AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 01-16-08, 08:44 PM   #1   |  Link
aerial1
Smile Fox 36 FT. Wayne
Watching WFFT 36-1 in 1080i on Sunday during the football games was stunning. In fact digital artifacts was not noticeable compared to the three networks doing multicasting which were prevelant. I know that the transmission antenna is only 212 feet above ground. And 970 watts of power. How good or how far would that 970 watts travel at 735 feet? Installing xg-43 antennas has worked out well in most cases. In fact tuesday evening a medium signal was still working at State road 101 just 1/4 mile south of Antwerp road. This location according to the polar plot of dt 36 is the cut off point . I am impressed no pre-amp no distribution amplifiers and a two way splitter is in place. The only odd component is I used rg-11 from the garage roof to the basement of the house. Also a highband yagi is aimed at dt-12 with a channelmaster VHF/UHF mast mounted combiner between the antennas.
aerial1 is offline   Reply With Quote
Old 01-17-08, 07:59 AM   #2   |  Link
foxeng
Nitwit TV Engineer
FOX broadcasts at 720p, not 1080i. Your display may be set for 1080i, but the signal you are receiving is at 720p and your system is converting it to 1080i.
__________________
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers.
foxeng is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.09596896 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
