#1 | Link |
Suggestions for OTA HD Tuner card
I'm looking for adding a tuner card to my HTPC. It must be PCI and work with Vista Media Center. I would also like 32 and 64bit support.
I need dual tuners for recording two HDTV shows at once via OTA antenna. I would prefer a single card that has dual HD tuners but have yet to find any. But I can fit two cards in my case. Would be better still if I could record 3 HD programs at once but don't have room for more than 2 cards. I was looking at the fusion 5, myHD, ATI 650 and various happague but can't quite decide. |
#2 | Link |
AVS CLUB MEMBER
HDHomerun, won't even take up a slot...
__________________
My website documenting my HT/HA system & path. - Training video & docs for "Intro to HA via Elk/CQC", "Intro to Security Systems", & "Advanced Elk/CQC" - My Equipment Lists - Wiring Suggestions |
#3 | Link | |
I just decided it was better to plug the HDHomeRun into my gigabit switch and take this stuff out of the case. Plus its got great support from Vista from what I can tell and the upside is other folks can use it across the LAN.
__________________
Chris |
#6 | Link | |
![]() By the way I have 2 of these and am able to record 4 HD streams at once without problems.
__________________
XBOX360: Ingo23 PS3: RJ23 |
#7 | Link | |
#9 | Link |
I've had good luck with VBox DTA 150, which is an older PCI single tuner card without QAM support. I love Vbox, but there really is no better value than the HDHR (that's what I use now with Mediaportal).
Heh, I bough the HDHR back when they were first released, and they were ~$125 if I remember correctly, and the only place you could order them was www.9thtee.com. I doubt you'll find any cheap (or used) HDHR. I think most HDHR owners feel the same as I do...you can have my HDHR when you pryit out of my cold, dead hands. |
#10 | Link | |
How sensitive is the HDHR? I live pretty far away from the towers and have found that not all tuners are created equally. The Direct Tivo box I had couldn't tune all my HD channels but my newer Dish Network box can. So whatever tuner I get is going to have to be pretty damn good.
#11 | Link | |
VboxDTA 150 and Fusion 5 worked great, but I got rid of them for the HDHR. HDHR works great. I'd say at least as well as the Vbox and Fusion 5: I watched football all day yesterday during a blizzard and I live in a valley 30 miles from the broadcast towers. (I use a omnidirectional UHF and a Directional VHF antenna on my roof.) |
#13 | Link | |
That said, depending on the strength of your antenna signal you might not encounter a problem with a 4-way splitter. I have a good high-mounted rooftop antenna that is split four ways. If you do encounter a problem you might need a better antenna or relocate it to a better position. If all that fails there are signal amplifiers but I'm not familiar with their costs or efficacy. |
#14 | Link | |
#15 | Link | |
Good to hear the HDHR has a good tuner. How does the HDHR work with multiple media center PCs on the network (XPMCE 2005 on both)? Can both access it as a tuner at will or does one PC own it all the time? If both how does it handle conflicts? |
| Bookmarks |
| Thread Tools | |
