#1 | Link |
Please excuse the overly dramatic topic title but I am desperate for some help on this subject and thought this might generate some interest...
Background: I use AnyDVD HD to backup my HD-DVD and Bluray discs onto a PC in the office, I then copy these files over to my HTPC via a gigabit network to my home. So my HTPC doesn't have any HD disk spinners attached. HTPC Specs 2Gb Ram Core2Duo E4400 Asus 8500GT Creative X-Fi (8 x analogue out to Rotel Audio Processor) I have tried various bits of software including Nero7 Premium, WinDVD (neither of which actually work on my system) and have settled with the somewhat flawed PowerDVD Ultra. I noticed the problem a while back after testing various HD disks and swicthing between DD+ and LPCM or DD TrueHD. There is no audiable difference in sound quality; maybe a slight volume change and if I am really straining my ears a tine weenie 5% improvement but that is it. Now I know DD+ at 1.5mbs is going to sound good but surely an 8mbs LPCM track is going to sound a lot better? Not to my ears at least... I decided to contact Cyberlink, initially to see if I had some Codec issue but it turns out that my ears were not decieving me because PowerDVD DOWNSAMPLES the uncompressed audio before sending it to your sound card driver! So all this expense building a gorgeous HTPC has been for nothing, as I still cannot get uncompressed audio ![]() Can anyone tell me if there IS a way to get uncompressed audio with an HTPC? Thanks, Adam PS. Below is the transcript between myself and cyberlink, just for your info: Quote:
#2 | Link |
This has been suspected for awhile but never confirmed in this way, that I'm aware. However, using some of the alternative solutions (ahem... see sarah99's threads in this forum) you should be able to get LPCM at least to work at full bitrate/frequency. LPCM doesn't need any special decoders like DTS/TrueHD do, so you're not at the mercy of Cyberlink's compliance to the need for PAVP.
But still, not wonderful news. Though at least this gives hope that HDMI ADD2 cards will be allowed to transmit 8-channel LPCM sound in PowerDVD/WinDVD (albeit with the same 48kHz/16 bit restriction). Was wondering how they were getting around the PAVP requirement on the current analog sound codecs....
__________________
I do not speak officially in any sense for Intel Corp., Technology Manufacturing Group but I do work there. |
#3 | Link |
Thanks for the reply.
I have read some of Sarah99's posts but from what I gather she had no success with HD audio. I had wondered if Cyberlink were downsampling LPCM as well but it wasn't exactly clear in their replies. I have briefly tinkered with Graphedit and Filmerit to try out different audio decoder/filters but I am flailing around in the dark really. I may pursue the LPCM route as most of my disks have LPCM as well as DD TrueHD and it is worth some time tinkering. Can you suggest which audio decoder/filter I should try to get this to work? Adam |
#6 | Link |
So I am guessing that AnyDVD HD running in the background would have no affect on the downsampling of PowerDVD HD because this is not an HDCP issue but a hard-coded function of the software...correct?
In that case: Calling all software reverse engineers - remove this crappy "function" of the software. Even if there was some solution to remove the downsampling, how the hell would I get the digital signal to the receiver? There are no HDMI sound cards available. What a joke. Until this issue is addressed, HTPCs are little more than a novelty for HD movie use. |
#7 | Link | |
Unfortunately I am not an expert in this regard but hopefully someone with more idea will come along.... Adam |
#9 | Link |
I don't honestly know but my gut feeling is that it would be downsampled for any connection method, as LPCM would be passed to the sound card driver before the sound card makes any 'decision' on whether it is output via analogue or HDMI.
As bitstream cannot be passed unless the original disk allows it, that is not an option either. Adam |
#10 | Link | |
Of The 7th Dimension
I use PowerDVD Ultra and notice a definite improvement when using TrueHD. I use an X-Fi via analog.
Audio formats supported by PowerDVD Ultra: # DTS-HD # Dolby Pro Logic IIx # DTS-ES Discrete # Dolby Virtual Speaker # DTS 96/24 # Dolby Headphone # DTS Neo:6 # MLP Lossless # DTS 5.1 # LPCM audio support # Dolby Digital Plus # MP3 # Dolby TrueHD (5.1) # WAV # Dolby Digital (5.1) # AAC decoding # Dolby Digital EX # DVD-Audio High-Definition Audio Technologies * Dolby TrueHD: Mandatory audio for all HD DVD players and optional for Blu-ray Discs. TrueHD delivers lossless, source-master-quality sound as multi-channel audio soundtracks to a playback system. TrueHD is compatible with older A/V players through HDMI. * Dolby Digital Plus: Dolby's next-generation Dolby Digital technology, offers multi channel sound with discrete channel output. Channel and program extensions can carry multi-channel audio programs and support multiple programs in a single encoded bitstream. * DTS-HD: With twice the audio performance of standard DVDs, this is mandatory audio technology for both Blu-ray Discs and HD DVDs. Works with new format standards and older, existing home theater systems. * DVD-Audio: Enjoy rich sound offered by a 5.1 channel audio experience. http://www.powerdvd-ultra.com-http.com/audio.html
__________________
"Without struggle there can be no progress." Last edited by MidnightWatcher; 08-19-07 at 06:24 PM.. |
#11 | Link | |
![]() What discs do you notice it on as I would like to try and see for myself? I have spent the most time comparing the tracks on Pirates, Dead Man's Chest as it has the highest bitrate uncompressed audio I have come across so far, 7.2mbs or something like that. Thanks. Adam |
#12 | Link | |
Adam |
#13 | Link | |
__________________
"Without struggle there can be no progress." |
#14 | Link |
I have Matrix knocking about somewhere so will give it and see if I can tell the difference but it's late now and I'm off to bed
![]() BTW what is your audio kit, maybe mine isn't up to the job... ?Thanks. Adam EDIT: Can you recommend a good scene in Matrix to try a comparison? Last edited by AngelEyes; 08-19-07 at 06:42 PM.. |
#22 | Link |
The only HD DVD with 448 Kbps audio that I know of off hand is Planet Earth. Both the Blu-ray and HD DVD of Planet Earth are 448 Kbps. HD DVD is normally either 640 Kbps or 1.5 Mbps DD+, and TrueHD is often much higher.
__________________
"Without struggle there can be no progress." Last edited by MidnightWatcher; 08-19-07 at 09:17 PM.. |
#24 | Link |
AVS GOLD CLUB MEMBER
I corrected it, and look at this, lower right corner 48k/24bit, so we're loosing 8 bits?http://www.dts.com/dts-hd/dts-encore-audio.php
#30 | Link | |
Adam |
| Bookmarks |
| Thread Tools | |
