AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 07-30-07, 08:10 PM   #1   |  Link
jbutle4
Help me find a tube at Best Buy!!
I have some gift cards to BB, and I am in need of a television for my bedroom in a new house. I currently have a 30" CRT HDTV that I really have enjoyed, but alas, it won't fit into the cabinet that my future wife has selected. So I now need to find something in the range of a 27" set (my 30" set, which is 35" across, won't fit by about a quarter of an inch).
I thought I had found a solution with the "Samsung Slimfit 27" Widescreen HDTV" at Best Buy, but upon further investigation, it was just mislabed as widescreen and is actually 4:3.
I would definitely prefer HD if the price is right, but if it comes down to a quality SD set and an Insignia HD set, I'd probably go with the SD.
I have about $380 in gift cards, and would be willing to put in $100 (give or take) more if need be.
Any suggestions would be greatly appreciated!
jbutle4 is offline   Reply With Quote
Old 07-30-07, 10:57 PM   #2   |  Link
WJonathan
Off-topic Instigator
Well, you wont find any widescreen 27" HDTVs in your price range. The Samsung Slimfit is not a bad choice, but they have a lot of geometry problems with them, which could be trouble if you're watching HD content in a letterbox format.
WJonathan is offline   Reply With Quote
Old 07-31-07, 12:01 AM   #3   |  Link
jbutle4
Well, do you think the Samsung would be an unwise purchase? To be perfectly honest, I'll proabably just be hooking it up to an over the air antenna for now. I just didn't want to waste $200-$250 on a crappy off brand tv, when for a little more, there may be something better.
Old 07-31-07, 08:30 AM   #4   |  Link
UWisconsin97
Classified Rating: 100% (1)
It really depends on what's available in your area. The LAST time I was at CC, they had a few (less than 5) XBR970's available, and the BB across the street had only the display for sale. Meanwhile I've read a few posts where the local retail stores are completely sold out of tubes, and only stock LCD/plasma.
The Samsung isn't a bad choice either, and I really enjoyed my 30" HD-CRT Insignia.
Do you plan on watching HD programming, HD movies, any gaming? etc. etc.
UWisconsin97 is offline   Reply With Quote
Old 07-31-07, 12:51 PM   #5   |  Link
BLiTzNicK
I would not buy the Samsung. My 27" HD Slimfit has been in the shop for going on 9 weeks, and appears to be unfixable, but Samsung is dragging their feet on replacing it. Their customer service is terrible.
BLiTzNicK is offline   Reply With Quote
Old 07-31-07, 02:42 PM   #6   |  Link
jbutle4
Probably mostly SD and a little bit of over the air HD. No HD movies or gaming.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10719204 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
