#1 | Link |
AMD's RS780 integrated graphics chipset was recently released in China. The word is that there are still existing driver issues with respect to CrossFire support. However, all indications seem to confirm one can view HD content without the need for a powerful processor.
Gigabyte GA-MA78GM-S2H Pics http://www.bit-tech.net/news/2008/02..._igp_and_sb700 Jetway PA78GT3 Benchmarks http://www.ocworkbench.com/2008/jetway/PA78GT3/b1.htm |
#5 | Link | |
So if the HD 2400, or 780G, or HD 3450, had problems with 1080i MPEG2, it would have problems displaying it on a 1080P TV correct? |
#6 | Link |
never heard of these guys, but one more 780g mobo, apparently overclocking the IGP to 1GHz and with 64MB sideport mem installed. should be no shortage of mobo options for 780g in a few months
![]() http://www.jwele.com/news_detail.php?39&id=253 Last edited by dougri; 02-01-08 at 06:56 PM.. Reason: forgot link |
#7 | Link |
It really sounds great! Gaining acceleration for all video formats at full resolution is a great addition. The 55nm process technology along with PowerPlay will give a very nice power consumption.
Which CPU to choose:
#8 | Link |
I'm going for the cheapest, lowest power, multicore am2 CPU I could find... which in my case was an x2 3800+ EE SFF on craigslist for $50 (admittedly a steal), TDP of 35w and should run at about 10w during hd playback with the 780G chipset
If its not enough, I'll wait for the 65w quad core phenoms (9100e/9150e) and build a low power media server with the x2. I'd go for the be-2400 otherwise... I like to keep things quiet.Last edited by dougri; 02-02-08 at 12:47 AM.. |
#11 | Link | |
There's no way I'd touch a 2400 series when the 3400 series is out and replaces it and is supposedly able to handle 1080i sources better (the 2400 couldn't to save it's life). |
#12 | Link | |
#13 | Link | |
I have my HDTV hooked up to a 2 year old nVidia 6150 chipset and I do find the interlacing artifacts annoying. Which players takes advantage of this HW capability? |
#14 | Link | |
Any codec that is AVIVO enabled such as Cyberlink's decoder from PowerDVD Ultra. The deinterlacing mode is a setting in ATI's control center. |
#16 | Link | |
![]() The first benchmark tests with 780g (Hd3200) and bluray/hddvd discs are simply awesome... Less than 25% average CPU load on H264/MPEG4 AVC bluray disc with ~28 mbps bitrate................................ about the same with VC-1!!! WITH AN SINGLE CORE ATHLON 3500+ (!!!!!) ![]() Less than 10% CPU load with a X2 5000+ (!!) Now we're talking.... The BE-2300 I'm planning on for my HTPC rig will work perfectly!! A friend of mine has the same rig with a 690g board as I plan to build. Antec Fusion Scythe Mini Ninja (developed with close co-op between Scythe and Antec especially for the Antec all of you should know) BE-2300 oc'ed to about 2.1 GHZ 2 x Noctua 1200 mm 800's run on LOW (800 rpm) <8 db per fan (for real!) No fan on scythe mini ninja, all passively cooled by one of the Noctuas in the Antec fusion side wall. 100% load on CPU for 6 hours resulted in 45 degrees celsius on the CPU!! ![]() Too good to be true. The Gigabyte GA-MA78GM-S2H is the dream HTPC card. 780g+SB700+ALC889 is simply too good to be true!!! It is released around Cebit show, that is end of Februaru/beginning of March. Simply worth the wait for me.. Then I put a Silverstone nightjar, damp the hdd and optical drive a bit, isolate the chassis etc in my rig and the only fans running will be two 800 rpm Noctuas at <8 db per fan. DEAD SILENCE anyone?? ![]()
__________________
The Treble 1999 - Manchester United - The pride of ALL Europe! |
#17 | Link | |
![]() Looks like a great motherboard from the specs ![]() |
#18 | Link | |
More info:
#19 | Link |
Does the 780g accelerate MKVs?
I found two statements: 1. The 1080p .mkv files would be fine. But for Blu-ray/HD-DVD, you should spend more on the CPU, or add in a graphics card (GPU) which provides hardware decoding such as an ATI 2400 or 2600 for example. 2. A French site that I can't understand the translation http://translate.google.com/translat...%3Den%26sa%3DG Edit: also found- The IGP on the RS780 is the first chipset to support DirectX 10 and Unified Video Decoder (UVD) 2.0 for H.264 and VC-1 decoding Is H.264 the same as x264?
__________________
An addendum to a foundational law of physics states that “common sense and a government agency cannot occupy the same space at the same time” Last edited by grittree; 02-06-08 at 07:57 PM.. |
#20 | Link |
Yes.
H264 is the actual standard. X264 is an implementation of a H264 encoder. http://en.wikipedia.org/wiki/X264 |
#21 | Link | |
http://www.avsforum.com/avs-vb/showt...7#post12473507 http://forum.doom9.org/showthread.php?t=132924 |
#22 | Link |
So the results are the same with the rs780 as with ATI cards with UVD2. It depends on the encoding.
So it would be fair to look at the speeds, etc of the 780g chip and compare them to the various ATI 3x00 cards?
__________________
An addendum to a foundational law of physics states that “common sense and a government agency cannot occupy the same space at the same time” |
#23 | Link | |
any opinions? anyone??? maybe gigabyte cut-n-paste from the 690g manual? according to their 690g mobo manuals, the cpu requirement is the same... seems like an editing oversight to me. Last edited by dougri; 02-07-08 at 01:46 AM.. |
#24 | Link |
There are several tests on ocworkbench, fudzilla etc if you're looking for reliable high bitrate 1080p playback reviews with CPU load specs.
Here is the one I referred to earlier in this thread... (the one with the single core athlon 3500+) ![]() I'm impressed anyway, and would be very suprised if my BE-2300@2.1 GHZ couldnt handle BD/HDDVD with the new Gigabyte board... are there any reasons it wouldnt handle it???
__________________
#26 | Link |
@ dougri: you could be right: it could be a Gigabyte "copy/paste job" from another manual
Anyway I doubt it will fully support off-loading of MKV x264 playback, though off-loading might also have something to do with the way (which level etc. ) MKV x264 files are encoded. Also UVD 2.0 might have an edge over 1.0 hopefully. Looks like a nice mainboard nonetheless, we'll just have to wait and see when it hits the shelves (AFAIK it's not out on the market yet) PS: you can download the manual from the Gigabyte site |
#27 | Link | |
"worldwide launch of these products has been postponed to March 5, according to sources at motherboard makers." |
#29 | Link | |
But I guess we'lll all just have to wait and see. If the RS780 don't meet your demands you could always get a passively cooled ATI Radeon HD3450 to run together with the IGP and use hybrid crossfire. ![]() Allthough coming to picture quality and offloading CPU on bluray/HDDVD disc playback I'm confident we all will be amazed by the results of the 780' ![]() Around Cebit time they claim the Gigabyte card will be available. About three weeks away... Hate waiting! ![]()
__________________
| Bookmarks |
| Thread Tools | |
