#1 | Link |
New Member
urgent help,sony xbr 34
ok ive been looking at tvs, mostly rear projection the sony kdf37h100 and a samsung dlp. but today in the rex tv ad they have a sony 34 xbr crt but it doesnt say the model number is it a 970 are the newer ones, its 599, it will be used for the ps3 and blu ray movies but some games only do 720p its my ubderstading that this tv doesnt do 720p, so will it look good, basicaly i need some one to talk me into buying this this tv,,thanks oh and im buying a tv tomm thats what the urgent was for thanks again for any input
#2 | Link | |
A/V Enthusiast/Gamer
__________________
PSN Tag: RPGfan27 |
#4 | Link | |
__________________
PSN Tag: RPGfan27 |
#5 | Link | |
Off-topic Instigator
If it's new then that's a great price. This TV is the best "combo" outputter you'll find. It does a great job with 4:3 or HD TV, old SD video games in 480i or p, 720p input, and 1080i input. It has a very smart video processor that upscales all inputs well. The only issue is that it wont do 1080p, which at some point will be a priority with your PS3. SO if you want it primarily as a high-end console display, it may not be the best choice out there.
#6 | Link |
"The only issue is that it wont do 1080p . . ."
My XBR 970 will accept and display a 1080p feed from my upscaling DVD player. I don't know what the TV is doing with the 1080p signal, but it does look slightly sharper than 1080i. http://www.avsforum.com/avs-vb/showthread.php?t=878396 |
#8 | Link | |
| Bookmarks |
| Thread Tools | |
