AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 12-24-07, 01:30 PM   #1   |  Link
aquablue
New Member
Is my new XBR4 faulty, or is this normal reception?
My XBR4, connected directly by cable (no box), displays alot of odd artificats when showing HD channels. I.e, the background of a scene will turn into blocky pixels when motion/camera pan occurs. Also, shimmering dots/noise will appear at many times even on HD sources.
What gives?? I thought HD was supposed to be clear/crisp - why am I have this, is this a defective new TV, a bad source, or just the way it is? Is this normal compression?
If so, how do I get the best HD signal - do I need to switch to a cable box, or sattelite?
Aqua
aquablue is offline   Reply With Quote
Old 12-27-07, 09:55 PM   #2   |  Link
samaird
Sounds like channel bandwidth issues from your cable company. Do OTA (over the air) signals look equally as bad?
__________________
Muscatine, IA
samaird is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.08882809 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
