#62 | Link | |
I like this hobby
AVS GOLD CLUB MEMBER
The sealed unit is of particular interest ... 8 of those would be pretty cool in our theater room. ![]()
__________________
Owner of Tweak City Audio |
#63 | Link | ||
Early bird
*edit*I can say a BASH 300 is WAAY too small
Luckily I also have an ep2500.Quote:
If so, how many?
__________________
#64 | Link | |||
I think I'll put another layer on so I can call it a totally new project along with building up the varathane a 1/8" thick for this driver. I guess you know by now I'll have a few things to say once she's up and running though. I'm going to go ahead and try it out in a LLT sono also since I sold all my drivers to the Chuckster. Sheeze, all my DIY enclosures are empty.Quote:
Thanks Looneybomber for posting all the great pics! EDIT> Quote:
#65 | Link | |
RAW
We will have finished subs which the designs will sold as kits and or finished. |
#66 | Link | |
#67 | Link | |||
Early bird
You're welcome Sir Robert ![]()
__________________
#70 | Link | |
![]() I don't know if it's exactly the same dimensionally, but at the very least it's "inspired by." And it's a darned good place to get inspiration, too! |
#72 | Link |
I like speakers!
Wow yeah, i see a major resemblance there in basket design.
__________________
Only time will tell what the future holds...so until then JAM LIKE THERES NO TOMORROW! -Rob My Natalie P project |
#73 | Link |
I assume that a company like JBL has it's own proprietary tooling. There are so many baskets available that it's hard to decide which way to go.
As far as the fall is concerned we're evaluating the SDX12 sample and waiting for samples for our Extremis replacement. Then there might be a new plate amp, a Heil based tweeter as well as other products from vendors we already represent or are working with. Some of this will be limited to Canada where we work with American vendors and take the border out of the equation for Canadian customers. Bob |
#78 | Link | |
Transducer Engineer
AVS CLUB MEMBER
__________________
Jim |
#79 | Link |
Just got back from Al's (RAW Acoustics) and while we didn't get as much done as hoped we did test both the sealed SDX15 as well as the ported. We used a BASH500 as well as the LT1300 but didn't have time to get to the Crown CDi1000. Measurement screens from the SMS-1 were captured via digital camera. The subs were in the right front corner with the driver facing out and the microphone at ear level on the chair back in the first row of seating.
General conclusions: 1. Al's dedicated HT room is remarkably well damped with no major peaks or resonances. Somehow all that extra studding, bracing and double drywall makes a difference! 2. The ported version has more output. 3. The low pass crossover to roll off the sub worked on BASH but did not work on the LT1300 sample we were using so that would definitely need the LFE setting on the receiver. I will take this up with Elemental on Monday. 4. The 25 Hz bass boost worked very well on the LT1300. Screen shots to follow. Bob Last edited by Sir Robert; 06-23-07 at 06:26 AM.. |
#80 | Link | |
#81 | Link |
RAW
OK since Bob can not post the images I will.
Here is the sealed cabinet in room done with the SMS1 using the settings Bob showed above. No eq nothing on the SMS1 Just used for measurments in room Below same amp settings the ported has more SPL and out put over the sealed OK now the Ported design with the LT1300 no boost added and the SMS1 used in Auto EQ in 1 minutes time. ![]() |
#82 | Link | ||
Early bird
Because I have two, I may end up going with a 15hz tune.
__________________
#85 | Link | |
http://videos.streetfire.net/toprate...bb4cd10ec8.htm http://videos.streetfire.net/toprate...580035f079.htm ![]() |
#86 | Link | ||
Early bird
*sigh*
__________________
| Bookmarks |
| Thread Tools | |
