AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 10-15-07, 02:07 AM   #1   |  Link
OldManClemens
Newbie in training
Movie Poster dealer
Hi Everybody!
I searched the forum and found a bunch of links for movie poster sites, but what I'm looking for here:
Is there one place you consistently go back to for your movie posters?
I'm interested in cheap, good selection, fast shipping of 27"x40" posters.
OldManClemens is offline   Reply With Quote
Old 10-15-07, 02:44 AM   #2   |  Link
coolhand
eBay for originals
allposters for replicas
coolhand is offline   Reply With Quote
Old 10-16-07, 05:50 AM   #3   |  Link
OldManClemens
Newbie in training
Thanks for the link.
Do you guys roll the posters back up when not in use or store them flat somehow?
Old 10-18-07, 09:26 AM   #4   |  Link
Road Captain
I store mine flat... I bought Bass LOC frames and kept one of the boxes the frames came in. Makes a great box to store the posters in.
Road Captain is offline   Reply With Quote
Old 10-23-07, 02:35 AM   #5   |  Link
OldManClemens
Newbie in training
Thanks. I guess just any old plain flat box will do then...
Old 10-23-07, 03:01 PM   #6   |  Link
coolhand
They are EXTREMELY difficult to store flat if they had been stored rolled up to that point. I tried deperately to store them flat but eventually gave up. I probably have ~200 originals. Just a guess.
Old 10-24-07, 05:48 AM   #7   |  Link
OldManClemens
Newbie in training
200 rolled up? Do you have a method of identifying them quickly?
Have you had much luck getting them from theaters?
Old 10-24-07, 12:28 PM   #8   |  Link
puskarich
I'm somewhere in the neighborhood of ~200 posters too. Have nowhere good to store mine flat, so I had to roll them up. I got a bunch of large shipping tubes from an office supply store to keep them in. They're organized by type of movie (comedy, etc) and the tube is labeled. I started an Excel spreadsheet to keep track of which poster was in which tube, but I cant say that I've referenced it that much.
My bro-in-law sells DVDs on the Internet, so he gets all those promotional posters. He gives the posters to me.
You may want to check small mom & pop rental stores. You'll find a decent selection there at cheap prices.
puskarich is offline   Reply With Quote
Old 10-24-07, 12:47 PM   #9   |  Link
HeyNow^
HeyNow^'s Avatar
AVS CLUB MEMBER
I found that storing the posters rolled up easily damages them when trying to put them in the poster frame. It would take two of us to hold the poster down to put in the case since rolling them up caused them to curl. I have since begun to store mine in a flat box and put that under a bed. Nicely protected and easy to access the posters.
__________________
Randy
My Bar Build
HeyNow^ is offline   Reply With Quote
Old 10-24-07, 02:05 PM   #10   |  Link
tleavit
I'd love to buy some origional posters and for some cash out for them but I dont trust anything on ebay
__________________
"Any sufficiently advanced technology is indistinguishable from magic" -Arthur C. Clarke
5 minute Video walk through of my Home Theater in High Def:
http://www.youtube.com/watch?v=ELHpQhkXUb8
tleavit is offline   Reply With Quote
Old 10-25-07, 08:17 AM   #11   |  Link
rgroves
Get two ( or more) slightly oversized pieces of plexi-glass (Lucite, etc..) and use them to lay your posters between for storage. Use bungee cords to hold the sheets of plexi together and store them upright in a closet.
I've only got 1 poster right now, but I want to get more and rotate them out, and I plan on using that method for storage.
rgroves is offline   Reply With Quote
Old 10-25-07, 03:49 PM   #12   |  Link
ginigma
Member Supreme!
Store flat, under a bed or sofa. Out of the way and doesn't take up any extra space.
ginigma is offline   Reply With Quote
Old 10-26-07, 03:45 PM   #13   |  Link
Road Captain
When I first receive a rolled poster, I unroll it, lay it flat on the floor and lay 2-3 DVD cases on each corner. Leave it there for a couple of days and they will lay flat by themselves. Flattened posters are alot easier to put in the frames.
I keep my poster box on the top shelf of my storage shelving in the basement.
I also get quite a few poster from the local 'Movie Gallery' rental. They roll them up, put them in a box and are free for the taking. The only difference is the poster are normally mark "Now on DVD" or something similar.
Old 10-26-07, 05:15 PM   #14   |  Link
Big Worms
Where did you get a box poster size to store them in?
__________________
.: DVD Profiler :.
Big Worms is offline   Reply With Quote
Old 10-26-07, 07:25 PM   #15   |  Link
HeyNow^
HeyNow^'s Avatar
AVS CLUB MEMBER
Take an appliance box and break it down. Lay the top on the bottom and tape two or three sides. Then open it up like a book. Pretty simple.
__________________
Randy
My Bar Build
Old 10-29-07, 01:04 PM   #16   |  Link
coolhand
My experience was that when I tried to flatten them out and stack them in an organized fashion they just got damaged. I have some pretty nice posters in there and decided that was not an option. My system is very close to that of puskarich. To be honest, I don't change them nearly as frequently as I thought I would. There really aren't many frames that are conducive to rapid changing.
Honestly, if I didn't care about the condition of the posters (I have several original Steve McQueen posters like The Magnificent 7, The Great Escape, The Cincinnati Kid, Bullitt, etc that are pretty valuable) I would probably find a way to just stack them to take up less space. I just haven't been able to manage it. I also like that I don't have to mess with my entire poster collection to get at a few of them.
If anyone is looking for some specific posters let me know. I have many that will likely never see the light of day that I wouldn't mind getting rid of. I might also be able to show you what and where to look for.
Old 07-29-08, 07:51 AM   #17   |  Link
Ormazd
If you're using cardboard boxes or tubes to store your posters, make sure you protect them with acid free tissue, mylar, etc.
Ormazd is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.20563507 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
