AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > LCD Flat Panel Displays
Forum Jump
Old 02-28-08, 10:44 AM   #3061   |  Link
AVchemE
Originally Posted by moxyman View Post
1. Get the best picture. (currently too grainy, with "blocky" blacks)
2. Find out what firmware version/model I have to get the best settings.
When I go to SETUP>SW UPDATE> It only has USB as a choice no on or off. However in the info box at the bottom it does say, "The software could be updated". If i press anything, it searches for a USB. I cant do anything else, or get any other info. If I do the 1,2,8,POWER trick it shows on the main screen:...
1. What my firmware/software version is?
2. If I need to upgrade it?
3. Which of the 100+ page threads should I be in to find my settings?
Well, to start with I wasn't totally impressed with the 61 series for the reasons you quoted so I'm not sure if you'll get what you're looking for. You can try turning down the sharpness and contrast as a start.
As for the SW update. How do you think the TV is going to get the software, over the air? You have to download it to a flash drive. Currently there is no software update posted for the 61 series TVs at Samsung (I just checked).
Get a DVE disc or pre-order the Blu-ray version from amazon, go throught the calibration, and see if anything helps.
AVchemE is offline   Reply With Quote
Old 02-28-08, 10:35 PM   #3062   |  Link
mercerm
New Member
i have the 4061f. When watching hd channels on my comcast box the picture is incredible. But when i watch a blu ray movie using my ps3 the picture isn't even close to the quality i saw on display at best buy. it's not even better that the picture i get from cable. i am using the default "dynamic" setting w/HDMI cable. Does anyone have any recommended settings for the 4061 with the ps3?
thanks
mercerm is offline   Reply With Quote
Old 02-28-08, 11:17 PM   #3063   |  Link
montanaman
Classified Rating: 100% (1)
thanks
Check to make sure the PS3 is set to output 1080p.
__________________
4661 - 14/11/7
montanaman is offline   Reply With Quote
Old 02-28-08, 11:31 PM   #3064   |  Link
mercerm
New Member
yes it's set to 1080p. i was wondering if anyone had the exact same setup. to see what they had the ps3 video settings and 4061/4661 display settings configured to. i am a complete noob when it comes to this.
thanks
Old 02-29-08, 03:50 AM   #3065   |  Link
AVchemE
thanks
I gaurantee you've messed something up if your HD cable looks better than a blu-ray on the PS3. Is your aspect ratio set correctly (on the PS3 - 16:9, and on the TV - "Just Scan")?
If you're in a dimmly lit area don't use dynamic, but that shouldn't make your picture look worse than the Cable.
If you have the PS3 and cable connected to two different TV inputs (instead of plugging them into an HDMI capable receiver and sending one cable to the TV) just go through the options on the cable box input, write them down on paper, and then go to the other input and make sure they match exactly. Make sure you look at the detailed settings under picture and the settings menu.
Old 02-29-08, 06:56 AM   #3066   |  Link
Indecisi0n
thanks
Consider yourself lucky. I have comcast HD and my picture looks like #$%@. Still trying to figure out if its TV or cable signal.
Indecisi0n is offline   Reply With Quote
Old 02-29-08, 12:37 PM   #3067   |  Link
mercerm
New Member
I had problems at first with my comcast(motorola) box. If you have the same box, power it off then hit the menu button on your remote. It will bring up a white screen. There you can change it to 1080i and 16:9. My box came defaulted at 720.
Thanks AVchemE: i'll check for that Just Scan setting.
Old 02-29-08, 08:17 PM   #3068   |  Link
Indecisi0n
Is this the box you had ? (DVR )
This is the one i have.
Old 02-29-08, 09:19 PM   #3069   |  Link
cginex
why o why, help
i have calibrated about5x, all the same results. i used dve and avia II. my samsung lnt4661f looks like absolute garbage while watching a blu ray. it looks sooooo ridiculously grainy. DNIe is off, sharpness is down to 20 (lowering to 0 doesnt help), ive tried everything. here are my settings. Someone help me!
My Movie
contrast 95
brightness 48
sharpness 20
color 50
tint 52/48
backlight 6
color tone warm1
detailed
blk adj low
dyn cont low
gamma 0
color space auto
edge enh on
xvYCC off
__________________
Samsung LN-T4661f 46" LCD HDTV
Sony BDP-S300 Blu-Ray Player
Motorola DCT-3416 DVR (Comcast)
Yamaha RXV-496 Home Theater Receiver
Logitech Harmony 880 Remote
Samsung DVD-R120 Recorder
cginex is offline   Reply With Quote
Old 02-29-08, 09:58 PM   #3070   |  Link
kirinichiban
New Member
I've had a LNT4665f for a few months now, but just got around to getting an HD cable box from time warner. I have this weird problem and I don't know if its the tv, the box, or the signal. when watching the HD channels when a SD commercial comes on the picture will blink between the video and a black screen sometimes. It doesn't do this every time or for the same channel, and watching SD video through the SD channels is fine. Anyone know whats up with my set? oh the box is a scientific atlanta explorer 3100HD and I have it going to the set with component cables.
kirinichiban is offline   Reply With Quote
Old 02-29-08, 10:06 PM   #3071   |  Link
moxyman
I have changed my panel size as per the first page post. (it was set on 46AU).
But now i notice white fading (so not pure black) in all for corners. Any idea how to fix that?
moxyman is offline   Reply With Quote
Old 02-29-08, 10:37 PM   #3072   |  Link
plat
i think you should change it back, sounds like you dont have a samsung panel
plat is offline   Reply With Quote
Old 03-01-08, 02:13 AM   #3073   |  Link
montanaman
My Movie
contrast 95
brightness 48
sharpness 20
color 50
tint 52/48
backlight 6
color tone warm1
detailed
blk adj low
dyn cont low
gamma 0
color space auto
edge enh on
xvYCC off
The settings look good. Could try the "standard" mode to see if DNIe helps. Also, try bringing down the contrast, I run mine around 50-60 and brightness 35. With lower contrast, color needs to increase, I run around 60.
Maybe the BR player has a problem? Maybe try a few different movies.
__________________
4661 - 14/11/7
Old 03-01-08, 01:23 PM   #3074   |  Link
Ice That Jaw
My Movie
contrast 95
brightness 48
sharpness 20
color 50
tint 52/48
backlight 6
color tone warm1
detailed
blk adj low
dyn cont low
gamma 0
color space auto
edge enh on
xvYCC off
I absolutely HATE gain but its on every movie regardless what TV you own. These are the best settings to reduce grain I've seen on the web. I had to come up with them myself ofcourse for my 4665f (trident).
Standard (with DNIe ON)
Contrast 65 or 68
Brighness 52 or 53
Gamma +3
Color Space AUTO (Wide color adds more grain to backrounds, trust me)
Backlight 0,1,2,or3 (I personally use 0 or 1 for Blu-ray)
Black Adjust OFF
Dynamic Contrast LOW
I use my PS3 and I have Y/Pb/Pr/Cb output so HDMI balck level is grayed out. That should be your last step if its not grayed out. Try these settings, you will be amazed at how much it reduces grain. I just watched 30 days of night on blu ray and it looked so sterile it was crazy.
__________________
LNT-4665F
T-TULPAUS0-1036, Aug 24 2007
T-TULPAUS5-1011 CS[D652] [46(AMV)-inch]
PS3
XBOX 360
Crappy Sound Reciever
Ice That Jaw is offline   Reply With Quote
Old 03-01-08, 05:29 PM   #3075   |  Link
mercerm
New Member
thats not the box i have hooked up. i do have that box in my bedroom. i was actually getting ready to replace my older box for that one. i guess i should test out the one in my room on the samsung before i do. I'll let you know how it turns out.
cginex : i'm having the same issue with my blue ray. The picture isn't horrible but i just can't seem to get it right. It's either too dark, too light, or too grainy. as of now on my 4061 my settings are:
Standard
Cont - 90
Bright - 40
sharp - 20
Color - 50
Tint - 50
Backlght - 9
ColorTone - Normal
Size - Just Scan
Dig NR - Auto
DNIe - On
Detailed Settings
Black Adj - off
Dyn Cont - low
Gamma - -1
Color Space - Auto
Edge Enhance - on
These settings are ok, the darks are nice. i would like a little more pop on the colors but the picture gets too grainy when i try to brighten any setting up. If i can get the picture to look as good as the sony blu ray display in best buy i think i'll crap my pants. Also, i think the fact that i spent all of this money and still have to deal with the black bars is bumming me out. Will there ever be conformity in the movie/tv industry?
Old 03-02-08, 11:42 AM   #3076   |  Link
Einride
Go back to Best Buy and get the same BluRay disk used for the Sony display. Put your TV into default Standard Mode setings, or, better yet, default Dynamic Mode settings. Put your BluRay player into and endless loop, and enjoy.
__________________
Samsung LN-T5265F
Dynex DX-L32-10
Proscan 40LC45S
Einride is offline   Reply With Quote
Old 03-02-08, 03:43 PM   #3077   |  Link
mercerm
New Member
believe me i've thought about it. Anything that would ease the pain of wasting 4 bills on the ps3.
Old 03-02-08, 04:08 PM   #3078   |  Link
AVchemE
mercem, this is a very strange problem. Sure I'm not totally excited about the 61, but it shouldn't look that bad not comparred to Vizios, Toshibas, LG, Sharp, or other crap that you could buy.
You are NOT using the movie "300" to check picture quality, right? Try connecting to the PSN (playstation network) and download a 1080p movie trailer. This will tell you if its your TV or a broken laser on the PS3.
Your settings look good, almsot exactly what I have (my backlight is at 4 and I set neutral collor, but that's the biggest difference from your list). Is game mode and DNIe on or off?
Old 03-03-08, 03:02 PM   #3079   |  Link
mercerm
New Member
I'm starting to think it is the movies i was watching. I have spiderman 3 that came with the PS3 and Pirates at worlds end. I bought the game Uncharted for PS3 yesterday and the picture was Amazing!. I was just thrown off because the display at bestbuy was showing clips of one of the pirates movies at it looked alot better that than the picture i was getting. I guess thats a sales ploy. It definately worked on me. I'll have to try to download a trailer from the PSN to check out the quality. Thanks for the tip.
If you have the PS3 have you messed around with the xvYCC setting? I was thinking if i enable that setting on both the tv and the ps3 and lower the contrast and backlight i might get a little better of a picture.
Old 03-03-08, 04:18 PM   #3080   |  Link
S. Hiller
Has anybody measured the color space on one of the more recently manufactured sets, say September or November forward? Perhaps a CIE chart with measured against NTSC?
Wondering how good the color space is since Samsung started using an 8 bit panel with presumably 72% of NTSC instead of the original 10 bit and 92% panel...
S. Hiller is offline   Reply With Quote
Old 03-03-08, 08:10 PM   #3081   |  Link
mth0611
New Member
Has anyone with a Cortez processor found picture settings that they're satisfied with? Every set of settings I've found so far are from people with the Trident processor, and I haven't really been able to dial in decent picture settings for this TV yet.
So, If anyone could post their picture settings with an LNT4665f with a Cortez processor, I'd appreciate it. Thanks!
mth0611 is offline   Reply With Quote
Old 03-04-08, 04:15 AM   #3082   |  Link
AVchemE
Some movies are recorded with high gain, which makes the image grainy. I would think that Pirates would be grainy... probably spiderman too (an animated movie would be better to try out, as you saw with Drake's Fortune). I bet if you went back to best buy the image wouldn't look much better from what you're experiencing if you stood the same distance away. If it does, it's probably because there are more lights on and you don't see the same level of detail as you might at home.
I had super white on and then I turned it off. I have recently noticed more Banding (see my previous posts) and I'm starting to think this was the problem. I'll go turn it back on and make sure that BD/DVD output is set to Y/Cr/etc.
Old 03-04-08, 07:53 PM   #3083   |  Link
cginex
heres a question. why on my 4661f when i set standard and movie to the exact same settings do they look different? i can set contrastm brightness etc all to the same settings, even the detailed settings will be the same (black adjustment, etc) to same and yet they look different. any explanation. personally i think the standard looks more grey and washed out but yet movie although looks blacker and more true looks too dark. i need to turn my backlight up to 6 7 or 8 for my house. is this weird? anyone else use backlight this high #1 and #2 why do they look different when set at same settings? thanks fgor the help.
__________________
Old 03-04-08, 09:27 PM   #3084   |  Link
cginex
i found this on samsung in troubleshooting. does this make sense to anyone? anyone done this? does it work?
Resolution Settings
All HD cable and satellite boxes have resolution settings you can set to optimize the picture of your TV. This TV works best when it receives a 720p signal. To get the highest quality picture, set the box to output at 720p. If you do not know how to set the resolution, call your cable or satellite provider.
I personlly have my comcast box on 1080i (obviously there is no 1080i) so i thought 1080i would have been better than 720p, am i wrong?
__________________
Old 03-04-08, 10:20 PM   #3085   |  Link
tdrag97
Resolution Settings
I also have the concast box... what/how do you set the box?
tdrag97 is offline   Reply With Quote
Old 03-04-08, 10:22 PM   #3086   |  Link
cginex
on ur remote hit cable, then power, it will turn off
then hit menu, should bring up a settings screen
goto the 2nd optiuon where it says hdmi outout, use the remote to change it
hit power again 2x and box will turn back on
__________________
Old 03-04-08, 10:31 PM   #3087   |  Link
Indecisi0n
I have my comcasr HD DVR set to 1080 and my screen looks great. I also went ahead and changed the output to RBG
Old 03-04-08, 10:44 PM   #3088   |  Link
cginex
hmmmm rgb
im curious why change the setting to rgb as opposed to the ycc whatever?
__________________
Old 03-05-08, 12:01 AM   #3089   |  Link
dj330xi
Resolution Settings
I'm curious about this too. I have RCN, Motorola 3416 box. Just checked CNET, and the majority of HD channels are output in 1080i, though there are some that are 720p:
http://www.cnet.com/4520-7874_1-5119938-1.html
I have my cable box set to 1080i output - can't set it differently for different channels as far as I can tell. Would 720p be better? For 1080i content, it seems that setting it to 720p will result in the image being processed twice - from 1080i to 720p by the cable box, then from 720p to 1080p by the TV. Would this be better than 1080i content being sent to the TV then processed once to 1080p?
A second related question: I keep seeing people recommend RGB output rather than yppc output. Does this mean it is better to use component output than hdmi output?
__________________
Module: T-TULPAUSC-1014, Date:
Micom: T-TULPAUSS-1011, ACL: T-TULPAUSG-1007
dj330xi is offline   Reply With Quote
Old 03-05-08, 02:48 AM   #3090   |  Link
byyoung
which settings should i use?
i have a 4661f. bought in may 2007. original board = 1016/1004. replaced few days ago because of recurring green flashes and dropouts. now 1037/1011. which calibration settings should i use? the ones in this bulletin board (i.e. post 1499) or on the 1007/1011 board? sorry if this question has been asked before but there are just too many posts.
byyoung is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.38776398 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
