AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 08-09-07, 11:41 PM   #1   |  Link
elrechazao
XBR 970 + Xbox 360 = bad
I get serious overscan issues on my 360. It's inputting through the component cables.
Essentially, the left side of the screen is cut off by about an inch to two inches in most games.
In movies and tv viewing I can't see noticeable overscan, but then its hard to tell since you don't know as easily in those things that there is a part of the picture cut off.
Any help on this? I'm stumped, and never done any calibrating of anything, so I have no idea where to start really, or if this is even fixable.
elrechazao is offline   Reply With Quote
Old 08-09-07, 11:49 PM   #2   |  Link
elrechazao
http://www.avsforum.com/avs-vb/showt...x+360+overscan
just found this, had to upgrade my search skills :0
will post if I have any issues in this thread I guess, thanks still to anyone who has comments about their success or failure with this method, thanks.
Old 08-10-07, 01:34 PM   #3   |  Link
Wickerman1972
Yeah, 970s tend to have pretty dramatic overscan at the factory settings. The only way to fix it is to go into the service menu and adjust it. This is easier said then done though as there are two different sets of menus to get it truly right. The MID menus are resolution specific and you can mess up your PQ if you don't get it right. Then there's the set of menus that start with a 2 ( I forget offhand exactly what it's called but I think it's 2-10D-something or the other. ) and the settings in there affect all resolutions. If it were just one set of menus to adjust it doing so would be easy. But having two sets of them makes it more tricky than I initially thought it would be.
Wickerman1972 is offline   Reply With Quote
Old 08-10-07, 10:38 PM   #4   |  Link
elrechazao
can I adjust the settings for a single video input (video 3, my component input) only? Or does a settings adjustment adjust over the entire TV?
Old 08-13-07, 10:44 PM   #5   |  Link
scarekrow
New Member
i have scan problems with the ps3 but its shrunk on the left and right sides by about an inch, this is with ps2 games, the ps3 games played seems to be fine and no overscans i can tell with a 360 game, movies are fine, tv is fine, its only the ps2 games played with the ps3..weird.
scarekrow is offline   Reply With Quote
Old 08-14-07, 12:54 AM   #6   |  Link
STEVE050
I had to adjust this same prob in a customer's home. It's width was about 1" over the right side and a bit too tall. All of this was gauging an XBOX360 NBA2K7 game compared with the pix it produced on an LCD flat panel. It was also OK on HDcable and DVD 480p.
He couldn't be satisfied and he kept poiting out what doesn't look right while I was trying to adjust it. It even looked right on my test crosshatch generator.
Anyways, I ended up reseting all adjustments to factory recommended default, and then just minor tweaks after that. He was still not totally satisfied, but what did he expect comparing the geometry of a CRT to a flat panel.
There seems to be a difference in the sync signals from HD game boxes compared to TV boxes. Seems the factory doesn't set them up for these game systems.
STEVE050 is offline   Reply With Quote
Old 08-14-07, 01:17 PM   #7   |  Link
WJonathan
Off-topic Instigator
[quote=STEVE050...There seems to be a difference in the sync signals from HD game boxes compared to TV boxes. Seems the factory doesn't set them up for these game systems.[/QUOTE]
Hmmm...that must be the key to so many complaints over the 360/PS3 being offcenter and overscanned on many CRT models. Thanks for that summary!
WJonathan is offline   Reply With Quote
Old 08-31-07, 03:48 AM   #8   |  Link
hyghwayman
HDTV/7.1SS Gamin NUT
Lightbulb
I have my 360 Elite hooked up to my XBR970 via HDMI and have issues with overscan too.
these are screen shots from the same Halo3 : E3 2007 Trailer. You can see a difference in the two. Top is on my TV bottom is on my HP LCD, more picture on bottom pic. ( not too good with fee hand lines, but figure i'm loosing up to an inch on both sides)
I guess I will be calling out the EliteTechnicians ASAP to have this fixed!
2yr. manf. warranty and 5yr. store warranty! Both say do to size and weight of this beast, I get in home service.
hyghwayman
__________________
Helping others hear (my) TRUTH!
My XboxLive GT - hyghwayman
Halo® 3 Beta Tester
COD® 4 Beta Tester
hyghwayman is offline   Reply With Quote
Old 09-05-07, 11:39 AM   #9   |  Link
borland502
hyghwayman
I hope that works. My PS3 cuts off the titles on fighting games like Tekken and Puzzle Fighter. Oh it'll do it to others, but it kind of slaps you in the fact when text is cut off. Occasionally, the bottom and top text is sliced off to due to this problem.
borland502 is offline   Reply With Quote
Old 09-13-07, 08:55 AM   #10   |  Link
hyghwayman
Got the pros to come out...
I have an Auth. Sony Serv. Tech coming out on Friday @ 10am to look/fix this and my geomentry issues under the 2yr. warranty.
hyghwayman
__________________
Halo® 3 Beta Tester
COD® 4 Beta Tester
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.14561892 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
