AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-20-07, 01:56 AM   #1   |  Link
iiiiiiiiii
slimfit 16:9 issue
ok im watching a dvd (widescreen), when i set the tv to 4:3 mode there are black bars at the top and bottom of the screen, everything is normal so far...
then i set the tv to 16:9 mode and the black bars are still there and they are the exact same size that they were in 4:3 mode, which means 16:9 mode only stretches the picture horizontally. Is this normal?
when i select the zoom setting, it fills the screen, but i loose picture detail. am i supposed to have to do this to fill the screen?
PLEASE HELP...
iiiiiiiiii is offline   Reply With Quote
Old 07-20-07, 02:02 AM   #2   |  Link
like.no.other.
1080p24 7.1 LPCM
Telling us what model the TV is surely will help.
__________________
There is always someone out there that gives you opinion of a product that they don't even own.
like.no.other. is offline   Reply With Quote
Old 07-20-07, 02:50 AM   #3   |  Link
iiiiiiiiii
sorry, here it is
TXT3093WH
Old 07-20-07, 03:00 AM   #4   |  Link
like.no.other.
1080p24 7.1 LPCM
It's aspect ratio. Even if you have widescreen, some movies are shot beyond 16:9. It's more
wider than 16:9 so it still have black bars on top. If you look at the image, if it doesn't look
wide stretch on 16:9 then you have no problem. Research aspect ratio to learn more.
__________________
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10214210 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
