AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 09-25-07, 03:39 PM   #1   |  Link
GrilledCheese
Lane Hollywood Seating - Does it fit?
Hi folks,
Finishing up my theatre and looking at buying some seating. I don't qualify for the HT Authority Powerbuy as my remote location precludes me from shipping, so no Berklines/Coasters/etc. for me, I have to buy local (thanks anyway Serge!).
The nicest chairs by far locally are the Lane Hollywoods, I have read some nice feedback on these items through the forum.
My question: for those who have had them delivered, do they come broken down for easy moving into the house? I have 32" doorways and a tight 180 degree turn on the stairs, with a low ceiling to boot.
Dimensions per chair are W=45, D=41, H=41. Salesperson said the back comes off, so the height may come down then to 20 inches? I should be ok if that is true. But I always like to check with buyers first, just to gauge their experiences.
Any further comments on quality/comfort of these chairs is appreciated also.
Thanks in advance...
GrilledCheese is offline   Reply With Quote
Old 11-11-07, 06:17 PM   #2   |  Link
GrilledCheese
My 4 chairs arrived a couple of weeks ago, the back was separate from the bottom so they easily fit into my house. They are extremely comfortable and have received great feedback from the people who have sat in them so far.
Old 11-12-07, 11:06 AM   #3   |  Link
theant
I also had a couple of them delivered last week, and they came in one piece. They were still able to get them in by reclining them through a 30 inch door. And I believe they are the most comfortable chairs I have sat in. If you did not know Lane is a division of Thomasville which makes excellent high priced furniture
theant is offline   Reply With Quote
Old 11-12-07, 02:50 PM   #4   |  Link
GrilledCheese
I did not know that actually, there is a Thomasville retailer in the city also but I don't believe they carried any Lane items, so I bought it from a Lane retailer.
They are comfortable enough to sit in for 8 hours, and recline at just the right angle so that I don't fall asleep.
Old 11-12-07, 07:10 PM   #5   |  Link
theant
The people at Lane told me if they took the same chair and put it into one of their Thomasville stores the price would be tripled just for the name alone. I agree they do recline at just the right angle and the leather was top notch. I did the leather/vinyl match and you cannot tell what is the vinyl.
Old 11-14-07, 12:47 PM   #6   |  Link
hoosierjerry
For what it's worth, I've had Lane's for 4 years and even at over 250 lbs. the chairs are still in great shape and as comfortable as ever.
hoosierjerry is offline   Reply With Quote
Old 11-17-07, 09:33 PM   #7   |  Link
GrilledCheese
One negative with these is that they are not attached, so when someone pushes back to recline the chairs can get out of line. Of course mine are on hardwood so that is not helping. Anyone join these together, or use carpet or something to make them less slippery? They won't incline on carpet though, so it is a bit of a dilemma.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.13006592 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
