#1 | Link |
New Home Theater groups from Berkline (after attending Market in High Point, NC)
Folks,
Here is my report from the Market in High Point, NC where I spent some time in the Berkline show room. Please understand that I am only sharing my opinion here… First, some of the current groups 073, 194, 45009 and 45010 are being discontinued. You can still order them until end of this year, but after that they are going to be dropped. Here is a little review of new groups I was able to see and try at the market. Domestic groups (I was able to take some pictures) 45015 This group has C-MAX bucket cushion with about 43” high back. While I am not a big fan of rounded armrests, this chair felt quite comfortable, and I liked it. These are about the same width as the 090s in straight configuration, but the curved configuration they are quite wider. I am not sure why the Berkline decided to make such wide wedges, but they did. 45016 This group also has C-MAX bucket cushion with about 42” high back. The back was quite comfortable, and the seat was soft and cushy. It has a puffy look, and if you are after a firmer seating this may not be the best chair. But if you like soft seating with very cushy feel to it, this is a great recliner. It was extremely comfortable. As a bonus, it comes with two level storage compartments in the armrests. The articulated back provides a nice head support. 45018 I did not like this one at all. The armrests were too high; the back did not feel comfortable and did not provide me with a great head support. Similarly to the 45013 these come with the blue rope light under the chair. The light can be controlled by the switch installed on the armrest of one of the chairs. The Berkline is still working on the switch for the lighted cup holder. They told me it would be in production by next spring. Each cup holder will have its own on/off button that will control the light. Non-domestic groups: 13134 This one did not do anything for me at all. It is basically the 13084 with the slightly modified shape of the back. I did not like the 13084, and I did not like the 13134 either. It felt awkward and not comfortable at all. 13174 This is basically the 090. It did not seat as quite well as the 090, but it was OK for me. It is still a good chair with very attractive pricing. It was much better than 13134 IMHO. I guess the reason this group was just OK for me was the fact that these were manual recliners, and I personally not a big fan of Leggett and Platt mechanism. The power recline version would have been much, much better. 13175 This would be my pick out of all new groups this time. The similar back to the 078s was extremely comfortable. These chairs are great alternative to small 088s or 086s. It has similar (just slightly wider) footprint, but with the 42” high back. The only thing I did not like – it was a comfort rest and not a chaise design. Nevertheless it sat very well. It had great head support especially in the reclining position, and it felt right. The power recline was perfect and the controls were on the sides of the armrests, and that is what I personally prefer. What I did like on non-domestic groups: 1. They use quite nice mid grade leather similar to 7077 (group 3 leather). I was actually surprised how well it felt. 2. They have power recline option, which is A MUST, and work as well as on their domestic groups (they use same components). 3. These chairs will be quite affordable. What I did not like on non-domestic groups: 1. They use Leggett and Platt mechanism, and it is hard to change the positions on the manual recliners. Thank God they have a power recline option!!! 2. Most of the recliners (except for the 13175) were nothing special. I either did not like them (13084, 13134) or they were just OK (13174). 3. None of the non-domestic groups have C-MAX cushion (not a deal breaker).
__________________
Roman rtheaters.com Utimate Home Entertainment Last edited by rsh; 10-20-07 at 08:30 PM.. |
#3 | Link |
Samaritano,
I do not have the schematics yet, and the ones that where on the floor were curved. I measued them and they were 98". By my calculation, the straight row of three should be around 93-95", but do not hold me to these numbers...
__________________
Roman rtheaters.com Utimate Home Entertainment |
#6 | Link |
Roman, you are going to be hearing from me in the next few days. I was leaning towards the 86/or 88 in a 4 chair config to minimize width to 115 inches or even 120 if possible. I have spoken to you on the phone several times before, but keep referencing your site and AVS to get the best possible chairs for my setup, hence the time delay. I have about 156 inches in width to work with and would like to have 20 inches each side to walk around. I like the straight config, but would prefer the curved if possible. Although the curved take up a 5 inches more width on the curved config of the 86/88, they actually take up the same or less space as you move toward the front of the two outside chairs since they curve in, don't they? Meaning, while they have a bigger footprint on each rear corner, they have equal to or less width than the straight at the front outside corners since they angle in? I like the 13175 as well and like your recommendation. What is the difference between comfort rest and chaise design?
#9 | Link |
The C-MAX cushion has a combination of high-density foam layer surrounded by a very soft layer of foam and fiber wrap. It gives a firmer feel and at the same time stays soft and comfortable.
The 090 and other based on the 090s seats do not have it. The groups that do have the C-MAX cushion are: 083, 45001, 45002, 45004, 45010, 45012, 45013, 45014 As I mentioned the difference is very subtle, and I would take a comfort and design of some groups over C-MAX cushion any day.
__________________
#13 | Link | |
Nope, they are on the sides of the armrests, similarly to the way they are done on the 090s.
FYI: There are no loveseat options on the 13174 or 13175 groups, only 3 or 4 straight across or curved configurations. Quote:
__________________
Roman rtheaters.com Utimate Home Entertainment Last edited by rsh; 10-21-07 at 11:18 AM.. |
#14 | Link |
Eternal Sonata
sexy!
__________________
Theater construction. |
#19 | Link | |
Thanks, |
#21 | Link | |
Miembro
AVS CLUB MEMBER
How long till you get the spec sheet on the 13175? I need dimensions. ![]()
__________________
Edgar |
#22 | Link |
All I have is dimensions per piece:
13174 two arm recliner IOI 3900 W39 D39 H41 one arm recliner OI 5200 W32 D39 H41 LF racliner w/RF console IOV 5340 W43 D37 H41 RF console recliner OV 5440 W37 D39 H41 13175 two arm recliner IOI 3900 W35 D37 H40 one arm recliner OI 5200 W30 D37 H40 LF racliner w/RF console IOV 5340 W37 D37 H40 RF console recliner OV 5440 W33 D37 H40 You can do the math from here... Hope it helps.
__________________
Roman rtheaters.com Utimate Home Entertainment Last edited by rsh; 10-23-07 at 08:14 AM.. |
#24 | Link | |
and IOVOVOVOI = 37+33+33+33 = 136 Can you do this? IOVOIOVOI = 37+30+33+30 = 130 |
#25 | Link |
Tweakophyte,
The first one is correct, the second one is not. IOVOVOVOI - > 37 + 33 + 33 + 30 = 133", but in reality it would be less than that because of the curvuture. I do not have exact number, but my guess it would be around 129" - 130". No, the confirugation IOVOIOVOI is not available.
__________________
#26 | Link | |
Miembro
AVS CLUB MEMBER
__________________
Edgar |
#27 | Link |
Edgar,
The specs on my site are from Berkline repository. I have not looked at them after I put it on my website - my bad. I believe they are wrong for the 13175. If you look carefully - they do not make much of a sense: According to these specs the straight armrest should be 4.5", and I know for sure it is not. Even if it was, it makes the seat width to be 28.5" which is definitely not the case. These specs are bogus. I will have to talk to Berkline about that. Refer to the dimensions I provided in this thread. From what I measured at the Market 3 seat curved configuration was about 97".
__________________
| Bookmarks |
| Thread Tools | |
