AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Flat Panel General & New FP Tech
Forum Jump
Old 09-26-07, 09:39 AM   #1   |  Link
jestes22
New Member
LCD horizontal lines?
I bought a 46" Samsung 1080p monday. This morning I've noticed that there is a horizontal black line that has appeared at the bottom of the screen. It's visible roughly 3/4 of the way across the screen. It runs through the Fox listing on the guide in the pic.
Any ideas as to what caused this? Everything that goes to the tv runs through one of Belkin's top surge protectors.
jestes22 is offline   Reply With Quote
Old 09-26-07, 10:00 AM   #2   |  Link
nicknomo
Is it present in other channels? While I doubt it is a problem with the cable provider, it is possible.
Otherwise, I'd say that this is a pretty clear defect..
nicknomo is offline   Reply With Quote
Old 09-26-07, 11:13 AM   #3   |  Link
jestes22
New Member
It's visible on all dish channels, including my dvd movies.
Old 09-26-07, 02:04 PM   #4   |  Link
nicknomo
I'd put my money that the set is defective. The final test would be to see if it happens from other sources and other inputs... but I'm betting that you'll still have the problem. If you do not have the problem with this testing, you have just discovered what it is not - the very expensive and irrepairable panel on your tv.
If its your tv, return it or submit for warranty service..
Old 09-26-07, 04:40 PM   #5   |  Link
jestes22
New Member
I hooked up my PS2 to it earlier, same result. I've already submitted a warranty repair request on samsung's website for in-home service.
Old 09-26-07, 04:47 PM   #6   |  Link
nicknomo
I know of someone who had a problem with their samsung set.. The problem was rectified pretty quickly... so you should be ok.. Good luck!
Old 09-28-07, 01:04 PM   #7   |  Link
DBLASS
If the internally generated screen (like the OSD menu) shows the problem, then it is likely the set. The problem looks like inducted noise from the cables. This is why the video board generated screens should not show it (since it is not coming in from the outside window).
DBLASS is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.13006401 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
