AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Direct View (single tube) CRT Displays
Forum Jump
Old 08-10-07, 09:09 PM   #1   |  Link
ickysmits
Need help choosing between Tosh & Philips HDTV...
...because it's getting very hard to find a decent CRT TV - there are few options. I found a 34" Toshiba 34HF85 on Craigslist and a 30" Philips 30PW9110D/37B refurb on their outlet site. They're both about the same price - but I can't compare the specs very well because I'm not used to the way they name things. I read through the forums, but am overloaded with the various issues people describe.
I should not that I only have analog cable and want a CRT TV for picture quality over LCD. HDTV will be good for DVD's and broadcast and, if I but an external HDTV tuner for $50 on eBay, the Toshiba will be the same price as the Philips.
Philips pro's:
-90 day warranty
-PIP
-NTSC, ATSC, QAM Tuner built-in
-Digital sound?
Philips con's:
-only 30" screen
-refurb, maybe a cheap TV when it was on the market?
Toshiba pro's:
-34" screen
-maybe it was a high-end TV a few years ago (1k+)
Toshiba con's:
-used, no warranty
-only analog tuner
-no digital sound
-made by Orion
Below are the manufacturer specs for each TV - thanks in advance for any advise.
30" Philips 30PW9110D/37B - refurbished:
Picture/Display
• Aspect ratio: 16:9
• Visible screen diagonal (inch): 30 inch
• Display screen type: Real Flat picture tube
• Picture enhancement: Progressive Scan, Scavem,
2D Combfilter, Active Control + Light sensor,
3:2 pull-down, AutoPicture (5 modes), Black
stretch, Blue stretch, Color Transient
Improvement, Dynamic Noise Reduction, Green
enhancement, Luminance Transient Improver,
Tint, Widescreen Plus
Sound
• Output power (RMS): 2 x 10W
• Sound Enhancement: Auto Volume Leveller, AutoSound (4 modes), Incredible Surround
• Sound System: AC-3 Dolby Digital Decoding, Virtual Dolby Surround Convenience
• Ease of Installation: Auto Volume Leveler, Autostore
• Ease of Use: Easy toggle Dig/Analog modes, DVD, TV
• Teletext: Closed Captioning Full Text
• Picture in Picture: 1 tuner PIP, Double window
• Screen Format Adjustments: 6 Widescreen Tuner/Reception/Transmission
• TV system: NTSC, ATSC
• Cable: Unscrambled Digital Cable -QAM
• Video Playback: NTSC
• Aerial Input: 75 ohm F-type Antenna Connectivity
• AV 1: CVBS in, CVI
• AV 2: CVBS, S-Video
• AV 3: HDMI
• AV 4: YPbPr
• Audio Output - Digital: AC3 over S/PDIF (Optical)
• Front / Side connections: CVBS in, Headphone out, S-video in
34" Toshiba 34HF85 - used on Craig's List:
-16:9 FST PURE® Flat Picture Tube Wide Band Video Amplifier
-Invar Shadow Mask
-DFine™ (High-Speed Velocity Scan Modulation
-CrystalScan HDSC™ (all time 1080i)
-CableClear® DNR+
-3D Y/C (4MB, 10-bit) Digital Comb Filter
-Color Temperature Control (Warm/Medium/Cool)
-Black Level Expander
-Movie & Sports Modes
-TheaterWide® Modes (5 - Standard, Full, TW1, TW2, TW3)
-Cinema Mode (Film/Video)
-Tilt Control
-MTS Stereo/SAP with dbx®
-BBE® Sound
-StableSound®
-Audio Wattage (20 Watts total)
-RF Input
-Rear A/V Inputs 2
-Rear S-Video Inputs 2
-ColorStream® HD Component Video Inputs (Y, Pb, Pr) 2
-Front Panel Inputs A/V/S
-HDMI™ Digital A/V Input X
ickysmits is online now   Reply With Quote
Old 08-10-07, 09:25 PM   #2   |  Link
MechanicalMan
There is no way that I would buy something from Philips outlet. Certainly not a TV. You might want to look at the experiences that others have had with Philips outlet before you make your decision.
MechanicalMan is offline   Reply With Quote
Old 08-10-07, 10:46 PM   #3   |  Link
ickysmits
I think you may be right – I just visited the guy I trust at Best Buy (very knowledgeable and helpful) and was told to skip the Philips.
He said to look for a Sony XBR HDTV first. If I don't have luck then buy the Samsung at BB anf get the extended warranty.
Any thoughts if that's sound advice?
Old 08-11-07, 01:00 PM   #4   |  Link
fugiot
960 + 360 = 420
I'd look for a Sony. If you can't find one, get the Toshiba and an Avia calibration DVD and tune it up a bit. You'll be satisfied.
fugiot is offline   Reply With Quote
Old 08-11-07, 03:05 PM   #5   |  Link
WJonathan
Off-topic Instigator
The problem with the online outlets is that a large majority of TVs they sell are unsatisfied returns, and the "refurbishment" process is often just powering them on. Read the thread for that Philps model here; those sets had beautiful picture quality but really poor quality digital tuners that resulted in ghosting. Owners say that hooking up to a good quality digital set top box cures the ghosting.
WJonathan is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10170889 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
