AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-29-07, 02:33 AM   #1   |  Link
boneless6220
HD out of a 3yr old CRT
I have a Philips 34PW850H and it's HD ready. I found this page with info
http://www2.shopping.com/xPF-Philips-34PW850H
Since it can do 1080i, what happens if I feed it 1080p?
I don't have any digital inputs, HDMI, or DVI. How much resolution can I get out of component cables only?
Can it display 720p well?
boneless6220 is offline   Reply With Quote
Old 07-29-07, 04:33 AM   #2   |  Link
fugiot
960 + 360 = 420
It will not accept 1080p at all. 720p should be scaled to 1080i by the TV, but it's possible that it may not accept 720p either. You can get 1080i out of component cables.
fugiot is offline   Reply With Quote
Old 07-29-07, 08:23 AM   #3   |  Link
raouliii
This Philips 34PW850H Leaflet doesn't mention 720p or 1080p. You can pass full 1080i through component cables.
__________________
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline   Reply With Quote
Old 08-09-07, 02:30 PM   #4   |  Link
boneless6220
I found 2 sets of component inputs on the back and only one was labeled 720p/1090i. Even the instruction manual states this and doesn't specify 1080i for the other input. Are both able to go 1080i or is the unlabeled one likely lower?
Old 08-09-07, 03:41 PM   #5   |  Link
jwebb1970
Enhanced Member
Originally Posted by boneless6220
I found 2 sets of component inputs on the back and only one was labeled 720p/1080i. Even the instruction manual states this and doesn't specify 1080i for the other input. Are both able to go 1080i or is the unlabeled one likely lower?
Perhaps the dual resolution input is there to accept either res (which will be displayed @ 1080i). If that's the case, I'd use it for anything you may have diff resolutions coming from (outboard OTA tuner, maybe?), the other dedicate to a 1080i-constant source (HDDVD/BluRay player).
Or they're the same. Just have to try either res in both. But, you should be feeding it 1080i if possible, at the time.
__________________
"I'm really only an Atheist on Christmas and Easter. Rest of the year...it really doesn't matter." - Dr House
jwebb1970 is offline   Reply With Quote
Old 08-09-07, 05:20 PM   #6   |  Link
G-Bull
I would guess that only the component video input labeled 720p/1080i can accept those HD resolutions, and the other (unlabeled) component input will only accept 480i (or possibly 480p).
Component (Y-Pb-Pr) video has been around for some time, and it's not strictly used for high definition signals. I know some standard-definition TVs have component inputs as well. I would guess that your TV has one standard-definition component input and one high-definition component input.
G-Bull is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12069988 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
