AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-16-07, 12:49 PM   #1   |  Link
aldo1013
New Member
KV-34xbr800 - Really bad Horizontal tilt.
Hi everyone. I just received a KV-34xbr800, which has a spectacular picture. The only problem is, the whole picture is canted slightly (about an inch) down and to the left. I've tried the Tilt Correction in settings, and I tried setting 2170D-1/NSCO in SM. Is there another place to set the horizontal tilt that I don't know of? Maybe a hardware tweak inside? I've searched for hours for a fix, with no luck. Any knowledge or suggestions (other than, "Google's your friend", etc), would be very much appreciated! Thanks.
aldo1013 is offline   Reply With Quote
Old 07-25-07, 04:20 AM   #2   |  Link
doc_chiron
Sr Video Engr
I have the same model and have made some service adjustments, but am not happy with the overscan of standard definitition shows with the display mode set to NORMAL (4:3). 4:3 shows coming in on 1080i channels are much wider. I have a DVD I made with HDTV test signals down converted to SDTV. Monoscope has 5 circles on a square grid with a big circle centered and diameter equal to screen height. It also has smaller circles in each of the four corners that a great for checking overscan. The overscan is set nicely when the display mode is 16:9 (FULL), but too much of the left and right sides are missing in NORMAL as evidenced by the missing portions of the corner circles.
Oh, yeah. I remember there is a service setting that affects rotation of the screen. I would set that to the center of range, then rotate the CRT deflection yoke clockwise until the horizontal lines are parallel to the ground. Sorry, but it has been three years since I made my adjustments and do not remember the abbreviations for the appropriate setting, sorry.
doc_chiron is offline   Reply With Quote
Old 07-25-07, 04:48 AM   #3   |  Link
aldo1013
New Member
doc-
Thanks for the reply! I'm getting off of work soon, and I will try the yoke adjustment...can I do this with the TV on or off? Is it mostly something that I'll have to eyeball myself?
Old 07-25-07, 08:17 AM   #4   |  Link
raouliii
I wouldn't recommend making yoke adjustments just yet. There's a lot that can go wrong, including electrocution.
You may believe that it is a tilt problem but it may be a combination of geometry errors that are causing your issue. A crosshatch type test pattern can be used to determine the geometry errors and quite a few service menu items can be used for correction.
__________________
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline   Reply With Quote
Old 07-27-07, 09:57 PM   #5   |  Link
aldo1013
New Member
raouliii-
Thanks! I've looked around for a good crosshatch/calibration disc , but do you have a suggestion for one? I'm pretty much looking to download one, if possible.
Old 07-28-07, 08:30 AM   #6   |  Link
raouliii
My recommendation is AVIA : Guide to Home Theater .
There are a number of jpg test patterns posted in the Sony Service Code thread but I have been unsuccessful at loading them on a memory stick and viewing them on my HS510. The memory stick reader in the early sets are notoriously picky about formatting of the files and directory structure.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10892391 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
