AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-18-07, 05:48 PM   #1   |  Link
irhxcbcziuzxs
DVE question
I have been using DVE to fix my darkness problems on my TV w/ my 360. However Since I run games in 1080i/HD , me running DVE does nothing. I switched my 360 back to non HD today, and things got brighter.
Is there a way I can adjust things correctly for HD display?
oh im hooked up via component if that makes any difference.
irhxcbcziuzxs is offline   Reply With Quote
Old 07-19-07, 02:41 AM   #2   |  Link
SurfingMatt27
A/V Enthusiast/Gamer
adjust UBOF for that input in the service menu.
that should fix it.
__________________
PSN Tag: RPGfan27
SurfingMatt27 is offline   Reply With Quote
Old 07-19-07, 07:30 AM   #3   |  Link
Wickerman1972
I have the same problem and for the longest time I couldn't adjust my overscan properly because of it. But a week or two ago I DVRed some test patterns off of HDNet and was able to use those to do my adjustments. Because my cable box can output in any resolution ( Except 1080p, of course ) I was able to adjust for all of the different resolutions. But on my 360 I can get DVDs to play only at 480i or 480p. I even bought the 360 HD-DVD player and it won't upscale either. DVE is also available on HD-DVD but I have the DVD version. I bought it first now knowing that a few weeks later I'd decide to buy the HD-DVD attachment for the 360.
I have heard that you can upscale DVDs with the 360 if you run it over VGA. Why that would be true I don't know but it's what I've heard.
Wickerman1972 is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11242509 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
