AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Flat Panel General & New FP Tech
Forum Jump
Old 10-13-07, 10:57 PM   #1   |  Link
holocinema
New Member
Lightbulb The most interesting question
so hdm formats store images at 16-235 ......ok
if u use a gamma 2.6 that = 220 levels to the power of 2.6 = 1231115 right
now forget about absolute black level for one moment
if i understand this correctly, to really show this perfectly u would need
a display that has a maximum luminance of 1231115 times its minimum non zero luminance in other words a ansi contrast ratio of 1231115 to 1 (still not taking into account zero black)
now where to put these levels in terms of luminance i dont know, lets see
we coud have 1231 nits to 0.001 nits
or 12311 nits to 0.01 nits
or what ever
but i think 12311 nits to 0.01 is better, our eyes need time for Dark adaptation plus our eyes have less dynamic rage at brighter levels so we wont notice the limited 220 steps + brighter more saturated colors and most important closer to real life almost ( hdr)
look at what this guy found out by testting
( http://delivery.acm.org/10.1145/1280...FTOKEN=6184618 )
so my question is, am i thinking right or what because if i am right then beautifull there is still room for improvment of image even with 16-235 and we have the illusion of hdr for free
holocinema is offline   Reply With Quote
Old 10-14-07, 09:29 AM   #2   |  Link
mastacow53
My head just exploded.
mastacow53 is offline   Reply With Quote
Old 10-14-07, 01:07 PM   #3   |  Link
tomanystraydogs
head on, apply directly to the forehead
tomanystraydogs is offline   Reply With Quote
Old 10-14-07, 04:50 PM   #4   |  Link
Jigen
or what ever
While I didn't get every technical term you threw around there, yes there's a HUGE way to go before displays can get even close to providing the contrast available in reality. That's why games have implemented real time HDR, because while we don't have displays that will require the human eye to react, we can simulate that reaction (or that of a camera) within the 3d rendering itself.
I wonder if humans will EVER be able to create a display with the contrast ratio even near reality (of course you wouldn't want to create a display that can be as bright as the sun, especially sitting 5 feet from it, unless you want to destroy the earth itself...), but even what we're used to as far as contrast, without the extremes is a long ways off.
If you're thinking of simplifying HDR calculations by cutting out the subtle gradients, no, that's not going to work because it would mess up the calculations and our displays can't do the work that HDR rendering can (not able to display that level of contrast).
Jigen is offline   Reply With Quote
Old 10-14-07, 06:53 PM   #5   |  Link
holocinema
New Member
there is nothing too technical about what i said,
with so much talk on this fourm about high contrast ratios
I just wanted to point out that to display 16-235 images at gamma 2.6
you need a display that has a maximum luminance of 1231115 times its minimum non zero luminance in other words a ansi contrast ratio of 1231115 to 1 (still not taking into account zero black)
Old 10-14-07, 09:22 PM   #6   |  Link
ccotenj
AVS CLUB MEMBER
Classified Rating: 100% (15)
so you pointed it out...
now what is your point?
ccotenj is online now   Reply With Quote
Old 10-18-07, 01:40 AM   #7   |  Link
Jigen
Honestly, I don't think you have any idea at all what you're saying.
First off, by saying 'a display that has a maximum luminance of 1231115 times its minimum non zero luminance' you should just type 1231115:1 contrast ratio. That's the accepted terminology. Noone would take 'zero luminance' as a starting point for any TV, because it would be off, if you consider 'zero' to be black as the set displays it, then you're sorely wrong because zero should be considered.
If you're using 16-235 and add gamma, you're going to be distorting the image more than is necessary for a HDR display. It'd be like turning the brightness and contrast to max on my TV and then complaining that I don't have decent image quality.
Old 10-18-07, 03:46 PM   #8   |  Link
k33p0u7
Holodeck from Star Trek?
k33p0u7 is offline   Reply With Quote
Old 10-18-07, 11:18 PM   #9   |  Link
CruelInventions
serpentskirting
this thread = good times.
don't ever change, holocinema.
CruelInventions is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.13618398 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
