| View Poll Results: Which Radeon HD do you own? | |||
| Radeon HD 2400 Pro |
207 | 31.90% |
| Radeon HD 2400 XT |
40 | 6.16% |
| Radeon HD 2600 Pro |
142 | 21.88% |
| Radeon HD 2600 XT |
224 | 34.51% |
| Radeon HD 2900 Pro |
6 | 0.92% |
| Radeon HD 2900 XT |
38 | 5.86% |
| Multiple Choice Poll. Voters: 649. You may not vote on this poll | |||
Thread Tools |
#1 | Link |
ATI Radeon HD 2X00 (2400,2600,2900) series owners thread
EDIT: Some quick links and info: (I'm going to keep updating this over the next couple of days...)
SPECIAL THANKS to Arfster, exDeus, ToughRowToHoe, and others who have offered valuable info and answered hundreds of posts! Arfster's summary post of Reg Tweaks: http://www.avsforum.com/avs-vb/showp...postcount=2121 as well from exDeus http://exdeus.home.comcast.net/ati-hd2x00/ ExDeus' Reg Tweaks Script: http://home.comcast.net/~exdeus/ati-hd2x00/ x.264/H.264 info: - tetsuo55 found some info on x264(encoder)/MKV/20fps bug over at Doom9: http://forum.doom9.org/showthread.php?t=132924 Arfster - "...The PDVD codec supports acceleration for all h264, except those that use extreme settings such as >4 ref frames (and some other stuff, someone a few pages back figured out exactly what). Unfortunately this includes most x264 encodes." http://www.avsforum.com/avs-vb/showt...7#post12473507 - DJBlu's x264 encoding tips: http://www.avsforum.com/avs-vb/showt...6#post12449406 ---------------------------------------------------- Audio related: ToughRowToHoe - http://www.avsforum.com/avs-vb/showp...postcount=3527 ToughRowToHoe - http://www.avsforum.com/avs-vb/showt...0#post12449880 "...ATI Knowledge Base Answer: 737-28867 In order to enable HDMI support on the Radeon™ HD 2000 series board through the DVI connector, AMD has designed a unique DVI-HDMI adapter..." - remember to set your audio output device in control panel/sounds and audio devices/audio, look for 'ATI' and 'HDMI' if thats what you want ---------------------------------------------------- General Info: (UNDER CONSTRUCTION! I'm going through the forum backwards...) Drivers: - install your manfacturer's drivers FIRST (included CD, etc), then get any ATI updates. Manfuacturer's drivers many include HDMI sound driver/AVIVO, which ATI drivers many not (at least, this is the case for my Asus 2600Pro) Latest public drivers from ATI: http://game.amd.com/us-en/drivers_catalyst.aspx Radeon 2400's: - Good for general HD disk playback (HD DVD, Blu-ray, 1080p, note: some disks are only 1080i, see below) - Not great at 1080i (broadcasts/satellite/some HD disks), has problems deinterlacing Radeon 2600's: - Good for general HD disk playback (HD DVD, Blu-ray, 1080p) - Can handle 1080i deinterlacing as well AGP: DPlettner - "...HA is not broken for all AGP owners. VC1 and AVC acceleration works great for me (both HD DVD and Blu-ray) on an old nForce2 AMD 3200+ AGP PC. However, for driver versions at 7.9 and above..." http://www.avsforum.com/avs-vb/showt...2#post12545542 some more info: http://www.avsforum.com/avs-vb/showt...5#post12361175 Tips on AGP installation: http://home.comcast.net/~exdeus/ati-hd2x00/#AGP More tips/info regarding AGP: added 02/08/08: http://www.avsforum.com/avs-vb/showp...postcount=3846 added 02/08/08: http://www.avsforum.com/avs-vb/showt...#post128447704 PowerDVD tips: - some options/checkboxes under configuration only appear while playing HD; DTS downmixing, etc ------------------------------------------------------------- Hi All, I thought that now that the lower end cards are starting to show up, we should start a dedicated thread for performance, issues and solutions. In keeping with the other owners threads, please refrain from price discussions, other than to say there is a sale on somewhere on these cards. Hopefully this thread will not be about where to buy, etc. I currently have the Sapphire HD 2400 Pro, which I picked up in downtown Toronto @ Canada Computers. I did some quick tests during the weekend, and saw some very promising, but not perfect results. In my setup, I'm currently running XP/MCE2005, and I'm outputting to a Westinghouse TX-47, via a DVI->HDMI cable. After solving my first problem (underscan @ 1920x1080), while trying some quick tests in WMP10, I would occasionally see some macroblocking and decompression artifacts, usually just before a large scene change, so I think it might be disk I/O issues. p. Last edited by protovision; 02-08-08 at 09:40 AM.. Reason: update/summary |
#2 | Link |
AVS CLUB MEMBER
I also have a Sapphire 2400Pro and the results are pretty bad with PowerDVD 7.3 build 2911.
I have tried the card with XP and Vista. On both systems, I cannot play HD DVDs and BD's with Hardware Acceleration enabled. I get macro-blocking, screen corruption, green flashes, blank screens. I can run without hardware acceleration. I got it to work for one resolution: 1920x1200 on my XP systems but it would not work at 1920x1080. I can get it to run without hardware acceleration. Also, I had to uncheck the application controlled in the video setting to get consistent black levels. It does look great without HW/Accel. Also, I have submitted support requests to PowerDVD and ATI. - Rich |
#4 | Link |
Me neither
I also tried the Sapphire 2400Pro, but I'm sending it back. Unlike RichB's experience, PowerDVD 7.3 2911 worked fine, for the most part, both with and without accelleration. Once it chrashed for no reason, and once it gave me some funny message about not communicating with the display (HDCP, I suppose). Otherwise it worked fine; I even had a feeling it had less banding (I run a 7900GS to a 1366 x 768 plasma), but that would require more testing with color profiles, and I've already pulled the board out.
It's MCE and normal operation that I'm sending it back for: Every time I try to play a digital TV channel, or a digital recording, MCE 2005 crashes. So does Media Player on those recordings. I get sparklies when I play photos in MCE (over 50' DVI cable) -- I had an old Radeon 9250 board that did the same -- I guess the DVI transcievers are substandard. I pulled the card from the HTPC and put it in my desktop, and it had the same behavior with those digital recordings, but no sparklies. What's more, once in a while the screen blanks and after a few seconds I get one of those VPU recover messages -- something like the board doen't resopond to driver commands. The issue with digital channels is probably software related, and I understand that I may have received a bad unit, and another one might work fine, but I've had some bad experiences with other Sapphire boards, and I'll wait until something else shows up, and put up with banding in HD-DVD some more. |
#5 | Link | |
Yup, I'm getting the driverstoppedresponding error messages in Vista, several times a day. Had the same thing with the 8500gt a bit, but it stopped after a few driver updates. Possibly it might be a PCIE voltage issue too.
A 50' dvi cable is an absolute monster though, that's well outside the standard. I'm severely unimpressed with the card, but I don't really think you can blame it for that one :-) |
#6 | Link | |
AVS CLUB MEMBER
I also submitted a tech support request to Sapphire for good measure. - Rich |
#8 | Link |
Edit: updated. Probably worth getting the Vista hotfix mentioned further down in thread too. As of today (10/july), the only remaining problem in Vista is forced tv>pc colour expansion with videos that are >719 vertical lines. Anything lower is fine.
These are for Vista problems, but some work for XP also. The difference is that in XP they're dwords, and go into the root (0000) directory rather than umd/dxva. For either OS, if you uninstall the driver it deletes all these keys, and the reinstall will set them back to default. 1) For the 2400 only, mpeg2 HD hardware acceleration doesn't work, and neither does European 25/50fps 1080i50. Set these strings to zero: HKR, "UMD\DXVA",DXVA_NOHDDECODE (add if it isn't there) HKR, "UMD\DXVA",DXVA_Only24FPS1080H264 HKR, "UMD\DXVA",DXVA_Only24FPS1080MPEG2 HKR, "UMD\DXVA",DXVA_Only24FPS1080VC1 The SORTOVERRIDE ones mentioned elsewhere are probably worth keeping - ATI have them in the 2400 installation but not the 2600, so there must be a performance reason. It's not a problem either, since mpeg2 acceleration works with them there as long as NOHDDECODE is at zero. However, it's possible 60fps 720p material might be unaccelerated as a result of the fpscap one, haven't checked. 2) Horrible forced denoising and sharpening, seemingly for XP/Vista and pretty much all Radeons. Add these keys to umd/dxva: TrDenoise 0 DXVA_DetailEnhance 0 (note: not sure detailenhance makes any difference as of the latest hotfix drivers, there seems to be another key handling it). 3) WMV acceleration broken. Search for DXVA_WMV_NA, change to 0. Now a new option to allow acceleraiton appears under the control centre's video settings (maybe needs a reboot). Last edited by arfster; 07-12-07 at 11:13 AM.. |
#9 | Link |
AVS CLUB MEMBER
Diamond now has the 2600 series on there website, but am confused. What is the differences between the 4 different models.
http://www.diamondmm.com/HD2600XT.php |
#10 | Link | |
#11 | Link |
Since the 2400 (xt and pro) is crippled in video performance in their drivers a bit but the 2600 isn't, ATI themselves seem to be thinking the 2600 is more powerful.
However, from my tests this won't be needed under most circumstances, since the 2400pro's gpu copes with >50mbit fairly easily in any format, and 1080i maybe up to around 25mbit (you can see GPU usage in rivatuner). I still need to test different forms of deinterlacing though, and maybe memory bandwidth issues will bite - I've only tested up to around 45mbit 1080p, and 18mbit 1080i, both in h264 (the latter eats a lot more btw, up around 60%). However, if you use one of those fancy 2500*1600 monitors that certainly would max out the gpu pretty fast, as upscaling really hurts. Last edited by arfster; 07-10-07 at 09:16 AM.. |
#13 | Link | |
Thanks, btl. |
#14 | Link | |
AVS CLUB MEMBER
- Rich |
#15 | Link | |
Experimenting with 2400 Pro, very promising!
I had another chance to test out the card yesterday. I did a full reinstall of MCE2005/SP2 (due to earlier hw/bsod issues) and even took a chance and did the OS with the HD2400 installed. Installed MB drivers, then Sapphire driver disk, no probs. I haven't done any registry tweaks yet.
System: C2D 2x1.86ghz, Asus P5B-VM, 2GB dual channel RAM, SATA drives, HD 2400 Pro. Installed Haali media splitter, then PowerDVD. I have this all connected to my 47" LCD via a dvi to hdmi cable, I haven't tested the ati hdmi 'audio' dongle yet, but I did see the driver for it install, and I think I saw the option to redirect sound through it in PowerDVD. When I looked to see if acceleration was on, the option was greyed out/unavailable. Tested a few clips I have: The Prestige (blu ray / 1080p/AVC MPEG-4) - 0% cpu usage(!), perfect quality TombRaider (blu ray / 1080p/MPEG-2) - 50% cpu, ok but not great quality (7/10), artifacts, weird scanlines King Arthur (h.264 / 50hz / .ts) - 0% cpu, great quality, a bit soft. (seems like S*yHD stuff plays very well) More tests tonight, including some of the registry tweaks here and in the other 2400 thread, and hopefully I can test the ati hdmi sound dongle. Thanks to arfster and others for registry tweaks! p. |
#16 | Link | |
#18 | Link |
Latest testing update: with the new Vista betas. After applying all registry updates, everything is accelerated. Colour expansion no longer happens on SD, but does as soon as vertical resolution hits 720 lines, regardless of format, renderer or DXVA on/off.
It's exactly 720 too, at 718 lines it doesn't expand - you can do this in playback with ffdshow to demonstrate. Thus, a very silly bug, and surely an easy one to fix from ATI's side. Possibly they're using different internal colour spaces with HD resolutions (performance reasons?). Getting there..... Last edited by arfster; 07-10-07 at 10:52 AM.. |
#19 | Link | |
AVS CLUB MEMBER
I submitted more information to ATI. Can you PM me with a place to download the Vista Beta drivers? - Rich |
#21 | Link | |
Has anyone else got this to work in XP? |
#22 | Link |
Vista beta drivers:
https://a248.e.akamai.net/f/674/9206...625a-49540.exe By the way, if anyone's not getting mpeg2 acceleration even after the registry changes above, put this in umd/dxva: DXVA_NOHDDECODE 0 In Vista it's a string, XP I dunno, might be a dword. Setting it to 1 disables mpeg2 dxva instantly for me, back to 0 and it works. For some strange reason the drivers default to 1 if the key isn't there (which it isn't normally). Since this defaults to 1, so might some of the other dxva-disabling stuff mentioned in the previous reghack post. Rather than deleting the 3 dxva-no24fps keys, it may be better to just set them to 0. Last edited by arfster; 07-10-07 at 11:44 AM.. |
#23 | Link | |
AVS CLUB MEMBER
- Rich |
#24 | Link | |
EDIT: NM, just saw your other message about setting it to '0' p. |
#25 | Link | |
http://support.ati.com/ics/support/K...estionID=28254 |
#26 | Link | ||
AVS CLUB MEMBER
#27 | Link |
Hehe, jeez. Try from further up the tree:
http://support.ati.com/ics/support/d...asp?deptID=894 click radeon support PC on the left, find the 2400, look for the one called: "737-28254: Radeon HD 2000 series: Slow performance in main menu in the game Lost Planet" There's also one for XP users I see, seems to be the same generation as the above fix (4954x). Go to the 2400, look for the other lost planet related one. |
#28 | Link |
arfster, any word on a beta XP driver?
I've got nothing but problems now - I can't get h/w accel to work for VMR9 in XP anymore. And the funny thing is that it was working on Sunday. Then BAM! It doesn't work anymore and I get flashing green screen (and sometimes a BSOD) now when using Zoomplayer, MPC, or KMPlayer. ![]() |
#29 | Link | |
AVS CLUB MEMBER
- Rich |
#30 | Link | |
Think ..Should be : TRDenoise (dword 0) R new XP Betas add some interesting things : deinterlacing slider underscan-overscan slider improved PQ best m
__________________
HTPC - ISF- Panasonic TH-42PHD8UK Last edited by mine; 07-11-07 at 01:01 AM.. |
| Bookmarks |
| Thread Tools | |
