AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Plasma Flat Panel Displays
Forum Jump
Old 10-21-07, 03:08 PM   #1   |  Link
grazyna672
New Member
LG 32PC5RV first 32-inch plasma
Even if it's not the first as LG is claiming it is, the 32PC5RV 32-inch plasma TV recently announced by the company is the smallest plasma TV to get a decent production run....Read ALL
__________________
HDTV Portal - News, News & News
grazyna672 is offline   Reply With Quote
Old 03-29-08, 06:25 PM   #2   |  Link
IMOp-i-nion
New Member
For anyone who understands & appreciates the current benefits of plasma technology, this LG 32PC5RV 32-inch plasma is a smart addition to the smaller flat panel line.
I too have been waiting patiently for the LCD technology to improve, as a replacement for a quality CRT; I have yet to see an LCD that doesn't disappoint.
I have recently purchased one of these & for a flat panel, as a quality CRT replacement; it is what I was hoping it would be!
Connected to analog feed it looks as good as a quality CRT ( impressive for a flat panel TV )
As far as it's 852 x 480 panel, don't let other's criticism fool you. It displays as clear & sharp ( High Def. appearing image ) as any larger 720 / 768 Res. High Def. flat panel I have ever seen.
It is capable of receiving any high def. inputs up to 1080i through HDMI and displays any high quality source beautifully !!!
The real bonus with this TV is the picture quality it produces when the source is not Hi Def.
As many salesmen will try to sell you on the picture quality of the latest & greatest 1080p set and all it's benefits when viewing the latest ( if I might add "limited" ) source material.
In the real world, most of us still use our TV's for watching Television ...
What percentage of television is broadcast at 1080p ?????????
What percentage of television is broadcast at 480i > 1080i !!!!!
Many may criticize LG, or any manufacturer, for releasing such a TV, referring to it as out dated technology.
Anyone who really understands what is most important in creating good picture quality for modern day Television viewing will appreciate this TV, if you are looking for a television in this size range.
IMOp-i-nion is offline   Reply With Quote
Old 03-30-08, 01:46 PM   #3   |  Link
Jamesman0
member
I recently purchased this tv as well. I am quite pleased with the quality of the picture when compared with the price of the unit. The picture is far superior to budget LCD's in the same price range. I have not noticed much of a difference between the clarity of this set and other HDTV's when viewed from a reasonable distance.
The difference I have noticed with high def sources is more then made up for, by the improved image with SD broadcasts. This is my third HD TV (samsung 1080P LCD and aPanny 60U plasma) so I feel I have been able to make reasonable comparison.
The only criticism I have is that the black levels could be abit better.
I have one question for anyone that may have bought this tv. I tried to connect my HD sattelite reciever to this unit using a DVI to HDMI cable and the audio inputs on the tv do not seem have an option to provide sound to the HDMI port. It seems the only sound input for DVI is a computer sound jack for the VGA input.
What is the solution to this problem? It seems ridiculous that LG would have made no way to connect sound for DVI "boxes" in an easy way.
Jamesman0 is offline   Reply With Quote
Old 03-30-08, 02:20 PM   #4   |  Link
chrisherbert
You can buy an inexpensive adapter that will link RCA to the standard PC/headphone jack. You can find them at Radio Shack, and monoprice has one (http://www.monoprice.com/products/pr...seq=1&format=2) for 65 cents.
chrisherbert is offline   Reply With Quote
Old 03-30-08, 03:12 PM   #5   |  Link
scorpio_87
Where do you buy this TV? Sounds interesting. Also, just to confirm, the upcoming Vizio 32" is made by LG and will be a 720p set?
scorpio_87 is offline   Reply With Quote
Old 03-30-08, 03:26 PM   #6   |  Link
slbosse
Well, the Vizio press release certainly seems to state that the 32" will be 720p:
http://www.avsforum.com/avs-vb/showthread.php?t=970879
I guess that means it's a new panel, since that LG 32" that was released late last year (non-U.S.) is a 480p panel. Makes me think that maybe LG will also have a 32" 720p set this year, at least in some markets.
slbosse is offline   Reply With Quote
Old 03-30-08, 05:02 PM   #7   |  Link
Jamesman0
member
chrisherbert,
Thank you. Will the audio quality suffer at all by doing this?
Old 03-30-08, 05:03 PM   #8   |  Link
Jamesman0
member
Scorpio 87,
I picked mine up at best buy. They price matched a futureshop sale and I got it at a great price.
Old 03-31-08, 08:04 PM   #9   |  Link
chrisherbert
chrisherbert,
No it'll sound the same. It's not doing anything to the signal, just changing the plug.
Old 04-01-08, 06:14 AM   #10   |  Link
lazerfan
I bought this plasma when it first came out, back in November. I have found that the picture seems a little better, as the plasma has aged a little.
I'm seeing less false contouring now, even though there wasn't a huge amount in the beginning.
The easiest place to pinpoint is at the very beginning of Deep Blue. The close up of the ocean broke into clear concentric rings, when the plasma was new. This effect has diminished greatly upon recent viewings of the same dvd.
lazerfan is offline   Reply With Quote
Old 04-01-08, 06:57 AM   #11   |  Link
tinghai
Can't agree more to the excellent SD playback on this little LG Plasma. I noticed some IR after leaving the DVD menu on for 30mins but clear away after doing the white wash (ISM) thing.
tinghai is offline   Reply With Quote
Old 04-02-08, 08:21 PM   #12   |  Link
Jamesman0
member
I have been looking at the 2008 models to see if LG was going to produce a 720p model of this tv, but I haven't found one. Does anyone know if LG is going to be continuing to Make 32" plasmas or if they ahve dropped this size?
Old 04-07-08, 03:43 PM   #13   |  Link
Jamesman0
member
I have been having a lip sync problem with my tv. Has anyone esle had this problem? I have tried multiple inputs, multiple sources and different cables and it seems to be there. It is not severe, but enough I have noticed it. I suppos eI should call LG then haul it back to bestbuy and excahnge it.
Old 08-30-08, 09:56 AM   #14   |  Link
blued888
Is this TV considered an EDTV or HDTV? It's capable of accepting signals up to 1080i.
Is the 852x480 resolution principle similar to that of 1024x768 used in 42" Plasmas? (Resolution says 1024x768 in plasmas but they are still capable of displaying HiDef)
Would I still need an upscaling DVD player to fully appreciate picture quality of will normal 480p players be enough, given its resolution?
blued888 is offline   Reply With Quote
Old 08-31-08, 09:11 PM   #15   |  Link
Jamesman0
member
I think the best way to describe the tv is that it is an edtv that is hd capable because it will accept hd signals. I think a 480p dvd player would be just fine as 480p is the native reolution of the TV. Of course, an uconverting DVD player would be nice, but it is not necessary.
Old 10-10-08, 03:37 AM   #16   |  Link
horng
New Member
how about playing xbox360/ps3 and watching blu-ray movies?will it do the job nicely?compare to 720p lcd resolution, any difference?
care to share some pic of it?
thanks!
horng is offline   Reply With Quote
Old 10-10-08, 03:28 PM   #17   |  Link
lazerfan
thanks!
I've had one in my bedroom since November of last year. I have an LG BH200 hooked to it for dvd, HD DVD and blu-ray playback.
The real improvement with high-def is just the clarity of the image and lack of noise/artifacts. Standard dvds look great on this set.
I once tried flipping a combo-HD DVD to try the standard side first, then the hi def side. Not a very noticeable difference at all. Perhaps a little cleaner with the HD DVD side.
This is definitely a tv set that is fine with just a good progressive scan dvd player. You'll actually get a better picture with this set- as it matches the resolution of the set perfectly- versus a hi def set.
As the tv has aged a little I have zero burn-in. IR happens but disappears very quickly.
Here's an example. I had a little IR from the dvd menu last night. I put the tv on Whitewash mode. Within 2 minutes the IR was totally gone and I turned off the set.
The IR also goes away by itself when you watch moving material, of course.
Old 10-10-08, 08:38 PM   #18   |  Link
C E Jones
I'm not quite getting why this tv exists. The resolution is weird for this day and age, especially considering that LG has released a 720p 32" plasma in England:
http://www.trustedreviews.com/tvs/re...n-Plasma-TV/p1
Also, considering that the 32" plasmas from Vizio and Insignia use the LG panel, I'm wondering why they don't release it here under their own brand.
C E Jones is offline   Reply With Quote
Old 10-11-08, 12:53 PM   #19   |  Link
lazerfan
The set doesn't have an ATSC tuner, which I believe is now mandated by U.S law. That's why it went on sale last November in Canada, but not in the U.S.
We don't have that law in Canada.
Old 10-12-08, 01:58 AM   #20   |  Link
aerodynamics
Agreed. That's the only obstacle keeping me from buying the Insignia. I have a feeling LG (or some other higher tier brand) will release their own 32" plasma in the very near future, especially given the fact both those sets are selling well (the Insignia was on backorder on the BB site as recently as yesterday).
aerodynamics is offline   Reply With Quote
Old 10-12-08, 01:50 PM   #21   |  Link
C E Jones
Same here--I've seen the Insignia at BB and the PQ is impressive for the money, but I can't believe they deny access to calibration settings. In the review of the LG I link to above, they mention the LG can indeed be calibrated. Lazerfan points out that it doesn't have An ATSC tuner, which would make it illegal to sell stateside as is--but how hard could it be to add an ATSC and market it in the US? They'd probably sell a ton of them. I hope you're right and LG or another legit brand releases a 32" plasma early in 2009. At this point I've decided not to buy the Vizio or the Insignia, and I'll never buy LCD!
Old 10-12-08, 02:49 PM   #22   |  Link
aerodynamics
Also, LG already has the PG60 series stateside which uses the same one-piece glass design as the 32PG5000. It's just mind boggling to me why they haven't released it yet.
At this point I'm waiting to see how Black Friday shapes up - they say that's the best time to buy an off brand TV. I'm hoping BB will sell the Insignia in the $400s otherwise, like you, I'll keep playing the waiting game and see what happens early 09.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.25563407 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
