AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 09-29-07, 08:31 PM   #1   |  Link
goku2100
Questions about a rack
First of all I was wondering if it is important to ground your rack or not. Second of all I wanted to know that since the rack supports around 1ton of equipment, for a given area in a typical home, how much weight can it support before it could collapse the floor?
__________________
Calling an illegal alien an undocumented immigrant is like calling a drug dealer an unlicensed pharmicist.
goku2100 is offline   Reply With Quote
Old 09-30-07, 01:02 AM   #2   |  Link
Don_Kellogg
The One and Only!
Don_Kellogg's Avatar
AVS CLUB MEMBER
iRaq is a small sandy country in the middle east, aside for that I believe racks are rated for a certain amount of weight my Mid-Atlantic is somewhere around 300#'s
__________________
The Cinema Kellogg
"Anyone who lives within their means suffers from a lack of imagination."
Don_Kellogg is offline   Reply With Quote
Old 10-01-07, 11:06 AM   #3   |  Link
reedl
I spent too much $$$
1 Ton? That's 2000 pounds. What the heck are you putting in your rack?
Reedl
__________________
Check out my theater! My Theater
Here is the Arcade: The Arcade
reedl is offline   Reply With Quote
Old 10-02-07, 03:15 PM   #4   |  Link
DoyleS
This question is really more about your home than the Rack. Homes are typically designed to have a safe uniform load of 40 pounds/sq foot. Now don't get concerned with that low number because that design means that the entire floor can have 40 pounds per sq foot on it. So a 10x10 room could be safely loaded with 4000 pounds or 2 tons. As mentioned in a previous post, a typical load in a rack might be a couple hundred pounds. How or why you want a ton in a rack is not clear. You might want to make sure the rack supplier agrees with that level of load. Your individual home could be an older home where the 2x10 floor joists were actually 2x10 instead of being 1.5x9.25 like they are now. There are too many factors to give you and easy answer. We all know that a 300 pound person could stand on any of our floors without it having a problem. We could also have 8-10 200 pound people in a 10x10 room with no problems.
..Doyle
__________________
"So many tweeks....So little time!"
DoyleS is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10379291 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
