#1 | Link |
No funny shtuff
XA2 vs A35 repository
...premature, no doubt, to create a unique thread, but I know that I'm not alone in being very interested in the top of the G3 line (at least, so far that's been released.)
What we know so far about the A35: - THIS is what it looks like: - Preliminary Spec sheet (Via Value Electronics): Dimensions: 16.9" x 2.34" x 13.58" Weight: 8lbs HDMI 1.3a Ethernet (of course) Extension Terminal (USB port(s)?) Video: As expected, up to 1080p, including support for 24p. Audio: "High Bit Rate “HBR” Audio decode by-pass for decoding any lossless audio in your receiver" 5.1 Analogue, 7.1 via HDMI All Dolby formats supported NO DTS-HD MA (ie., DTS-Lossless) or DTS-HD, only core DTS. I assume this means we'll get the 1.5mb/s extracted via analogue outs, HDMI, and/or Toslink/Coax. ***************** - MSRP of $499 (vs. $700+, $999 in Canada for the XA2) - 24p out of the box (vs. promised upgrade in the future) - Deep Colour (hinted at with the XA2 upgrades, hard to see utility for HD DVD playback given the spec doesn't handle above 8bit) - Sleeker chasis (pic of one of the models available on the link above, looks slightly "curvier" than the XA2, and downright svelte compared to my A1) - 5.1 analogue (no 7.1 a la Panny BD, alas) - 7.1 "audiophile mode" passthrough (again, hinted at with FW upgrades for XA2 but not yet available) - CE link (to control other devices via HDMI - again, suggestions are that the G2 models will be able to do this, but nothing yet confirmed) What we -don't- yet know about the A35: - Will it do HDMI>DVI with proper colour space? (A1 does not, unsure about XA2) - Will it cooperate with an HDMI switch properly, without -ever- getting HDMI errors and refusing to play? (My A1 does not, unsure about XA2) - Is this the chip inside? - Will it be joined by an XA3 big brother that has even better specs? UPDATE: Answer is, uh, "maybe..." (LINK) ![]() - Does it have the REON or equivalent level of video processing for SD content? [update October2k7: The ABT chip has results that some are finding decent for SD DVD, but lacking in the advance colour and PQ setting modes that the REON has) - Will it decode DTS-Lossless (aka, Master HD) internally and output through Analogue outs? - How will the "passthrough" be implemented, given the necessity of current players to mix certain sounds like PIP audio, menu sounds, etc.? Will the implementation do what we want, namely, raw Lossless bitstream from the selected audio track set to the AVR for processing? [update October 2k7: aparently this is working well, an advantage of the yet-to-be implemented XA2 outboard decoding option] - Is it HDMI 1.3? Deep colour would suggest that it needs to be, if I understand what's going on with HDMI correctly, but there's nothing clear in the release. Does it matter for everyday HD DVD viewing? [no, save for some possibilities with menus - Amir discusses this in insider thread] - Will it finally be the rock solid, never ever have problems with discs player that we all really want? ![]() - Could they throw in DVD-Audio support for fun? (heck, it's already doing MLP...) [no] - Does it suffer from CUE? - Does it avoid the lipsync issues that the XA2 seems to have (both with digital and/or analogue) for some users? [update October2k7 - more testing required, but early results are postive] ****************** I think there will be tremendous interest in this model in particular - in USD it's pretty close to what I paid for my G1 lower-end unit, and if performance is better and more stable than the XA2, without sacrificing anything of note, it may be a winner for many, many of us. Thoughts? I'd be happy to edit any of the information above to keep it up to date as information rolls in. If I've made any mistakes or left things off, let me know that as well... I'll be very pleased if this proves to be a solution that's more streamlined, easier to update from a FW perspective (one chip solution?), and sees an end to the quirks that we've almost all experiences with either G1 or G2 models. I remain cautiously optimistic... ![]()
__________________
Read Filmfest.ca! Last edited by sharkshark; 10-02-07 at 08:56 PM.. |
#2 | Link |
Great thread.... I hope to see some more announcements made at CEDIA on whether or not this player will include a Reon processor, or if that we will have to wait for a true successor to the XA2.
__________________
forum tennis, look right.........................................forum tennis, look left
#3 | Link |
I too am interested in the A35. I would love to be able to get rid of the A1 and move the XA1 into the bedroom. Hopefully it will be a true successor to the XA2.
__________________
2009 - New uniforms + New HC = A Return to Dominance. The 49ers will win the NFC West. |
#5 | Link | ||
CS Junkey = Beta 5.1
And is not an important part for HD DVD 1080p viewing? Quote:
__________________
Blu ray is the best Blah, blah, blah. |
#6 | Link | |
__________________
#8 | Link |
No funny shtuff
FWIW, if you have HDMI audio there's not a heck of a lot that seems to distinguish the two, I grant. However, for many of us Analogue output is a MUST have, and one reason many are still using G1 units. So, yeah, it's important.
__________________
Read Filmfest.ca! |
#10 | Link | |
I really don't like to speculate but I THINK this chip is in the new Gen 3 players. This is a case of one chip replacing two to save on manufacturers cost.
http://www.cirrus.com/en/press/releases/P524.html
__________________
Charter Member Of Early Adopters Anonymous |
#12 | Link |
No funny shtuff
...if anybody has definitive info about the REON and HD processing, let me know... I listed it as SD important above as, without receiving the $200, that's what I thought. I've been wrong...
![]() Lee, good find, and my assumption as well - we're finally seeing one-chip solutions that will hopefully provide even better stability due to their customization for the process of HD DVD playback. Time will tell....
__________________
Read Filmfest.ca! |
#13 | Link | |
http://edageek.com/2007/01/02/toshib...deo-processor/ |
#14 | Link |
No funny shtuff
...yeah, if I undestand it correctly, the REON is used for upsaling, and, potentially, for outputting HD DVD via component. For HDMI HD video it's not used. I don't want this to get off topic, but it would go a long way to whether or not it's actually a big deal that the REON is available or not. As above, some don't care about Analogue outs, so they can get away with the other model. Some may worry less about "losing" the REON in favour of a half-the-price player that's even more stable and does just as good a job with HD content...
__________________
Read Filmfest.ca! |
#15 | Link | |
Edit, you never said it was for video, and I agree one chip for all audio is better. My bad Sorry to get of topic as well. Last edited by dobieck1; 08-06-07 at 01:26 PM.. |
#16 | Link | |
HD addict
AVS GOLD CLUB MEMBER
__________________
HD DVD titles: 379 BD titles: 356 Last HD DVD: P2: A New Level Of Terror Last BD: Baraka LED DLP |
#18 | Link |
Someone help me out here . . .
To my understanding - there are three makers of UP DVD chips (did I already blow it?) 1. Sirrus Logic 2. Anchor Bay 3. Farjouuuuuu - whatever We know the Samsung 2400 and the 5000 are using the SL Reon chip. We do not know (or at least I don't know) what UP DVD chip the P1400 will have.) Anyone know which chip is in the A2?
__________________
#19 | Link |
No funny shtuff
...isnt' Anchor Bay a DVD distribution company?
__________________
Read Filmfest.ca! |
#20 | Link | |
No funny shtuff
It remains far too early to know what chip will be inside the G3 units, and whether or not the new chip (if not a REON) will do a similar level of PQ. In the mean time, here's hoping this thread can remain a civil place for the discussion of these specific models when new info is presented.
__________________
Read Filmfest.ca! |
#21 | Link | |
The Reon is made by Silicon Optix. It is in the XA2. Their high-end chip is the Realta. ABT makes the chip in the A20. They also make the chips that go on the high-end DVDO scalers. Not sure about the A2. |
#22 | Link | |
Here is the Anchor Bay Tech chip I believe you are discussing for the A20: ABT-1018: http://www.9web.co.uk/abt/downloads/..._PB_011606.pdf
__________________
#23 | Link |
Before I saw this thread I was thinking about the A35 and how I might use it. I've got my old HD-A1 in our guest room hooked up to a Samsung CRT direct view 30" 1080i TV. That's just fine. My XA2 is in my theater hooked up to the IN76. But I'm limited to using coax digital out for audio because of the lipsync problems with that unit.
So I'm thinking of moving my XA2 into the bedroom paired with a new 1080p LCD and, perhaps, getting the new A35 for the theater. That will only work if 1.) the video performance of the new player is as good as the XA2 for both DVD and HD DVD. and 2.) Tosh finally solves the lipsync problem on the analog outs. With those two prerequisites in place, I'm very interested in this player. BTW, this thread was a good idea.
__________________
Hank Brown "Being at the right place at the right time is purely a function of being at the right place a lot." JPEG's of my Home Theater. |
#24 | Link |
No funny shtuff
...it'll be next to impossible to keep the announcement thread on track, so let's all try and keep this one up to date over the next few weeks/months.
Are there any other key questions that any of you may have for this upcoming unit that I should add to the top? Once we have answers to these questions I'll include them above so that they'll be located in one place. Hopefully we can thus keep at least this one thread on track... ![]()
__________________
Read Filmfest.ca! |
#26 | Link |
No funny shtuff
...probably as good a guess as any - FWIW, it's question number two above (pending a confirmed answer)
__________________
Read Filmfest.ca! |
#27 | Link |
Sharkshark -
This is just a fine point ... but I think the lipsync issues on various HD DVD players manifest themselves on all audio output ports ... not just the analogs. I know I've posted myself that I have a problem with the lipsync issues ON THE ANALOG OUTS. But here's the explanation: The lipsync issues on the digital outs (coax and toslink) can be completely remedied using a Felston digital audio delay. I have one. And I bought it because I needed it badly. But I am not aware of any way to delay analog audio out. Hence, the lipsync issues with analog are simply not fixable. fine point ... but, I thought, worth mentioning ... since I don't want someone to read this and come away thinking they can have good lipsync using coax/toslink digital audio out. I think they'd still have a problem.
__________________
#28 | Link | |
Take it for what its worth. He's been dead nuts on with every other thing he's told me so we will see. |
#29 | Link |
No funny shtuff
...cool, added to above. We all take any of this info with a grain of salt, of course. I for one -assume- that the XA3 is coming, or at least something to capture the high end market. The question, then, is what this model has compared to the -previous- model champion. We'll add the comparison to the XA3 (or equiv.) when/if it gets announced.
Edited lipsync issues comment above. As there contines to be tonnes of "does it do XXX?" repeated in the announcement thread, I may have missed some key questions. Sorry to repeat, but let me know as this develops, as above, and I'll do my best to keep what we know up to date.
__________________
Read Filmfest.ca! |
| Bookmarks |
| Thread Tools | |
