#1 | Link |
New Member
Toshiba service mode codes
I have a service manual for my CN27G95 color TV. I can get into the service mode and design mode alright, but the manual doesn't go into any detail on what most of the codes do. I've recorded all the current settings, so I'm not too worried about screwing things up.
It also doesn't appear possible to make any convergence adjustments, either by yoke magnets or via service menu (pressing '7' in service mode, as on many Toshiba TV's, does nothing). Am I really stuck with less than perfect alignment? |
#3 | Link |
fugiot,
How old is that model? I can't find it in last 3-4 years. It doesn't start with 'CN', does it? If it is no digital video conversion internally, then focus, screen, purity, and static/ dynamic convergence are all done mechanically in the rear. Some old CRTs have bad edge focus that can't be adjusted --- needs new CRT. Any luck? |
#4 | Link | |
Granted, it was a low-end model, but there was not even a way to rotate the screen, either in the user menu or in the service menu. I found that to be pretty unbelievable, and returned the set the same day I bought it. So if these TV's don't even have tilt adjustment, you can pretty much forget about color convergence, I would think. |
#7 | Link | |
Toshiba 37LX96 LCD
Press mute two times. Then press the menu button at the front of the TV for about three seconds. |
#8 | Link | |
Toshiba 37LX96 LCD
| Bookmarks |
| Thread Tools | |
