AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Digital Video & Audio Devices > Digital Media Servers & Content Streamers
Forum Jump
Old 06-06-07, 09:28 AM   #1   |  Link
GreySkies
Joe-12-Pack
Media Server Software Comparison
I'm of the opinion that the server software one uses is as important (if not more) than the actual media extender chosen. That said, I'd like to get a master list of different server software and the pros and cons of each, perhaps something we can use as a sticky.
I'd like to avoid any Apple flames; I know many people who use iTunes and love it, and just because it doesn't work for me doesn't mean that I don't think it's a legitimate choice for others; one needs to weigh the pros and cons.
I'd also like to avoid any XBMC flames; I know many people who use XBMC and love it, and just because it doesn't work for me doesn't mean that I don't think it's a legitimate choice for others; one needs to weigh the pros and cons.
I'll start out with what I've tried (disclaimer: I'm currently using Tversity). Feel free to correct me if what I've written is incorrect. I'll change/add to this list as others post.
Basic File Server
Platform: Windows; Linux; Mac
Pros: Included with Most Operating Systems; No (little) Configuration Needed
Cons: No (little) Configuration Possible; Few Media Extenders Can Use; Requires Beefy Media Extender, Such as XBMC or HTPC.
D-Link Media Server
Platform: Windows
Pros: Free; Easy-to-Use; UPnP
Cons: Limited Functionality; Buggy; Doesn't Run as a Service; Sorts Album Tracks Alphabetically
Firefly
Platform: Windows; Linux; FreeBSD; AIX; Solaris
Pros: Free; Runs as a Service; Plays iTunes, Including Apple Lossless; Transcodes
Cons: Not UPnP
FUPPES
Platform: Linux; Windows; FreeBSD
Pros: Free; Transcodes
Cons: Not Fully UPnP-Compliant Yet; No Mac Support
GMediaServer
Platform: Linux; FreeBSD
Pros: Free; UPnP; Easy to use web based UI
Cons: No Windows or Mac; Larger Collections Take More Memory; Doesn't Appear to Transcode
iTunes
Platform: Windows, Mac
Pros: Free; Ubiquitous; Built-in Media Store; Easy-to-Use; Windows or Mac
Cons: Doesn't Run as a Service; Doesn't Work with UPnP Devices
Nero MediaHome
Platform: Windows
Pros: Bundled with Nero Burning Software
Cons: Not Free; Windows Only
JRiver Media Center
Platform: Windows
Pros: UPnP; Advanced Library Features; "Theater View" With HTPC; Works With iPod (and other devices); Transcodes
Cons: Not Free; Windows Only; Doesn't Run as a Service
SwissCenter
Platform: Windows; Mac; Linux; NetBSD; NAS
Pros: Free; Integrates With MusicIP; Controls for Paging Through Large Collections; Appears to be UPnP
Cons: ???
Tversity
Platform: Windows Only
Pros: Free; UPnP; Many International TV Feeds Built-In; Runs as a Service; Transcodes On-The-Fly
Cons: Crashes when a User Logs Off the Server; Still a "Work in Progress"; Menu Structure Not Customizable; Doesn't Play Protected Content; Difficult to Work With iTunes; Windows Only
Twonky
Pros: Runs as a Service; UPnP; Rock Solid; Customizable Menu Structure; Windows, Mac or Linux
Cons: Not Free; Doesn't Play Protected Content; Difficult to Work With iTunes
uShare
Platform: Linux; FreeBSD; FreeNAS
Pros: Free; UPnP; Easy to use web based UI; Included with FreeNAS
Cons: No Windows or Mac; Larger Collections Take More Memory; Doesn't Appear to Transcode; Doesn't Read All Tags Correctly
ViiV
Windows Media Connect
Platform: Windows
Pros: Free; Plays Protected WMAs
Cons: Windows XP and Vista Only; Not UPnP
Windows Media Player 11
Platform: Windows XP, Vista
Pros: Free; UPnP; Plays Protected WMAs
WIZD
Platform: Windows, Linux
Pros: Free, open source, compatible with Windows OS, Linux and NAS, easy to setup, low memory usage, no restrictions on the number of drives/folders/files, no restrictions on root directories, provides capabilities like playing ISO, VOB, file deletion, customizable skins and menu, ts file play, DV avi file play, does not hang up, runs solid day in and day out, runs as a service; Windows or Linux
Cons: The GUI could be a bit better, no NFS, does not play protected content, not UPnP
__________________
-Joe
www.marvindog.com
My Media Room Progress
GreySkies is offline   Reply With Quote
Old 06-06-07, 10:00 AM   #2   |  Link
digitalkid2
I would add;
WIZD
digitalkid2 is offline   Reply With Quote
Old 06-06-07, 10:05 AM   #3   |  Link
GreySkies
Joe-12-Pack
Added. Is WIZD UPnP? IIRC, I think it is, but am not sure.
__________________
-Joe
www.marvindog.com
Old 06-06-07, 10:06 AM   #4   |  Link
digitalkid2
I am not sure, just that it is based on Syabas middle ware. A visit to their site might clear things up. http://wizd.sourceforge.net/
Also, since you added WIZD to your list I have made a few more additions to my post regarding WIZD
Old 06-06-07, 10:11 AM   #5   |  Link
GreySkies
Joe-12-Pack
It's not. After looking at the Pros list, I was wondering why I didn't install it.
__________________
-Joe
www.marvindog.com
Old 06-06-07, 10:50 AM   #6   |  Link
BradMajors
New Member
Tversity will only run on a Windows machine.
Twonky will run under Windows, Linux, or MAC.
BradMajors is offline   Reply With Quote
Old 06-06-07, 11:12 AM   #7   |  Link
goofygrin
I don't understand the need to run software on the backend to simply serve up media?
I had a device that used a backend software and it was just a pain to use...
XBMC... no software = goodness.
goofygrin is offline   Reply With Quote
Old 06-06-07, 11:26 AM   #8   |  Link
GreySkies
Joe-12-Pack
You're still using software on the backend, even if it's just a basic file server. When you open a directory to sharing, you're enabling the file server in the operating system to serve that directory.
Not to knock an XBMC (I like them; I just don't have one), but they're closer to an HTPC than a pure media extender. And as such, can be well suited to working with a basic file server.
__________________
-Joe
www.marvindog.com
Old 06-06-07, 11:41 AM   #9   |  Link
digitalkid2
More XBMC rhetoric!
Old 06-06-07, 11:47 AM   #10   |  Link
GreySkies
Joe-12-Pack
Originally Posted by digitalkid2
More XBMC rhetoric!
Yeah, but it's sort of on-topic. Many people forget that a file server is still a server. I've added a "I'd also like to avoid any XBMC flames" caveat on my first post, and am adding File Server as a legitimate server type.
__________________
-Joe
www.marvindog.com
Old 06-06-07, 02:22 PM   #11   |  Link
skingery
Freenas
I'm just getting in to this whole realm so this thread will be interesting.
How about Freenas (www.freenas.org)? Build a pc out of old bits and serve up files.
Pros: Runs FreeBSD but even a monkey could set it up. UPNP. Gives you access to your files from anywhere on the network. Easy to use web based UI.
Cons: UPNP works but you have to manually restart the task to view new media added since the last time the task was restarted. It only takes a second but I haven't figured out a way to script it. (Im the monkey that installed it and don't know BSD enough to know if there is a way to script it). There are methods of restarting the whole box on a regular basis but that is a bit extreme to my mind.
I've also used TVersity to stream files from the FreeNAS box via a UNC path. This works well but you need to have both boxes on. Also TVersity is a little off on it's Vista support. I had to restart the service for my DSM-520 to see it.
skingery is offline   Reply With Quote
Old 06-06-07, 02:38 PM   #12   |  Link
GreySkies
Joe-12-Pack
I tentatively added it. I looked at the UPnP compatibility list and it shows "Winamp + On2Share for Winamp v0.1 Plugin." Is this the actual UPnP server and it's just running on FreeNAS? Or is the UPnP server actually embedded in the OS?
__________________
-Joe
www.marvindog.com
Old 06-07-07, 02:01 AM   #13   |  Link
skingery
embeded
It's part of the FreeNAS OS. Just as you can run CIFS shares or SSH you also have the choice of UPNP.
And yes, it is still a work in process but it is a nice solution.
Old 06-07-07, 02:53 AM   #14   |  Link
satgeek
Freenas basically uses the ushare UPnP server. I installed the latest version of ushare on my unRAID box and it didn't have the bug that it has in Freenas where it needs to be restarted.
FUPPES is another that seems interesting, though I haven't gotten around to trying it yet.
satgeek is offline   Reply With Quote
Old 06-07-07, 07:54 AM   #15   |  Link
GreySkies
Joe-12-Pack
I changed FreeNAS to uShare and added FreeNAS to the supported platforms, with being included with FreeNAS as a Pro.
Does uShare do any transcoding? It doesn't look like it from the website.
I also alphabetized the list to be more agnostic w/re my choice of server, and added a link to the website for each server.
__________________
-Joe
www.marvindog.com
Old 06-07-07, 11:28 AM   #16   |  Link
skingery
@GreySkies: I found a con for FreeNAS. While I do like the product the UPNP does have a downside: I doesn't show all the tags of a mp3 file when played through my dsm-520 (and I assume other clients as well)
@satgeek: ushare looks interesting. Do you know if I can use it on FreeNAS as a replacement for the UPNP service built in?
Old 06-07-07, 11:37 AM   #17   |  Link
GreySkies
Joe-12-Pack
Added.
I had a similar problem with my DSM-320 with all of the servers I tried until I started using MediaMonkey to edit my tags.
__________________
-Joe
www.marvindog.com
Old 06-07-07, 01:51 PM   #18   |  Link
satgeek
The UPnP service thats included with FreeNAS IS uShare.
Old 06-07-07, 05:10 PM   #19   |  Link
JAHarris
Hi,
How about JRiver Media Center. It supports upnp and has some great library features. If you should decide to use a full pc as the client then the latest version offers a very nice "Theater View" for use on the tv as well as a nice library server feature built in.
J
JAHarris is offline   Reply With Quote
Old 06-07-07, 06:11 PM   #20   |  Link
GreySkies
Joe-12-Pack
Originally Posted by JAHarris
Hi,
J
Added. Do you have a website for it? I'd g00gle it myself, but I'm cooking dinner at the moment and am waiting for a cast iron pan to heat up.
__________________
-Joe
www.marvindog.com
Old 06-07-07, 06:45 PM   #21   |  Link
skingery
Googled
J River Media Center: http://www.jrmediacenter.com/
Old 06-07-07, 06:46 PM   #22   |  Link
skingery
Is there a way to replace the version that comes with FreeNAS?
Old 06-08-07, 12:53 AM   #23   |  Link
kk131
New Member
Hi,
You should add Swisscenter. Quoting from the web site 'SwissCenter is a (free) replacement interface for a variety of Network Media Players made by manufacturers such as Netgear, Pinnacle, Buffalo, Lite-On, etc. The goal of the SwissCenter software is to provide a powerful interface that can cope with large media collections whilst remaining simple and intuitive to use.'
It's actively updated and has some nice features such as support for musicip.
kk131 is offline   Reply With Quote
Old 06-08-07, 02:12 AM   #24   |  Link
skingery
Originally Posted by kk131
Hi,
Googled
http://www.swisscenter.co.uk/
__________________
Scott
www.techlifeweb.com
Old 06-08-07, 08:47 AM   #25   |  Link
GreySkies
Joe-12-Pack
I haven't heard of that one before. I'll have to try it out this weekend and see how well the MusicIP part works.
__________________
-Joe
www.marvindog.com
Old 06-14-07, 12:48 PM   #26   |  Link
domerdel
New Member
Swiss Center doesn't support Mac
domerdel is offline   Reply With Quote
Old 06-14-07, 01:04 PM   #27   |  Link
kk131
New Member
I think it does. I can't post links here (haven't made 5 posts yet) but search the forum on the swisscenter web site there's a discussion 'Easy Mac OS X installation'
Old 06-14-07, 01:18 PM   #28   |  Link
GreySkies
Joe-12-Pack
According to SwissCenter's FAQ, Mac OS is supported.
__________________
-Joe
www.marvindog.com
Old 08-23-07, 08:23 PM   #29   |  Link
skingery
A couple I didn't see above:
Windows Media Player 11 (takes the place of windows media connect)
Windows only of course. One really great thing is that files added to watched folders are available on the server very quickly without having to manually refresh. This is a drawback of some of the other solutions I've tried. Additionally, you can create play lists to play on the server (at least the work on the DSM-520).
Another which I only just heard about is Nero MediaHome. Not free. Windows Only.
Comes with the suite of Nero burning software. I'm going to see if I can get this one working and report back.
__________________
Scott
www.techlifeweb.com
Old 08-24-07, 08:55 AM   #30   |  Link
GreySkies
Joe-12-Pack
Thanks Scott, I've added them.
__________________
-Joe
www.marvindog.com
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.61676502 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
