AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Home Entertainment & Theater Builder > Theater Room Items & Accessories
Forum Jump
Old 10-23-07, 12:49 AM   #1   |  Link
tubaprde
Focused lighting without the visual distraction
Can people reccomend some recessed lighting (or a thread) that doesnt spill light onto the screen, focusing instead on the sofa or back half of a 14'x14' room? Are there some models that are better than others? I'm looking to install 2 to 4 of them and use a dimmer for movies and a full blast for sports.
Thank you.
tubaprde is offline   Reply With Quote
Old 10-23-07, 09:56 AM   #2   |  Link
BIGmouthinDC
HT 2.0 Bound
AVS CLUB MEMBER
get cans with pin hole baffles. The light goes straight down.
these are 6 inch cans but I also used some 4 inchers that are even more focused.
BIGmouthinDC is online now   Reply With Quote
Old 10-23-07, 03:55 PM   #3   |  Link
tubaprde
Thank you! Very nice looking theatre there...is that a h79? How do you like it?
Old 10-24-07, 08:06 PM   #4   |  Link
DoyleS
You can also get cans with eyeballs to direct the light.
..Doyle
__________________
"So many tweeks....So little time!"
DoyleS is offline   Reply With Quote
Old 10-25-07, 07:48 PM   #5   |  Link
BIGmouthinDC
HT 2.0 Bound
AVS CLUB MEMBER
thanks, yes the H79 aka the "Depreciator" (for drop in value)
Good picture for HD sources, burns bulbs at the rate of 500hours each.
Old 10-25-07, 07:52 PM   #6   |  Link
BIGmouthinDC
HT 2.0 Bound
AVS CLUB MEMBER
Yes I have two 4 inch can eyeballs on those two front columns in that pic
Old 10-26-07, 08:59 AM   #7   |  Link
scaesare
Also pay attention to the beam spread when you buy your bulbs.
I used narrow beam spreads (either 8 or 10 degrees) in my 4" cans to get a much tighter pattern aimed downward and minimize "horizontal" travel of the light.
__________________
-Steve
scaesare is offline   Reply With Quote
Old 11-01-07, 11:50 AM   #8   |  Link
tubaprde
Ahh, interesting. I'll have to look for that. Thats excactly what I wanted to know.
Should I be using incandescent or Halogen or how about LED? Also, does 6500k thing matter? Thanks
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.12146711 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
