#1 | Link |
HT signs / logos etc.
Hey All,,, I Don't get to this particular forum much,,,, I usually peruse the dedicated theater construction thread and I posted this over there,,,, some of the kind folks suggested I post the thread over here as well.
Just wanted to throw this out there for you all. I'm now doing custom Artwork framing and matting, along with custom cut vinyl designs. I can do anything from cutting your personal HT's name or DTS/THX/HDTV etc. etc. logos to building the entire sign created from scratch. If you would like your prized movie posters framed to match your current HT design, I can get it done for you. I can cut pretty much any design/logo out of the color/texture adhesive vinyl you would like,,, gold, chrome, textured, clear, etc. I can build you custom "one-off" frames with custom profiles, in-laid alum or exotic woods, multi-layered matting with glass or lexan viewing material. I can build you a "simple" aluminum/laminate frame as you would order from a Michael's or "Frame Shop" for much less. Most of the folks around here are pretty handy and do this kind of stuff for themselves,,, but I wanted to throw it out there for anyone that may be interested. This is all in-house stuff that I will be doing,,, no sub out work here. If you order it,,, I will be the one designing/building it. Thanks for your time, Trevor Allen Graphic Details LLC tallen@graphicdetailsllc.com
__________________
You poor *******s... My GF actually said,,, "We can't put the couch there, that's where the sub goes"!!! My HT build Thread |
#2 | Link |
Eternal Sonata
Please show examples and I will order something from you
Thanks, ELmO
__________________
Theater construction. |
#4 | Link |
End User Clinician
AVS CLUB MEMBER
Signs like these?
__________________
427 Blu ray titles! Latest Fav- Monsters Inc. For my unbiased Reviews, Screen shots and more go to: http joerodhometheater.com/about.html |
#5 | Link | |
Eternal Sonata
Joe, that top sign is like $500 at least isnt it?
__________________
| Bookmarks |
| Thread Tools | |
