AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 01-29-08, 11:53 PM   #1   |  Link
dballard125
New Member
Problem with 42" HP Plasma
First let me say that this plasma is for our bedroom so I dont have a high def (DVR) box. I only have the coax cable from our cable provider fed directly into the TV. I also have a DVD player fed into the TV with an HDMI cable.
I am having two problems:
1) On Fox HD (which is local channel 41-1) I get a wierd noise from time to time. I can't even explain the noise but it usually occurs during crowd noise (during a ballgame) or when music is played. It is a wierd "buzzing" type noise. The TV has done this from day 1. It only happens on this channel.
2) When I first ran the TV set up, I received all local HD channels, which are3-1 (NBC), 11-1 (CBS), 15-1 (KET), 32-1 (NBC), 41-1 (FOX), and 58-1 (PBS) locally. Then one day I turned the TV on and suddenly didn't have 11-1 (CBS HD) anymore. I ran the TV set up again but I can't get the channel to come in anymore. I type in 11-1 on the remote and it automatically goes to channel 11, which is a an analog channel.
I have a 65" Toshiba DLP in the basement. I have the cable fed into a DVR box. Then an HDMI cable from the DVR box to the TV. The picture and sound is perfect. I get no noise on FOX HD on that TV and I get CBS HD with no problems.
Could my issues with the HP 42" plasma be caused because I don't have a High Def (DVD) box...or could it be a problem with the TV...or could I have the settings wrong somehow?
Thanks in advance for your help
dballard125 is offline   Reply With Quote
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.07105708 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
