AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Blu-ray & HD DVD Areas > Blu-ray Players
Forum Jump
Old 09-01-07, 06:02 AM   #1   |  Link
nonametofame
Arrow Samsung BDP1400 Disussion Thread
Just picked up a new unit at Best Buy, and it appeared to be the only one they had on hand. Just had the chance to fiddle around with the player a bit and here are some quick notes.
HDMI audio bitstream - Sadly, I was not able to get the elusive DTS-MA logo to switch on on my Onkyo 605 receiver. Out of the box, and with the digital output set to bitstream, I only got regular ol DTS. Not sure if a firmware upgrade will ever allow a true pass through on the audio. However, it was interesting when I selected PCM as the digital output. I checked the display on the onkyo and it said PCM 7.1. I don't think it really means anything as the lossless DTS track on X-Men 3 is only 6.1.
Boot up and load times - About 10 + seconds or so from powering on to ejecting. Loading is a different story. Some of my discs got stuck during loading (Final Fantasy: SW) or just took awhile (Weeds S2 Disc 2). I'm comparing this to my PS3 which boots and loads almost instantly. The standalones still can't touch the PS3 in that regard. It was also strange that the main menu wouldn't even show the options on the FF disc. There was the background animation, but no way to select any options. I'm thinking this might be a java issue. Hopefully a FW upgrade will fix this.
Picture and audio quality - This is where the player seems to shine. With the 1080p and 24fps options on, I got a gorgeous picture via HDMI on my Samsung HLT6756 1080p set. From my first impression, it looked a tad smoother than the PS3's PQ, which was already great. I need to test some more discs, but the PQ is quite outstanding on this player. Audio also sounded nice although I haven't had a chance to do any extensive comparisons. Black Hawk Down and FF sounded just fine.
nonametofame is offline   Reply With Quote
Old 09-01-07, 06:15 AM   #2   |  Link
Supermans
I tested this vs the PS3 at 24fps and didn't notice any difference at all on a few setups. It is possible that your HDMI cable is the difference between the two you're testing. I've already had a friend who was getting a light amount of snow which he confused with grain until I switched the cable out for him. Check to see if black level is off as well since that makes a difference.. I still prefer the PS3 over this standalone.
Supermans is offline   Reply With Quote
Old 09-01-07, 06:28 AM   #3   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
So no Dolby TrueHD lighting up on the 605 either? I thought they said ALL three units would do it...
__________________
427 Blu ray titles!
Latest Fav- Monsters Inc.
For my unbiased Reviews, Screen shots and more go to: http joerodhometheater.com/about.html
joerod is offline   Reply With Quote
Old 09-01-07, 07:18 AM   #4   |  Link
ryoohki
I tought only the 2400 would allow passing Bitstream signal, from the press release i mean..
__________________
89+ Blu-ray Disc ;)
ryoohki is offline   Reply With Quote
Old 09-01-07, 07:27 AM   #5   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
Maybe so then. I actually am planning on trying out a 2400 soon so I hope you are right.
__________________
427 Blu ray titles!
Old 09-01-07, 08:38 AM   #6   |  Link
ryoohki
Well the spec sheet mention Bitstream and Internal decoding of TrueHD, DTS HD HR and MA (FW Update), but i'am not samsung so who knows
__________________
89+ Blu-ray Disc ;)
Old 09-01-07, 01:34 PM   #7   |  Link
Richard Paul
Would anyone be willing to open one of these up and take a picture of the decoder chip that is used in it? This was done previously with the Samsung BD-P1200 and proved very informative since it tells us exactly which decoder chip is used in the player.
Richard Paul is offline   Reply With Quote
Old 09-01-07, 02:16 PM   #8   |  Link
Dan Hitchman
5.1 Music Addict
Many players, including the PS3, will duplicate the mono discrete back channel on 6.1 tracks to create 7.1 PCM. They may think some processors won't know what to do with a 6.1 signal and dual back speakers... maybe there is a compatibility thing with PCM? Who knows.
__________________
Studios, just say "NO" to DNR and EE!!!
Say "YES" to full quality 1920x1080p high definition video and 8 channel, 24/96 (or greater) multichannel audio (full lossless or uncompressed PCM)!!!
Dan Hitchman is offline   Reply With Quote
Old 09-01-07, 08:21 PM   #9   |  Link
phansson
Classified Rating: 100% (2)
Has anyone confirmed if this player willl output bitstream? Is it profile 1.1?
__________________
My home theater
phansson is offline   Reply With Quote
Old 09-01-07, 08:41 PM   #10   |  Link
whsbuss
Someone needs to try Ghost Rider..... TrueHD.
whsbuss is offline   Reply With Quote
Old 09-01-07, 08:55 PM   #11   |  Link
phansson
Nonametofame, are you sure you had the Samsung unit setup as bitstream?? I have a new Integra 9.8 that needs a bitstream source. I looked through the manual and it said nothing about bitstream of advanced codecs but reports on the net said it will pass them.
Also, does this unit pass 7.1? I know that the 1000 and 1200 will not pass anything higher than 5.1, even via hdmi.
__________________
My home theater
Old 09-01-07, 09:26 PM   #12   |  Link
TheHDMan
I tought I taw a puttie cat!...
TheHDMan is offline   Reply With Quote
Old 09-01-07, 11:12 PM   #13   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
I will have a 1400 in hand here shortly and I will use it with an Onkyo 905 so I should be able to help shed some light on the situation. No pun intended!
__________________
427 Blu ray titles!
Old 09-02-07, 02:48 AM   #14   |  Link
TrevorS
Classified Rating: 100% (7)
I looked on Samsung's website and didn't spot DTS-HD MA mentioned anywhere, even as a firmware update. What spec sheet are you referring to?
TrevorS is offline   Reply With Quote
Old 09-02-07, 08:32 AM   #15   |  Link
VFR
1400 spec
2400 spec
VFR is offline   Reply With Quote
Old 09-02-07, 10:17 AM   #16   |  Link
RUR
Innocent Bystander
RUR's Avatar
AVS CLUB MEMBER
Great idea and verification of the amount of RAM would be nice, too (I didn't photograph it, but the 1200 has 256K). Can an owner verify that 24p lip-synch issues and proper 4:3 aspect ratio display have also been resolved?
RUR is offline   Reply With Quote
Old 09-02-07, 02:36 PM   #17   |  Link
TrevorS
Originally Posted by VFR View Post
The 2400 data sheet shows: Dolby® Digital, Dolby®Digital Plus, Dolby TrueHD, dts-HD, HR, MA (upgradeable by firmware)
The 1400 data sheet shows: Dolby® Digital, Dolby®Digital Plus, Dolby TrueHD, dts-HD
So it appears the HR and MA capabilities will be restricted to the BD-P2400, the 1400 just gets DTS-HD Core (DTS Surround).
Old 09-02-07, 04:41 PM   #18   |  Link
Slingbox
I picked up the 1200 in the 5084 plasma package deal last week at CC.Im thinking of returning the 1200 for the 1400.
The Question,
Is the 1400 better then the 1200 or is it a wast of time exchanging?
Slingbox is offline   Reply With Quote
Old 09-02-07, 04:58 PM   #19   |  Link
Quetzalcoatl
The Question,
I would say waste of time. The 1200 has a better chip for upconverts. Now if the 2400 comes out before your exchange time is up I would make that change for the DTS HD MA.
__________________
The object of war is not to die for your country, but to make the other bastard die for theirs.
General George Patton
Quetzalcoatl is offline   Reply With Quote
Old 09-02-07, 06:05 PM   #20   |  Link
Slingbox
I took the 1200 back and got a gift card for $539.00 so time is now on my side .The rep at CC was pushing me towards the Panasonic but hmm not sure.
Old 09-02-07, 06:13 PM   #21   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
I would say if you plan to use it for mainly for Blu ray the 1400 would be better than the 1200. Dolby TrueHD is where it is at! Upconverting you have a case for the 1200 though. I plan to end up with the 2400 for my theater but will still give the 1400 a good workout...
__________________
427 Blu ray titles!
Old 09-02-07, 06:17 PM   #22   |  Link
Slingbox
Do you think CC will Carry the 2400 Anytime soon ??
Old 09-02-07, 06:58 PM   #23   |  Link
Adz523
What chip does the 1400 use for upconverting?
__________________
Adz
Next Level Audio Video
Adz523 is offline   Reply With Quote
Old 09-02-07, 08:17 PM   #24   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
In a few weeks the 2400 will most likely be hitting the BBs abd CCs... I do not know what chip the 1400 is using but I am sure it is no slouch... I will test it out soon...
__________________
427 Blu ray titles!
Old 09-02-07, 08:20 PM   #25   |  Link
Slingbox
Thanks Joe.I will hold out for the 2400 then
hmm heck
I will pick up the 1400 and then upgrade to the 2400
Old 09-02-07, 11:02 PM   #26   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
Sounds like a plan!
__________________
427 Blu ray titles!
Old 09-03-07, 08:10 AM   #27   |  Link
nonametofame
Some good news and bad news.
The Good: Samsung has a new firmware upgrade available to download via the player's Lan input. I was able to download it and install it without any problems. Only thing it seemed to change was the response time from the remote inputs. Other than that, I have no idea what it offers, but I did throw in a Fox title immediately.
The Bad: Sure enough, it still does not allow for bitstream passthrough. Only got the DTS core soundtrack on Flyboys. I guess this might confirm that this will only be available on the 2400 model.
The Ugly: I haven't had time to experiment with any more discs, but I do hope the FW upgrade fixed some issues with disc loading. I put in the BD torture test disc, Pirates of the Caribbean and it took an eternity to load. And it seemed random with other discs, all varying from snappy to almost unbearable. I'll post again later with any other findings.
Old 09-03-07, 09:06 AM   #28   |  Link
weathertop
New Member
nonametofame, does this player remember a paused position in a movie if the disk is ejected?
weathertop is offline   Reply With Quote
Old 09-03-07, 10:16 AM   #29   |  Link
joerod
End User Clinician
joerod's Avatar
AVS CLUB MEMBER
It would make sense that the 2400 has the HBR passthrough since it is coming out a little bit later. I would hope they would offer a firmware to make the 1400 do the same...
__________________
427 Blu ray titles!
Old 09-03-07, 10:49 AM   #30   |  Link
rlhjr34
rlhjr34's Avatar
AVS CLUB MEMBER
Classified Rating: 75% (5)
I'm like Joe. I'd really like to know if the 1400 will do the bitstream. I already have the XA2 for my standard DVD playback and don't need the upconversion ability of the 2400. If I have to spend the extra money for the 2400 to get bitstream I guess I will.
rlhjr34 is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.30445695 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
