AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > Display Devices > Digital Hi-End Projectors - $3,000 USD MSRP and Up
Forum Jump
Old 01-10-08, 10:47 PM   #1   |  Link
foofoobar
Suggestions for Epson 1080 UB vs. AE2000 shootout
Edit: Link to UB review with lots of pictures:
http://www.avsforum.com/avs-vb/showt...5#post12787075
Yes folks -- you read that right -- I have both of them lined up side up side. I have already made up my mind about which one I am going to keep, but won't spoil the suspense .
So, for a short time only, any recommendations on what I should capture for those still on the fence?
I can play HD versions of the following:
Phantom of the Opera
2001 : A Space Odyssey
Blade Runner
King Kong
The Shining
We Were Soldiers
SD-DVDs recommendations will be welcome too (upconverted to 1080p using the Reon in the Onkyo 905).
So fire away (PM might be better so as to not clutter the forum) ...
foofoobar is offline   Reply With Quote
Old 01-10-08, 11:22 PM   #2   |  Link
42Plasma
I'd like to see comparisons about black levels, overall color balance and sharpness. My suggestion is use King Kong and We are Soldiers.
I am on the fence on what to upgrade to from my Samsung 710 projector. Any suggestions?
42Plasma is offline   Reply With Quote
Old 01-10-08, 11:23 PM   #3   |  Link
suffolk112000
HTUnder Construction
Classified Rating: 100% (1)
Blade Runner
King Kong
The Shining
We Were Soldiers
Well, I would like to hear your opinion as to how each handles SD-DVD's, Sports in HD and of course HD-DVD or BD movies.
You could start off by telling us about your room environment. Are your walls dark. What color is your carpet and ceiling. Is the room light controlled? What is your throw distance? What kind of screen are you using? Screen size. Seating distance to the screen? Will you be measuring these units straight out of the box or will you be calibrating them. What is the method of calibrating the projectors?
Is this going to be your first projector purchase?
Sorry… But you did ask if we had questions.
Craig
__________________
Domino's don’t fall all at once, they fall one at a time...
suffolk112000 is offline   Reply With Quote
Old 01-10-08, 11:33 PM   #4   |  Link
Steve Dodds
I'd be curious about best brightness, and brightness in best modes. Plus of course black levels and shadow detail. Bladerunner is ideal for that.
I wouldn't delay too long with results either. Folk get mighty impatient around here.
__________________
My DIY Dipoles
Read My Book
Steve Dodds is offline   Reply With Quote
Old 01-11-08, 12:19 AM   #5   |  Link
foofoobar
Some quick answers about the environment for the impatient :
PJ newbie: Yes, but pretty well read thanks to avsforums
Screen: FocusPix Grey1.8, 106" diagonal (1.8 gain). Top of screen is ~2.5' from ceiling (room restrictions)
Room: 20' long with 9+ ' ceilings
Throw distance: About 14' feet; PJ mounted at 6' 4" to account for retroflective screen
Seating: About 10'
Ambient light control: Very good / excellent. Can be made pitch dark esp. at night if wife permits . On the minus side, walls are painted beige with a tan carpet; door 16' away and diametrically opposite is bright white.
Old 01-11-08, 09:16 AM   #6   |  Link
edved1
I'm interested in the outcome. When is this gonna take place?
edved1 is offline   Reply With Quote
Old 01-11-08, 09:55 AM   #7   |  Link
Ishmael198
It should've already happened, I need to know now! NOW!!!
Seriously though, looking forward to your comments and I echo the thoughts on brightness and black levels.
Also curious how the Epson out of the box best colour modes (and its new xvColour mode??) compare to the Panny's (whose out of box colour accuracy is touted as excellent).
Thanks in advance for your time and thoughts!
Ishmael198 is offline   Reply With Quote
Old 01-11-08, 10:29 AM   #8   |  Link
timell
foofoobar,
Since you've already made up your mind, I'm assuming the shootout has already happened. What I'd like to know is, are the projectors close in performance or does one completely blow away the other? (10 vs. 9 or 10 vs. 6) My main areas of interests are brightness, (I've got a big screen and a long throw so I need lumens at the best color mode), contrast/film look (my main use will be watching movies and I'm looking to recreate the cinema at home and really enjoy the 3D look), and finally sharpness (Blu-ray player for HD and SD).
Because I've got a 2.35 screen, the panasonic will probably get my business since it does the vertical stretch without the need for a scaler. But if I had to guess, I bet these projectors are probably fairly evenly matched with one or the other fitting into your setup better than the other. (placement, brightness, contrast, black levels, noise, focus, aesthetics, dust, etc.) Hopefully both projectors have good convergence and uniformity so that the playing field was level.
Can't wait to read the outcome
timell is offline   Reply With Quote
Old 01-11-08, 01:44 PM   #9   |  Link
pottscb
I'd be interested mainly in HD content with the following comparisons:
-Sharpness (soft, sharp, or tack sharp)
-Contrast (how punchy are each in mixed content)
-Black Levels (do either give that inky feel with an all black image? How dark are the 2.35 letterbox bars?)
-Upscaling/deinterlacing of DVD, do both pjs outperform, say, an oppo 981 or similar?
-Relative shadow detail
-Any image "deal breakers"?
Thanks for doing this for all of us...
pottscb is offline   Reply With Quote
Old 01-11-08, 02:17 PM   #10   |  Link
olinda cat
Both of these are on my short list, and would love to see how convergence and sharpness compare.Thank's John
olinda cat is offline   Reply With Quote
Old 01-11-08, 02:21 PM   #11   |  Link
st_o_p
And noise
st_o_p is offline   Reply With Quote
Old 01-11-08, 02:22 PM   #12   |  Link
foofoobar
BTW, I made my choice using a totally unscientific and subjective "je ne se qua" feeling, using two uncalibrated PJs.
The reason for asking for suggestions was that I may not be as discerning as some of you. If you know any specific shots in certain movies that might help you make a choice between A and B, please let me know.
I was planning on capturing the screen shots tonight and hopefully the environment will work for the "other projector" that has been already been dismounted.
Old 01-11-08, 04:17 PM   #13   |  Link
Ishmael198
I don't think many will make their decision based on your screen shots, more interested in what you have to say.
Old 01-11-08, 04:57 PM   #14   |  Link
rsprance
Why don't you just tell us what you prefer? Many people are waiting to buy one of these and it would be helpful. We don't come for the suspense, we come for the knowledge!
__________________
Rob
"The Arthouse"..MY HT Thread
http://www.avsforum.com/avs-vb/showthread.php?t=897055
rsprance is offline   Reply With Quote
Old 01-11-08, 05:43 PM   #15   |  Link
Wilson-Flyer
AVS CLUB MEMBER
You got that right.
I'm ordering one or the other in the next 3-5 days. Tired of waiting. I'd like to know what the guy thinks and I'd like Art to get his dang review posted for the UB.
__________________
Where are we going and why am I in this handbasket!
Wilson-Flyer is offline   Reply With Quote
Old 01-11-08, 06:03 PM   #16   |  Link
TenaCJed
Originally Posted by Wilson-Flyer View Post
You got that right.
+1 and +1
__________________
What a long.... strange trip it's been!!!
TenaCJed is offline   Reply With Quote
Old 01-11-08, 06:28 PM   #17   |  Link
tdsandme
I would like your opinion on which one has less motion blur with fast camera pans.
tdsandme is offline   Reply With Quote
Old 01-11-08, 06:45 PM   #18   |  Link
bass addict
witty statement here
bass addict's Avatar
AVS CLUB MEMBER
Classified Rating: 100% (6)
If I wanted suspense I'd read a book. Post your impressions already.
__________________
HT isn't a hobby, it's a sickness (just ask my wife).
bass addict is offline   Reply With Quote
Old 01-11-08, 07:09 PM   #19   |  Link
KBMAN
Advanced Human Being
Classified Rating: 100% (2)
Well, I haven't seen the panny, but I couldn't imagine that the picture could get any better with my TW2000, aka Epson 1080UB. The epson is PLENTY BRIGHT and the colors just dance off the screen. Sharpness is great, but more film-like, which is what I was looking for. It IS sharper than your typical cineplex. Epson has less problems and is built to last! Black levels are scary-good. Just my .o2
Ter
__________________
Terrence
"Hey Vasquez, have you ever been mistaken for a man...."No, have you?"
KBMAN is offline   Reply With Quote
Old 01-11-08, 07:11 PM   #20   |  Link
KBMAN
Btw,
The Poster Should Be Shot. Just Kiddin
__________________
Terrence
Old 01-11-08, 07:19 PM   #21   |  Link
RobZ
RobZ's Avatar
AVS CLUB MEMBER
Classified Rating: 96% (22)
Most of the current crop of 1080p projectors are excellent in bright scenes. The $1350 Mitsubishi HC4900 is even top notch in that department. I want to see what the Epson can do with black and shadow detail. The VW60 is very good when the iris is choked down, the AE2000u is close. How's the Epson with movies like Underworld or Dark City? I'm tired of comparing my projectors to the 34" Sony CRT in my bedroom!
__________________
My "Who Says You Need A Dedicated Room?" HT Thread
Pioneer Elite PRO-FPJ1(RS2),9ft Wide HP,Panasonic Plasma,Klipsch THX Ultra II,SVS PB13 Ultra, Hsu MBM-12
RobZ is offline   Reply With Quote
Old 01-11-08, 07:40 PM   #22   |  Link
Brajesh
Classified Rating: 100% (35)
These two PJs are on the top of my short list, with the Mits HC4900 being the wildcard for nearly $1,300 less! Looking to upgrade to 1080p from my 720p Mits HC3000U, which already set the bar pretty high for my next PJ.
__________________
HDMedia Fan
Brajesh is offline   Reply With Quote
Old 01-11-08, 07:48 PM   #23   |  Link
ricwhite
Personally, I don't think it's a hard choice. I think the Epson (from what I have read) is a notch above the Panasonic. The better battle would be between the Epson 1080 UB and the Mitsubishi HC6000. That one is a toss-up, I would think.
I just received my 1080 UB and I'll be watching some movies tonight. Unlike the OP, I'll post my impressions and feelings as soon as I have some. This "I'm not going to tell you yet" crap is rather ridiculous.
ricwhite is offline   Reply With Quote
Old 01-11-08, 08:03 PM   #24   |  Link
42Plasma
Look forward to your input and feedback Ric.
My freind and I are both waiting to order a new projector., possibly the Epson.
Old 01-11-08, 08:46 PM   #25   |  Link
bass addict
AVS CLUB MEMBER
I agree, it's not the third grade. The only shortcoming I can see with the UB, is lack of VS, oh and the fact you can't get it in black. I love my TW700 and were it not for the fact of foreseeable SDE w/ the move from a 96" 1.78 to a 130" 2.35 I wouldn't feel the need to upgrade. It certainly helps that Epson's CS is top notch.
While I liked my AE900 for the little while I had it, the glaring QC issues on Panny's latest crop of PJ's is very disconcerting.
__________________
Old 01-11-08, 09:07 PM   #26   |  Link
RobZ
RobZ's Avatar
AVS CLUB MEMBER
Doesn't the 1080UB have the D7 LCD panel and the Mitsubishi a D6?
__________________
Old 01-11-08, 09:46 PM   #27   |  Link
ricwhite
Yes, but the Mits is getting very good preliminary reviews -- even with the D6 panels. There is some talk about a new Mitsubishi HC6050 that has the D7 panels.
Old 01-11-08, 09:49 PM   #28   |  Link
RobZ
RobZ's Avatar
AVS CLUB MEMBER
Good news for future buyers but that sucks for those getting ready to buy the 6000.
__________________
Old 01-11-08, 10:40 PM   #29   |  Link
jstaylor83
This is a novice question but what does "film-like" really mean? What does something look like when it is "film-like" as opposed to not "film-like"?
jstaylor83 is offline   Reply With Quote
Old 01-11-08, 11:21 PM   #30   |  Link
Lance S
"Filmlike" means that it is not over-sharp. There are PJ's available that have such a sharp image that it is considered by some to be over sharp or un-"filmlike". Film has a tendency to be more of a smooth picture, one that flows more and is not quite as rigid as some of the PJ's offered.
Lance S is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.33193803 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
