AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-28-07, 12:00 AM   #1   |  Link
ryarber
question about 7 year old sony crt
I have a KV-32FS10 that I bought about 7 years ago. It has served us well over the years and has a very crisp picture.
Does anyone have any idea of what resolution the component input on the back of the TV will accept? I remember it was supposed to be HD compatible.
ryarber is offline   Reply With Quote
Old 07-28-07, 08:41 AM   #2   |  Link
au revoir
The TV is not HD, I'm assuming, because it has FS in the model number.
So 480i over component should be what resolution you get. As far as what it can accept, probably 480p as well, but 480p will display as 480i. A 720p or 1080i signal most likely give you a blank screen.
Try it and see what happens, you won't break anything.
au revoir is offline   Reply With Quote
Old 07-28-07, 09:56 AM   #3   |  Link
RalphArch
AVS CLUB MEMBER
Clearly an HD compatible set should be able to accept either 720p or 1080i. or both.
My older RCA set clearly stated it would only accept 480i on the component inputs - although it would take HD (1080i) on the high resolution inputs.
HD compatible is meaningless if you can only feed it 480, interlaced or not.
Although from the manual http://www.docs.sony.com/release/KV32FS10.pdf there appears to only be NTSC component capability (480i although not specifically stated on page 8)
RalphArch is offline   Reply With Quote
Old 07-28-07, 08:13 PM   #4   |  Link
ryarber
I don't have a HD source to fee it other than my BD player. I was just wondering what sort of receiver/components to get for it or if I should junk the thing. It weighs a ton.
Old 09-29-07, 02:51 AM   #5   |  Link
ucliker
ryarber, i have the KV-36FS10 and was wondering the same, I will test it soon enough!
ucliker is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10321689 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
