AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 10-19-07, 09:43 AM   #1   |  Link
tinman1412
Bad Reception. What Do I do?
I hooked up my brand new Sony XBR4 last night with a Terk HD atennae and got horrible reception at my apartment. The only digital channel I was able to pick up was ABC HD, and it didn't look all that great. I also had to extend my antennae all the way outside balcony to get reception. Ok, what are my options at this point?. Should I try to get a better antennae?. Can I can local hd just by using the coaxial jack and not use the antennae?. Do I need to subscribe to Dish or Cable just to get local channels?
Please advise, I'm not impressed with what I've seen so far. Do I need to calibrate the TV as well. Sorry for the long post, I'm just a little frustrated and dissapointed. Thanks
tinman1412 is offline   Reply With Quote
Old 10-19-07, 10:01 AM   #2   |  Link
afiggatt
What you do is go to the HDTV Hardware reception forum, repost this, but PLEASE PROVIDE YOUR ZIP CODE so we can find out how far you are from your local broadcast towers, what directions are they at, and what channel bands they are on. What Terk "HD" antenna do you have? As for cable, what HD channels does your cable company provide? You can also go to the local thread for your area and ask for help there.
afiggatt is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09397888 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
