AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > HDTV Programming
Forum Jump
Old 01-30-08, 03:55 AM   #1   |  Link
mrvideo
What Does Your Fox Affiliate Bug Look Like?
A discussion has come up in another thread about the Fox affiliate bug that shows up in the lower right of the HD image. Because of the unique "splicer" that Fox uses at each affiliate, it can be loaded with a graphic of the affiliate's bug of choosing. Of course, there are restrictions. The current Fox standard for bug size and placement is shown in the single page PDF:
http://vidiot.com/Fox_HD_Logo_Specv4.2.pdf
Even though it is the latest, it contains an error that they appear to have not noticed and fixed. The 719 value on the far right side is really 709.
I'm building a collection of all the Fox affiliate bugs on a web page:
http://vidiot.com/cgi-bin/FoxBugs.cgi
Right now it only contains my local affiliate bug. When you hover the cursor over the logo, the station's call letters and city of registration will be shown. How that is done is browser dependent.
As indicated in the spec, the bug is no larger than 5000 pixels and is 96hx80v. The upper left corner of the bug placement area is 1120hx630v.
Here is what I need in order for the image to make the repository:
1) Capture a Fox program with the local bug on screen. An OTA ATSC card in a computer is the best way to capture some of the program. Try and capture some video where the background is dark.
2) Use a program, like VideoReDo to extract a frame.
3) Use a program , like Photoshop, to extract a 96 pixel wide by 80 pixel tall area of the image, starting at 1120h 630v (reference 0 is in the upper left).
4) Save the image as a TIFF, BMP or PNG (JPEGs are too lossy).
5) Put the 96x80 image in a zip file and e-mail it to me (vidiot at vidiot dot com), along with the station's call letters and official FCC city of registration. Use a subject of "Fox bug image" to grab my attention.
I'll then add it to the collection of images.
The reason for the complete 96x80 area is to see where Fox has been placing the images in the splicer, i.e., are they always using upperleft, or starting further down.
If you can't edit the 1280x720 image, you can send me the whole thing and I'll extract the image.
Please, no digital photos of your monitor, TV, etc. That does not provide for an accurate extraction of the bug image. It needs to be a direct ATSC transport stream capture and still image extraction. I know, not everyone can do that. But maybe you know someone who can. Have them do it for you.
Let's see if we can get all of the possible Fox affiliate bugs captured and see which are the best for being viewer friendly, i.e., really transparent, or really opaque and/or ugly.
__________________
Mr. Video
My Geek Images
Dakota: Loving K9 companion [Jan 93 - 9/22/08] - You are missed.
mrvideo is offline   Reply With Quote
Old 01-30-08, 07:56 AM   #2   |  Link
foxeng
Nitwit TV Engineer
The stations create the bugs and then send them to FOX for uploading in the splicer. FOX doesn't create them. FOX has nothing to do with them. There is no commonality to them. Not every FOX affiliate's bug is wider than taller (such as the O & O's) and the station may have put the bug within a box that fits the splicer window thereby changing the size and location of the bug while still meeting the specs.
Bottom line, every bug is going to be a different size in a slightly different position on the screen that is a given and a known. FOX never sees the bug at anytime. Only the size of the file and the dims of that file. It is up to the station to be sure it looks correct on air.
__________________
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers.
foxeng is online now   Reply With Quote
Old 01-30-08, 09:34 AM   #3   |  Link
HofstraJet
Member in Hiding
One of my local Fox affiliates, WFLX West Palm Beach, FL, has to switch to SD to show their bug. Any ideas why? It is my understanding that with the splicer, this should not happen.
__________________
The grapes are free! The US Supreme Court finally ruled in our favor.
HofstraJet is offline   Reply With Quote
Old 01-30-08, 10:32 AM   #4   |  Link
Clarence
-o|||||o-
Clarence's Avatar
AVS GOLD CLUB MEMBER
Classified Rating: 100% (2)
Wow. That's lot of specific rules. I'll try to capture one later in accordance with your demands, but for now, here's Fox 5 in DC from a jpg framegrab I posted last week in the Sarah Connor Chronicles thread:
http://www.avsforum.com/avs-vb/showt...0#post12919640
I was planning to recapture that frame anyways to investigate the combing/interlacing artifacts.
__________________
Galleries: Canon 1D Mark II, 40D, T1i/500D, and XTi
My G90
Clarence is offline   Reply With Quote
Old 01-30-08, 10:34 AM   #5   |  Link
jpr281
WNYW New York
http://upload.wikimedia.org/wikipedia/en/7/7c/Wnyw.png
EDIT:
jpr281 is offline   Reply With Quote
Old 01-30-08, 10:47 AM   #6   |  Link
foxeng
Nitwit TV Engineer
Yes, the bug is in the splicer. If the station wants to show additional information then the splicer has to come off line.
__________________
Old 01-30-08, 11:03 AM   #7   |  Link
HofstraJet
Member in Hiding
I will note when it happens again and take a pic and post it (no HTPC for screen caps).
__________________
Old 01-30-08, 11:18 AM   #8   |  Link
Ken H
AVS HDTV Moderator
Ken H's Avatar
Why?
There are approximately 180 FOX affiliates. Since they could conceivably all do something different, you better have lots of room on your server.
__________________
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline   Reply With Quote
Old 01-30-08, 12:43 PM   #9   |  Link
mrvideo
I never implied that Fox created them. I'm sure I specifically said that the affiliates created them. Though I never did say that they sent them to Fox, but I did say that Fox loaded them into the splicer.
According to the spec, the bug has to be 5000 pixels, or less, fit within a 96x80 box, with a key file of 80% white. I suspect that whomever handles the files uploaded to the ftp server will look to make sure that the image is within spec, then they will send it to the splicer. The upper left of the box will always be located at 1120x630, if they follow their own spec.
When the local bug was first loaded into the splicer it was loaded into the wrong location. The lower right corner of the 96x80 box was placed at 1120x630, placing the bug up and to the left from where it was supposed to be. For a long time I complained to the local station that the bug was in the wrong place. They kept saying they had nothing to do with it, which was kinda right. After I finally discovered the spec document, I sent e-mail to the Fox person that handled bugs at the time and with 48 hours, a new friendlier looking bug was created (same style, different coloring) and loaded into the correct location. As the Fox contact pointed out, they rely upon the station to look and make sure that it is in the correct location. They never did that for the initial load.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 12:48 PM   #10   |  Link
mrvideo
Huh? You get bug-free HD images (except when Fox puts up their transparent FOX bug during live programming)?
Are you saying that HD programming is screwed over with them going to SD?
But, you are right, they should have created a couple of BMP images (the fill and key files) and sent them to Fox for downloading into the splicer. All of the instructions, including the PDF that I referenced, are available for their staff to download.
I would contact their chief engineer and politely ask what the deal is.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 12:52 PM   #11   |  Link
mrvideo
Originally Posted by Ken H View Post
Why?
Too see what they look like, as mentioned in the first posting. I'm hoping they are all different. That is the point. To see who has the best and worst bug.
The 96x80 PNG files are only about 14k in size. That is only about 3MB total. That is a drop in the bucket on my server.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 12:58 PM   #12   |  Link
mrvideo
Needed to be specific, otherwise there wouldn't be commonality in what is presented.
What you have posted will work. I'll grab that image later when I am at home.
If you can send an updated image in non-JPEG, that would be nice.
What combing/interlacing artifacts? Fox is progressive, so where does interlacing come into play?
__________________
Mr. Video
My Geek Images
Old 01-30-08, 01:06 PM   #13   |  Link
machpost
You can find all sorts of screen caps on this page, just enter a zip code:
http://www.silicondust.com/wiki/hdhomerun/channels
machpost is offline   Reply With Quote
Old 01-30-08, 01:06 PM   #14   |  Link
GeorgeLV
KVVU - Fox 5 Las Vegas
(Cropped from this screen cap)
GeorgeLV is offline   Reply With Quote
Old 01-30-08, 02:14 PM   #15   |  Link
Erik Garci
(click for homepage)
I suppose they chose it to be just outside the 4:3 and scope areas.
Erik Garci is offline   Reply With Quote
Old 01-30-08, 02:32 PM   #16   |  Link
coyoteaz
KSAZ-DT Phoenix
coyoteaz is offline   Reply With Quote
Old 01-30-08, 03:46 PM   #17   |  Link
Ken H
AVS HDTV Moderator
Ken H's Avatar
The best and worst bug. Hmmm......
__________________
Old 01-30-08, 03:48 PM   #18   |  Link
Clarence
-o|||||o-
Clarence's Avatar
You don't see the jagged artifacts in the screengrab I posted?
Here's the Fox5-DC bug from the original screengrab:
For that one, I used VideoRedo then saved as jpg.
But throughout the frame, even though it's 720p, it looks like bad deinterlacing.
So I grabbed the frame again using VLC, saved as PNG and cropped out the Fox bug for you...
Much better IMHO and IAW your directions.
I'll PM you the link to the full frame PNG. It's 930Kb. I saved the PNG frame as a JPG and replaced the original screengrab which looked jagged.
"WTTG-DT"
WTF is "-DT"? Digital Television? Is that a new acronym to cover "TV+HDTV= DT"?
Or did they misspell "-DC"?
__________________
My G90
Old 01-30-08, 04:01 PM   #19   |  Link
jimp2244
DTV OTA Only!
"WTTG-DT"
Yes.
Analog call sign is WTTG-TV. Digital call sign is WTTG-DT. All stations call signs are formatted in this way.
jimp2244 is offline   Reply With Quote
Old 01-30-08, 04:12 PM   #20   |  Link
nickdawg
40 Ounce Casualty
They actually use that full color bug during HD programming? That sucks!
At least here in Cleveland it's a small text bug in the bottom right corner. The brightness isn't too bad.
FOX 8-1
WJW-DT CLEVELAND
D I G I T A L
__________________
Time Warner Cable-NE Ohio
SA 8300HDC-->ODN 3.1.3_2
SA 4250HDC-->ODN 3.1.3_2
LUCK FETTERBOX: JUST SAY NO TO WINDOWBOXING
nickdawg is offline   Reply With Quote
Old 01-30-08, 04:17 PM   #21   |  Link
nickdawg
40 Ounce Casualty
I checked that site and I found a 16:9 picture from WJW w/ the bug.
__________________
Old 01-30-08, 04:34 PM   #22   |  Link
mrvideo
Originally Posted by jpr281 View Post
That is their logo, but not what is physically displayed on the HD video via the splicer.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 04:40 PM   #23   |  Link
mrvideo
All images are not full sized and appear to sample local programming, no network programming. The fact that they aren't full sized precludes their use.
Nice idea though.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 04:44 PM   #24   |  Link
mrvideo
As indicated in the logo PDF, the upper left location is one pixel to the right of the 4:3 area and one pixel down from the cinemascope letterbox area.
Fox did put some thought into the size and placement of the bug.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 04:46 PM   #25   |  Link
mrvideo
I know, an oxymoron, considering that all bugs are bad.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 04:51 PM   #26   |  Link
foxeng
Nitwit TV Engineer
As I said, and I deal with this EVERYDAY, the actual size and position of the bug can float within the window if the station wishes to make it smaller and move it within the window. There is nothing to say that a station can't make a file the required size and within that place a smaller bug. It has happened and will happen again.
I know what the memo says from FOX. There were two copies and you have the later version. I have the both versions.
__________________
Old 01-30-08, 04:58 PM   #27   |  Link
mrvideo
I looked at it very quickly when I was home for lunch and definately had a problem reading the text in the bug. I wondered what was up with that.
What version of VideoReDo, since I use that all the time for doing screen grabs (Ctrl-C saves as BMP). As you can see from the Fox47 bug that is on the web page, I've never had VRD screw up a screen grabs. Maybe it is a display setting in VRD that is messing you up.
I've never gotten VLC to do a frame grab for me. I tell it to frame grab, but can never find where it placed the image, nor has it asked me for a file name or a place to put it.
Does indeed look better. It has to be a VRD display issue. All of the images on this web page (the ones used for the stupid snipe diatribe) are all done with VRD:
http://vidiot.com/TVShows/
"WTTG-DT"
It is a FCC designation for the digital transmission. It is a way for the station to separately designate their digital channel, so it is indeed Digital Television.
They might be able to drop the DT once analog is turned off and they only have a single channel.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 05:00 PM   #28   |  Link
mrvideo
The -TV doesn't have to be used. I suspect that the -DT will also go away not too long after the analog channels are turned off.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 05:02 PM   #29   |  Link
mrvideo
Yep. AFAIK, most Fox affiliates have full color bugs.
You are one of the lucky few.
__________________
Mr. Video
My Geek Images
Old 01-30-08, 05:07 PM   #30   |  Link
mrvideo
Interesting. Figures that the couple of zip codes that I put in didn't have full sized images.
The site needs a city search, not a zip code search, as I have no clue regarding various city zip codes.
I'll use it until a better copy comes along. Thanks for finding it.
BTW, that is the way those bugs should look.... dim gray transparent. It is unfortunate that Fox allows the bugs to be full color. Someone must of that that would be neat. Think again.
__________________
Mr. Video
My Geek Images
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.38639402 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
