AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > LCD Flat Panel Displays
View Poll Results: Will you be keeping the Sceptre X46BV-FULLHD?
Yes 122 56.48%
No 94 43.52%
Voters: 216. You may not vote on this poll
Forum Jump
Old 05-30-07, 01:26 PM   #1   |  Link
xport
46" Sceptre LCD coming Mid Q3 2007
From Sceptre Sales office:
Yes, the information you received in the latest issue of Costco's Member Passport is correct. We recommend you purchase the 42" now. Sceptre will be releasing our 46" HD TV in the mid Q3 2007.
The module 46" is still in the production phase, weather or not it's a Komodo or Naga series has not been released at this time.
Best Regards
Again, thank you for purchasing Sceptre branded products.
Now....do I wait for the 46" or do I jump on the 42"?
xport is offline   Reply With Quote
Old 05-30-07, 01:31 PM   #2   |  Link
gi0rgi0
Ive been wanting to know some info on this as well since the 42" vizio 1080p model will be out before that one is on sale with the coupon. 46" sounds nice though, but the vizio is rumored to have the 120hz refresh rate. I wonder how much the sceptre will be before the $300off coupon ?
gi0rgi0 is offline   Reply With Quote
Old 05-30-07, 01:34 PM   #3   |  Link
xport
I emailed, awaiting reponse
I have emailed back about pricing.
MOD Note [ Do not post any pricing other than MSRP in AVS Forum. Thanks]
Old 05-30-07, 02:15 PM   #4   |  Link
Jithtproject
We just want MSRP.
__________________
JHT
Jithtproject is offline   Reply With Quote
Old 05-30-07, 02:41 PM   #5   |  Link
xport
Pricing Reply
I got a reply, but it doesn't contain much info.
Sent: Wednesday, May 30, 2007 3:39 PM
Subject: RE: Sceptre 46 1080p HDTV LCD
Still TBD.
Old 06-02-07, 09:36 AM   #6   |  Link
redgtconv
8:000:1 Dynamic Contrast and 3 HDMI, even though it is listed as dual HDMI. There are 2 on the rear and 1 on the side.
redgtconv is offline   Reply With Quote
Old 06-03-07, 01:27 PM   #7   |  Link
xport
Resolution: 1920 x 1080
Dynamic Contrast: 8,000:1
The Sceptre 46” Full 1080P LCD HDTV, brings brilliant life like imaging to your fingertips. Whether for professional for residential applications, the Sceptre 46” is a perfect fit.
Features:
*Screen size: 46”
*Resolution: 1920 x 1080
*Dynamic Contrast: 8,000:1
*Viewing angle: 176° H x 176° V
*Tuner: ATSC /QAM /NTSC
*HDTV Compatibility: 1080P
*HDMI input x3 (Rear x2, Side x1)
From the Sceptre site:
Old 06-12-07, 12:01 AM   #8   |  Link
crakarjax
DSP Guru
any word on this?
crakarjax is offline   Reply With Quote
Old 06-12-07, 10:40 PM   #9   |  Link
xport
Nope
, Sceptre said it was not yet decided
Old 06-14-07, 09:26 AM   #10   |  Link
crakarjax
DSP Guru
Bummer... I'm trying to decide whether or not to return my 42" Sceptre and go for the 46. Time is running out!
Old 06-14-07, 05:45 PM   #11   |  Link
HTSS-TR
I returned my 42" Sceptre last week before the 90 days return limit and waiting for the 46" 1080p. In the mean times I am using the 20 years old 17" CRT. Going from 42" HDTV to 17" CRT is suck big time.
HTSS-TR is offline   Reply With Quote
Old 06-15-07, 09:30 AM   #12   |  Link
d94
woaa 8000:1....i wonder if i should upgrade to that from my westy, or just hang on to the westy!
__________________
47" 1080P LG
52" 1080P Sharp
d94 is offline   Reply With Quote
Old 06-15-07, 12:57 PM   #13   |  Link
redgtconv
8:000:1 is a dynamic contrast number which holds no real basis. Each manufacturer determines their own dynamic contrast which is a major marketing tool. Do not rely on that spec. The panel manufacturers state the true contrast ratios which are typically 1000 or 1200:!. If you can find out who manufacturers the panel and go their site, you will see the true contrast ratio. Sceptre is one of the few manufacturers that is very secretive about who manufactures their panels. Call them and ask, I'll bet they tell you NO!
Old 06-17-07, 04:12 AM   #14   |  Link
tomprc
New Member
On the 42" thread, someone posted a response from Sceptre CSR stating that even the 42" has a native CR of 1500. So I expect this one has a higher CR.
tomprc is offline   Reply With Quote
Old 06-19-07, 03:05 PM   #15   |  Link
redgtconv
I called Sceptre today and I was told that this tv will be a Costco exclusive. Therefore Sceptre will not be giving out any information directly to consumers. All information will be provided to Costco and they will post the information as it is released.
Old 07-02-07, 07:01 PM   #16   |  Link
cougs1
X46GV-FullHD HDTV LCD
It is here and below are the specs:
1. HDMI = 1.3 version
2. No USB
3. MSRP=$1699
4. A grade LCD guarantee
5. picture: http://www.sceptre.com/Products/LCD/...6GV-FullHD.htm
6. No mention of Faroudja deinterlacing technology
Costco may list it at $1499 and $300 off
<enlarged Image> 3 HDMI v1.3 (2 Rear, 1 Side)
46" 16:9 HDTV LCD All-in-One ATSC/NTSC/QAM Tuner
1080P Full HDTV PIP and POP
1080P thru HDMI & Component PC Compatible (DVI & VGA)
8000:1 Dynamic Contrast
Swivelable Stand (±25ş)
5.1 Digital Audio Output
Self Power Off (While No Signal Input)
DETAILED SPECIFICATIONS :
LCD Panel
46" viewable wide color LCD TV
Aspect Ratio 16:9 Wide Screen
Brightness 550 cd/m2
Contrast 8000:1
Response Time 8 ms
Viewing Angle 178 L/R, 178 Up/Down
Backlight Lamp life > 50,000 hrs
Video Functions
De-interlace - 3D, SRC (Scan Rate Conversion)
Frame recover 3:2
Noise Reducing Core Technology : 3D Digital
Comb Filter, Digital Noise Reduction
Aspect ratio : 1:1, 16:9, 4:3, Zoom1, Zoom2,
Panorama
Gamma Fixed Gamma
Lamp adjustment
Picture mode : Custom / Standard / Mild / Vivid /
Multimedia / Recall
Video adjustment : Contrast / Brightness /
Sharpness / Saturation / Tint / RGB
Color temp. adjust : Cool / Normal / Warm
Picture Enhancement : APL (Dynamic Average
Picture Level), Dynamic Sharpness Adjustment,
Enhanced Color Management
PIP/POP Yes
Audio functions
Output (RMS): 2 x 10 Watts
Sound Enhancement: Digital Signal Processing
SRS TrueSurround XT
Built-in speakers: 4 x 10 watts per Channel
Connections Port
Hybrid TV Tuner NTSC, ATSC & QAM Tuner
AV 1 (CVBS / S-Video), Audio L/R in
AV 2 (CVBS / S-Video), Audio L/R in (Side)
YPbPr1, Audio L/R in
YPbPr2, Audio L/R in
HDMI 1, HDMI 2 & HDMI 3 (Side)
VGA, Stereo in
Other Connections: S/PDIF out (optical)
Compatibility Signals
Coaxial input support:
- Digital (ATSC) and Analog (NTSC) TV
in air
- Digital and analog TV in cable
(unscrambled signal only) QAM
Composite Input support
Component input support: 1080P, 1080i, 720P,
480P and 480i video signal
HDMI input support :
- 1080P,1080i, 720P, 480P,480i video
signal
- HDCP video up to 1080P
- Native resolution : 1920X1080
- DVI Max. resolution : 1920X1080
- VGA Max. resolution : 1920 x 1080
Control Functions
Digital TV & Analog channel
Channel return, Favorite Channel
Closed Caption
Channel auto scan
Sleep timer : Off /15mins /30mins /60mins
/90mins /120mins
V-Chip
Picture setting / Sound setting / Program Guide
Regulation
CSA, CSA-US, FCC Class B
Sizes & Power
Wall Mount Bracket (optional)
: Height 400mm x Width 200mm
LCD Dimension :
40.5(W) x 27.31”(H) x 9”(D) inch with Base
40.5“(W) x 25.5“(H) x 4.5”(D) inch w/o Base
Box Dimension : 44"(W) x 31"(H) x 12"(D)
Net Weight : 63lbs Gross Weight : 79lbs
Power Source Input : 100-240AVC, 50/60Hz,
3.5A max
Cougs
cougs1 is offline   Reply With Quote
Old 07-02-07, 07:51 PM   #17   |  Link
HTSS-TR
2. No USB
3. MSRP=$1699
Sizes & Power
LCD Dimension :
3.5A max
Cougs
Some infos are copied from X42GV-Komodo. Specially the Sizes and Power, width should be about 44" not 40.5" as X42GV42-Komodo.
Old 07-03-07, 11:30 AM   #18   |  Link
capt.video
2. No USB
3. MSRP=$1699
LCD Panel
Contrast 8000:1
Response Time 8 ms
Video Functions
Frame recover 3:2
Panorama
Gamma Fixed Gamma
Lamp adjustment
Multimedia / Recall
PIP/POP Yes
Audio functions
SRS TrueSurround XT
Connections Port
VGA, Stereo in
in air
signal
Control Functions
Closed Caption
Channel auto scan
/90mins /120mins
V-Chip
Regulation
Sizes & Power
LCD Dimension :
3.5A max
Cougs
on the sceptre website @ the lcdtv product section the response time is 6ms... hope this not a misprint... as the X42GV is 6ms & has the faroudja upscaler which is not listed also (or is it not needed on a full hd 1080p set) I am waiting for when the final price is actually listed & hope it does not have any "issues" w/ it b4 I pull the trigger
capt.video is offline   Reply With Quote
Old 07-03-07, 11:56 AM   #19   |  Link
taurus2007
But the new Sharp AQUOS is 720p while this set is 1080p.
__________________
Go 24
taurus2007 is offline   Reply With Quote
Old 07-03-07, 12:45 PM   #20   |  Link
osiris3mc
New Member
Oh is it? I just assumed it was the 1080p model....
osiris3mc is offline   Reply With Quote
Old 07-03-07, 01:39 PM   #21   |  Link
cougs1
guys,
anyone knows what is the refresh rate is for this set. The PDF file does not discuss this.
is it 60HZ or is it 120 HZ. Since this TV will have an HDMI 1.3 V which is very good.
Cougs
Old 07-03-07, 01:55 PM   #22   |  Link
taurus2007
I guess you just have to wait until August 6 to see what the price would be and whether you would have to pay for the shipping for the unit. I doubt if you can purchase it from a local costco store unless you are in Kirkland.
Old 07-03-07, 03:23 PM   #23   |  Link
unwired
New Member
Costco has a Magnovox 42" on sale now. Seems to have a better native resolution than the 46 sceptre.
Product.aspx?Prodid=11213783
As preveviously stated, who buys the sceptre 46" will have a lot to do with the final price.
I'd love the larger screen but am not really willing to throw an extra $400-500 for 4 diagonal inches.
unwired is offline   Reply With Quote
Old 07-03-07, 04:11 PM   #24   |  Link
taurus2007
46" has about 20% larger screen size then 42".
Old 07-03-07, 04:29 PM   #25   |  Link
RobDMB
In general what is the difference between the Naga and the Komodo series? Is one generally better than the other?
RobDMB is offline   Reply With Quote
Old 07-04-07, 04:28 PM   #26   |  Link
sandia1
New Member
Info is on Sceptre site -check it out!
I had been checking the Sceptre website a few times a week for the past month. I think this TV is better than the others Costco has especially if you want to use it as a computer monitor too (the ones they had on special so far won't display PC at 1920x1080).
They post a MSRP of $1,699, and call it 'X46GV-FullHD', and is in the Komodo line.
I'm 98% sure this is the one in the Costco passport.
sandia1 is offline   Reply With Quote
Old 07-04-07, 04:59 PM   #27   |  Link
tcatnat
Does anyone know if this TV has cable card slot? I looked at the specs but didn't see it mentioned unless it goes by another name.
__________________
Tom
tcatnat is offline   Reply With Quote
Old 07-05-07, 11:34 AM   #28   |  Link
osiris3mc
New Member
Okay, just to clear up the confusion on the refresh rate and contrast ratio...I asked Sceptre and here's the reply email:
Dear Customer,
Thank you for contacting us. We have just recently posted the model page. This is a typo on the index page. The response time is 8ms, not 6ms. The dynamic contrast is 8000:1 and the static contrast is 2000:1. If you don't see a price on Costco yet, that means they have not finalized with one yet.
We apologize for your inconvenience. Thank you for your understanding.
Best Regards,
Sceptre Technical Support Group
Old 07-05-07, 12:53 PM   #29   |  Link
capt.video
what's w/ 8ms?
Dear Customer,
Best Regards,
only 8ms? my X42GV is 6ms! & has 2k CR (native/static... since no mention of dynamic in the specs) & also has the faroudja scaler... ( I know its a 720p/1080i set) but...I have been seeing a few new 1080p sets w/ just 8ms..looks as its the industry's standard for 07/ 08
Old 07-06-07, 08:43 AM   #30   |  Link
EGOvoruhk
Dang, I just found this TV
Think it'll be too much for a desk computer monitor?
I was using the 42" Vizio, but returned it because it looked like poo over DVI
EGOvoruhk is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.31655002 seconds (100.00% PHP - 0% MySQL) with 11 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
