#1 | Link |
VMD Insider
Warner's Filtered 1080i Masters - Witness the Horror - *Pics*
This is an old topic but there has been some renewed discussion on it lately. So I decided to take some screencaps and document the issue.
The exact cause is still in question. But we know the effect is horrible jaggies. They are most easily visible on a 1080p display. These have sometimes been referred to as "bobbed" masters but I don't believe that is correct. Last edited by benes; 01-03-08 at 12:04 AM.. |
#3 | Link |
Never Ever Warn-her
benes. Thanks for the info. I also appreciate you for putting a note about this in your spec thread. As long as the PQ is top notch do we really have to bother about movies being authored using filtered 1080i masters ? Also I would like to know when and why the Studios will prefer this technique ?
__________________
Blu-ray : 213 |
#4 | Link |
Does anyone know: Is there anything to be done about the "vertical jaggies" i.e. do there exist clean frames within these movies, or is every frame hosed?
Wondering if I rip one and run an Avisynth script (e.g. SeparateFields) might I be able to find clean frames? |
#5 | Link | |
http://www.avsforum.com/avs-vb/showthread.php?t=942015 |
#6 | Link |
Freak
Hey benes,
good work. I don't see any indication that this is related to 1080i filtering, though. I quickly analyzed a few pics and they all had 960 instead of 1920 pixels of HORIZONTAL resolution. At first i thought its downsampled to 960 and then upscaled again using nearest neighbor filtering. But it appears to be more complicated than that. Its similar to CUE, but in vertical and it doesn't match up (just swapping neighboring lines doesn't match up). Some also had some vertical filtering, but that is NOT the issue here. And why this is supposed to be related to 1080i is beyond me. ![]() Whatever the cause. We urgently need a complete list of titles like this. Thanks again for the work Bjoern
__________________
"Never underestimate the predictability of stupidity" (Bullet Tooth Tony in 'Snatch') Videophile.info (HD and DVD reviews, SPL measurements, my HT in action...) | 'Edge Enhancement' Guide |
#7 | Link |
Screenshot Scientist
I love these threads. Great job, benes.
I'm also not sure that the jaggies are the result of filtering. Maybe some kind of improper 1080i to 1080p conversion or other mistake. They've shown up in many Warner HD transfers that have been broadcasted. Batman, Wild Wild West, Mavrick, etc. The Shining had it bad as well but thankfully the HDM versions are clean. As for any other suspicious titles I'm very curious if The Twilight Zone: The Movie has it. The broadcast version sure did: ![]() |
#8 | Link |
Freak
Stop it guys, you are killing me
![]() These pictures have jaggies due to limited horizontal resolution! 960 like i said above. This has nothing to do with filtering due to 1080i nor 1080i to 1080p conversion, both would operate on the vertical dimension. I want the source of the rumor that this is 1080i filter related. And names of people who believed it ![]()
__________________
#10 | Link | |
They are 1920x1080p on the disc but a problem with the master results in the vertical lines being screwed up. Think of it as an upconvert but only vertically.
Did Warner expect people not to notice or are their screens really small and these problematic transfes went by unnoticed? At some point a flag sould've been raised. Thank you, benes. I was worried about Twilight Zone. Looks like Warner corrected the problem so there is hope for the other titles to see proper releases. |
#12 | Link |
Yeah, they said around the summer of 2006 they weren't going to be releasing any more of these, except for a few already in the pipeline. I think Willy Wonka may have been the last one (although some of the titles already done for HD DVD got released on BD in 2007).
#13 | Link | ||||||||
It was confirmed by many insiders after that, you can read the quotes in this thread: http://www.avsforum.com/avs-vb/showt...2#post11254282 I report all the quotes here for reference: Quote:
From another forum too: Quote:
From a DVDTalk Review of FMJ: Quote:
__________________
#14 | Link | ||
Different transfer?: Broadcast HD-DVD/BRD Has it been confirmed that the new Full Metal Jacket is a new transfer and not a fixed version of the old master? I remember captures that were posted and the colors were indeed better but they might've just been tweaked. Quote:
#15 | Link | |
1080P dreamer...
Has WB made any statement about not continuing to release such poor HD DVD/BD product with these sub-standard masters? What's the latest/most-recent affected title to have been released?
Whether it's improperly bobbed/flagged/deinterlaced masters, or simply older masters that were compromised by filtering/processing and cannot be fixed, it doesn't matter. New film-to-digital transfers should be struck.
__________________
1080p and lossless audio. EVERY BD should have them both. |
#17 | Link |
1080P dreamer...
Sounds like it's an issue that's been effectively dealt with at WB in that case.
Though it's a bummer about this title... it's one I've been waiting to get on Blu-ray though now I'm in no rush for WB to bring it to that format! hopefully, as with full metal jacket, maybe this one will get revisited... with more luck for its first appearance on Blu (and re-issue on HD DVD).
__________________
#20 | Link |
Yeah, I've never understood the complaints about Lethal Weapon 1. It's just not there. Lethal Weapon 2, on the other hand, is the WORST high def title released on either format. The fact that it ranks as high as it does on those tier lists is a testament to how ill-conceived those tier lists are. How you could rank that disc as anything but unwatchable is beyond me. I actually have to crank my sharpness almost all the way down to hide the artifacts. Wonka is just as bad. From there they get better.
#23 | Link | |
http://www.avsforum.com/avs-vb/showthread.php?t=942015 On the Blu-ray list is in tier 4 and above LW1: http://www.avsforum.com/avs-vb/showthread.php?t=858316 Proof that the voting system works better. ![]() |
#25 | Link | |
AVS CLUB MEMBER
More problems come about from attempts to remove the obvious jaggies introduced above. Often it is felt you can't remove much more vertical information so to reduce jaggies (stair step) on diagonal lines you instead/also filter horizontally and it appears you also have less horizontal resolution. Though you still won't have really smooth diagonals unless the original picture had only vertical detail below the new 540 line Nyquist limit and thus avoids the ambiguities introduced by using only half the vertical samples. I believe some of the deinterlacing chips have these properties. - Tom PS - Even worse, sometimes credits or graphic overlays are introduced after telecine to 60i, creating more obvious problems. Dunno if that happened here anywhere.
__________________
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors? Tom Barry - Find my video filters at www.trbarry.com Last edited by trbarry; 01-04-08 at 07:46 AM.. |
#28 | Link | |
#29 | Link |
"You ain't just whistlin' Dixie, there, Brother" (I think that's from Bugs B.)
I ripped & loaded it and it's jagged on every image, though of course certain shapes look worse than others. This is from Perfect Storm. How could you, Warner? "The horror...the horror!" |
#30 | Link | |
AVS CLUB MEMBER
- Tom
__________________
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors? Tom Barry - Find my video filters at www.trbarry.com |
| Bookmarks |
| Thread Tools | |
