AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 10-18-07, 06:09 PM   #1   |  Link
marcus wood
Alternatives to Middle Atlantic?
I'm looking into using a Middle Atlantic AXS slide-out rack, but I'd like to find out if there are any other manufacturers making similar products, i.e. slide out racks with custom rackmounts. This is partly because the maximum height of the AXS is 43 units, and I'd like to go a bit taller than that. Are there any similar products around?
By the way, on the Middle Atlantic racks I've seen pictures of here, people don't seem to fit trim strips to cover the screws. Why is that - are they difficult to fit?
marcus wood is online now   Reply With Quote
Old 11-06-07, 08:32 AM   #2   |  Link
thundercow
DONT get the AXS slide-out. If you do, the screws at the bottom that both i-lock the slideout rails in place, and ii-hold the anodized plate that secures the unit, are going to strip and leave you with a very profound need for a large can of zip ties.
If you do get it, get extra screws and replace them each time you remove the rack.
thundercow is offline   Reply With Quote
Old 11-06-07, 12:10 PM   #3   |  Link
LathanM
AAGG
The trim strips are a bit of a pain to install and aren't really worth the extra cost. Just get better looking screws. I am using ones that have knurled and anodized black to match the rack.
How tall of slide out are you needing? If it is a full size look into a computer cabinet. Most have wheels built in. Just attach the trim directly to the rack. Works great and you don't have to worry about the screws stripping. If you are going smaller check with cabinet companies in your area. They make heavy duty drawer slides that will support 300lbs or more. Just attach a standard rack on top of it.
__________________
LathanM - Who brought the popcorn?
Blog - http://project2501.tumblr.com
Home Automation Gallery
LathanM is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10596395 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
