AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 10-19-07, 02:41 AM   #1   |  Link
rebelsubs
New Member
big speakers near fireplace???
I have a pair of MTX monitor tower speakers. Each has a 12 inch sub.
I am moving into a house with a rock fireplace. There is a perfect spot for one of these speakers between the edge of the rock ledge, and a build in bookshelf.
The speaker would be over two feet away from a any fire, at a slight angle. I am worried about the heat, or embers. It is a gas fireplace, wood can also be used.
So could the heat damage the fabric of the cover? Or the finish on the side? Or worse, ruin the speaker?
Anyone have a similar setup with/without problems?
rebelsubs is offline   Reply With Quote
Old 10-23-07, 01:39 PM   #2   |  Link
porsche951
Step 1: build fire
Step 2: place hand where you are considering placing speaker
Step 3: If hand is warm, heat may damage speaker enclosure.
Step 4: consider different location for speakers
Good luck.
porsche951 is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.10386300 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
