#1 | Link |
New Member
Need some help deciding two choices
I have two used TV's I am looking at the first one interested me because of the HDMI, since I am hooking it up to a computer. KV-32HS420
My other choice is a bit older and does not have the HDMI connection KV-36XBR400 but does have DVI, which I would be using a conversion cable for anyway? what do you think? PLEASE tell me what to get! Thanks for your help or advise! Last edited by Bosstone74; 07-21-07 at 02:27 PM.. |
#2 | Link |
So these are both 4:3 sets? If so, what made you go with 4:3? Old movies? PS2?
I think if I were going with a 4:3 set I'd go with the 36" one for letterboxed movies and games. AFAIK, the conversion of HDMI to DVI is not a big deal. And if you are using your computer's output (DVI I assume) you could avoid HDMI completely. HTH and good luck! |
| Bookmarks |
| Thread Tools | |
