#1 | Link |
Feedback for May 15th's Xbox 360 HD DVD Audio Update
Hey all,
As I'm sure some of you are aware, Amir in the Insider's Forum officially announced the HD DVD audio update to be out tomorrow (May 15). I've decided to start a thread where everyone can post their feedback on the update, and well as post questions and answers. Let's hope the update lives up to the 6 month wait. Please post your feedback here! Last edited by Dr_Kn0w; 05-14-07 at 04:45 PM.. |
#5 | Link | |
Here's what the HD DVD audio update will include on May 15th:
- Fix DD being stuck in "Night Mode" which is essentially Dynamic Range Compression leading to the sound sounding very flat - Option to output ALL HD DVD audio as DTS 1.5Mbps (list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs I may have missed) - Option to output ALL HD DVD audio as DD 640Kbps, (which it currently does, but will be fixed from the Night Mode bug), list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs that I may have missed. - Option to output ALL HD DVD audio as WMAPro 1.5Mbps, (list includes DD+, TrueHD, DTS, and any other audio option offered on HD DVD discs I may have missed) for those receivers that support WMA. - Option to enable/disable Night Mode (with the default set to off) - Fix a number of disc incompatibilities (including DVD Essentials) as well as a number of Lip Sync issues. This update is SEPARATE from the Spring Dashboard Update that came out on May 7, 2007. This was supposed to come out a long time ago, as the problem was identified back in November when the HD DVD drive was launched. I hope this clears the air as to what we're all waiting for. Last edited by Dr_Kn0w; 05-14-07 at 06:27 PM.. |
#13 | Link |
Jedi Master
What are the implications of the DTS 1.5 output when the original program was Dolby? This would be transcoding, right?
__________________
-- "No matter where you go, there you are." SXRD/Denon/Polk/PS3/360 Blu-ray bliss with the great PlayStation 3! SXRD Owner's Thread PSN: Uxi |
#14 | Link | |
Swollen Member
However, the original program may be a DD+ 1.5 Mbps track and some believe that re-encoding that to 1.5 Mbps DTS or 1.5 Mbps WMA Pro might be superior to re-encoding to 640 Kbps Dolby Digital. FWIW, some of the Toshibas only offer 1.5 DTS output and no DD 640 Kbps at all. One wonders why Toshiba chose this, especially since not all receivers support DTS.
__________________
Everything Apple | Xbox 360 HD DVD audio lag | HD DVD movie size | Funai Blu-ray disc compatibility |
#15 | Link | |
Jedi Master
Right. I'm wondering if there is the possibility, if not likelyhood of this causing degradation of AQ, though. Obviously I'll try it out if/when it's ready...
What receivers accept WMA Pro anyway?
__________________
#17 | Link |
Just an FYI.....I've heard a lot of people asking about how this update's going to come. From why I heard, you'll be prompted to update when you insert an HD DVD into the HD DVD drive (just like when most of us inserted King Kong into the drive for the first time).
This means it WON'T be an automatic update as soon as we log into Live (like the Spring Dash update). Hope this clears the air for those who fire up their 360 tomorrow and don't see the update and say "WTF?? Where's the update??!" |
#18 | Link |
i know it hasnt been tested yet but will forcing the audio to DTS be the best since its 1.5mbit vs the 640 DD?
And I assume there will be an option in the system settings to do all of this?
__________________
AggieFans.com http://www.bundyology.com/bal2.jpg "Pretty women make you buy beer. Ugly women make you drink beer." -Al Bundy- |
#20 | Link |
Techie
This is great news...finally I can watch some of my DD+ only HD-DVDs without them sounding like crap.
The NIN disck was particularly bad because it had DD crippled by DRC and the TrueHD track was bugged and playing with high pitch static/chirps. Hopefully the NIN disk is one of the bugs that are fixed (must be that is a well known and noted problem)
__________________
Paul Taatjes |
#21 | Link |
I have a quick question about this update...
I currently have a Sony Theater in a Box 550 Watt 5.1 surround system. My 360 is hooked up via Optical. Will my recieve be able to recieve the 1.5Mbs signal with tomorrows update using DTS (which is does decode) or will I still be stuck with 640kbs? Will I notice an obvious improvment in sound with this update and my little $250 surround system? |
#23 | Link |
According to amirm the wma pro option is the best. His words was it was the VC-1 of the audio codecs. Problem is not too many recievers support this codec, however I have a Pioneer elite VSX59TXI which does whoooo hoooooo. I think all pioneer elite recievers support it. DTS would be my next choice if I didnt have wma pro.
#24 | Link | |
Jedi Master
__________________
#25 | Link | |
Swollen Member
ie. Even DD will sound much, much better after the update. Whether or not DTS is even better still is another question. On your system, probably not.
__________________
#27 | Link | |
Swollen Member
__________________
#28 | Link | |
Hydra slayer
@Preditor74: Good news: you will be able to hear the difference. Bad news: the full dynamics might destroy your Sony HTiB. You better be careful when you crank it up!
__________________
Format neutral! (prefering HD DVD which is build on quality while blu-ray is build on marketing) CETERUM CENSEO BLU-RAYEM ESSE DELENDAM! |
#29 | Link | |
Take Him to Detroit!
#30 | Link | |
"- Fix a number of disc incompatibilities (including DVD Essentials) as well as a number of Lip Sync issues. " Guess I'll find out for sure tomorrow.....
__________________
"Evil is as evil does, and laws disarming guaranteed victims make evil people very, very happy. Shame on us." Ted Nugent |
| Bookmarks |
| Thread Tools | |
