AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > LCD Flat Panel Displays
Forum Jump
Old 06-24-07, 11:45 PM   #1   |  Link
kcrossley2
Samsung LNT4665F or LNT4661F?
I've finally narrowed my 46" LCD TV choice down to these two Samsung models. I also visited CC this past weekend and checked them out. Both looked amazing, but that's coming from someone who currently owns a 32" Sony picture tube, so I may not be the best judge of LCD picture quality.
I'm planning on putting this set in a 19 x 20 two-story family room with five top windows and five bottom windows. The bottom windows have room darkening blinds, but the top windows are uncovered. Fortunately, there is no direct sunlight, but there is still lots of ambient light during the day.
Based on these conditions, which set would you purchase?
Kelly
kcrossley2 is offline   Reply With Quote
Old 06-24-07, 11:55 PM   #2   |  Link
pulsation
It sounds like the TV will be in a bright room. Personally I would go with the 4661, its a solid set overall and you won't have any glare to worry about. If you can control the light in the room and want to use it in dimmer conditions, get the 4665. I personally have the 4665 in my bedroom and love it. The glare definitely takes some getting used to though.
pulsation is offline   Reply With Quote
Old 06-25-07, 12:50 AM   #3   |  Link
wsfanatic
Go with the 4661F. The matte screen is better suited for the room you're going to put it in.
wsfanatic is offline   Reply With Quote
Old 06-25-07, 02:33 AM   #4   |  Link
tomanystraydogs
CNET Samsung LN-T4665F review
CNET Samsung LN-T4661F review
tomanystraydogs is offline   Reply With Quote
Old 06-25-07, 03:08 AM   #5   |  Link
zoman504
zoman504
Check out the LNT XX61/XX65 owners thread, a lot more useful info in there, those cnet reviews suck.
__________________
Ohio State Alum
Samsung 46A650 & 4661
PS3 60gig & Xbox 360 Elite
Time Warner 8300HD
Yamaha v661 receiver w/ Athena speakers
zoman504 is offline   Reply With Quote
Old 06-25-07, 07:13 AM   #6   |  Link
kcrossley2
Holly crap Batman!
That thread is 145 pages long! After reading more than 40 pages, it seemed like both Samsung sets suck, which wasn't what I was expecting. All I wanted was a simple, "You should buy this set because..." Any help would be much appreciated.
BTW, aside from the screens are there any significant differences between the 61 and 65?
Kelly
Old 06-25-07, 07:36 AM   #7   |  Link
Chris NYC
These sets don't suck. There's a lot of people who have had HDMI problems with the earlier firmware but things seem to be settling down with the latest. The 4665 is ok if you don't have direct sunlight hitting it.
__________________
Samsung LN-T4655F (P5/1028/1008), PS3 60GB, 360 Elite, TWC 8300HD, Onkyo TX-SR605
Chris NYC is offline   Reply With Quote
Old 06-25-07, 07:40 AM   #8   |  Link
kcrossley2
I'm glad to hear that. I'm sure this is personal, but I though the 4665 looked better than the 4661 in Circuit City, but it was in a rather dark environment and there were no windows. I guess if I find that glare is a problem, I can always return the set and purchase a 4661 instead.
So, I'm assuming your 4665 is fine?
BTW, how well does it handle an SD signal. I currently have DirecTV SD. I assume that I'm going to have to upgrade my service. Is that correct?
Old 06-25-07, 07:48 AM   #9   |  Link
Chris NYC
My 4665 is fine, but I lucked out and got the latest firmware (Amazon). You need to look for one that was manufactured in at least May. See the first post of the official thread for more info.
SD does not look so hot. You're going to want to get HD service.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.13913703 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
