AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 10-19-07, 03:01 PM   #1   |  Link
squirrellydw
Wiring hookup question??
I just bought a antenna to hook up to see if I can get OTA HD and had a question on how to connect it to the TV. I have a Dish Network receiver, do I run the antenna cable into the receiver, the receiver than TV or just to the TV?
squirrellydw is offline   Reply With Quote
Old 10-19-07, 03:47 PM   #2   |  Link
ctomguy
Illini Fan
I would try hooking it into the Dish receiver first, especially if you have a DVR model. This will let you record OTA shows. However, it has been my experience that my TV (HP MD5880) can pull in signals that the Dish VIP622 cannot, so if you're having trouble you might want to try hooking up directly to your TV to see if that works better.
ctomguy is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.08779097 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
