#1 | Link |
New Member
Lookin for default Sony Configuration
hello
i want to sell my tv and ive changed a lot of setting in my service Menu that I think some people will not like Is there a way to restore default or a Place where default commands are written??? I have a.... SONY Serial Nu. : C401660 Model : KV-29FV300 AC 220V HZ 210 Any help would be much aprettiated |
#4 | Link |
As far as I know there is no way to go back to a "default" setting once you've changed and saved things. That's why people are always recommending that you write down any changes you make so that you can manually set things back to the way they had been if you want or need to.
#8 | Link |
Yea man. Even if you have the service manual you will most likely never get the TV settings back to how they originally came from the factory. I noticed after writing down my default settings for my xbr970 when comparing to the service manual that some settings were off by a few numbers. I guess the service manual is more of the default ball park numbers, then when they do a final adjustment before it leaves the factory they change some things up to fix the "out of whack" TV's to compensate for any unique problems and ship them off to us. Like my set they didn't even have the whole picture inside the raster. Even after adjusting the blanking settings the picture was just cut off at like 5% overscan on the top and bottom. They set my mid 2 settings totally off.
| Bookmarks |
| Thread Tools | |
