AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Dedicated Theater Design & Construction
Forum Jump
Old 06-26-07, 02:51 AM   #1   |  Link
sarkleshark
hollow baseboard for speaker wire?
Are there any other options other than wiremold that looks good and will allow speaker wire to be run in or behind baseboard?
thanks
sarkleshark is offline   Reply With Quote
Old 06-26-07, 02:56 AM   #2   |  Link
mhallida
Wiretracks makes something like that. You could look into that. You could almost make something yourself after you see their demo of how it works. Pretty simple. Me? I like ripping down walls and using my wood cutting bits on my drill!!
__________________
Matthew
My Family Room / HT Hybrid Construction
mhallida is offline   Reply With Quote
Old 06-26-07, 08:53 AM   #3   |  Link
Kevin_Wadsworth
Regular baseboard and a router table would work pretty well. Just cut in a 1/4 - 3/8” deep channel into the back of the baseboard.
Kevin_Wadsworth is offline   Reply With Quote
Old 06-26-07, 09:08 AM   #4   |  Link
BIGmouthinDC
HT 2.0 Bound
AVS CLUB MEMBER
Even if you don't have a router table if you have a table saw you can make some groves. Just several passes moving the fence a bit at a time. Line up all your boards make one pass on each board, then move the fence and repeat.
Here is another option, make your own with strips of wood that hold the base board a little bit off the wall. When painted to match nobody would even know the difference unless you pointed it out.
BIGmouthinDC is offline   Reply With Quote
Old 06-26-07, 09:15 AM   #5   |  Link
McCall
Proud Grandmother
McCall's Avatar
AVS CLUB MEMBER
To further enhance Bigmouth's picture above, you could ad another pc of molding, 1/4 round or Ogee or such to the top for a more finished look as well.
__________________
McCall
Yup that really IS me in the avatar.
http://www.avsforum.com/avs-vb/showt...he+Mickelodeon
McCall is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.26141500 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2010 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
