#661 | Link |
This is false...I am downloading the 2.0 update for the HD-A30 from Toshiba's site right now. From what everyone is saying...I will first install 1.3 which I downloaded from the sticky on this forum...1.1 clearly isn't up to par for me. |
#662 | Link |
That One
Not "false"...just incomplete, apparently. As post #658 indicated, it looks like you can also access the old f/w via the old "Recent Notices & Updates" path, which I didn't notice or peruse initially. However, as my link also indicates, if you follow Tosh's revamped path (starting with the "Seach By Product Type") it only references v1.3. Clearly, as Hankus aptly put it, the end of the format war has indeed lead to Tosh providing contradictory or confusing information both on their website and via telephone. Still, the point is the same: Even though v2.0 is still on the site in one location, someone at Tosh did in fact make some changes to the Customer Support page and pulled v2.0 on another part of the site.
__________________
Sony KDS-60A3000 Onkyo 805 (v1.08 w/DSP, HDMI) Toshiba A35 (v4.0) Sony PS3 40GB (v3.15) Carver Cinema Series (Digital 7.1) Polk R50 (Zone-2/Analog 2.0) Boston 595x subs My DVD Collection |
#665 | Link | |
out on bumblee and I did not see any jaggies with 3.0. My tv accepts 1080p/24. Some are saying the XA2 is not fixed with 3.0. |
#667 | Link | |
I just checked the Toshiba site, and they still have the 2.0 version available for DL
__________________
You are damaging my calm... - Jayne Cobb |
#669 | Link |
Streaming HD
I downloaded 3.0 for my A-35 and A-2 last night.
__________________
HD-DVD: 115 Blu: 6 Latest HD-DVD: All of them at Frys for under $10. Latest BD: No incentive to pick up discs now that the format war is over. Netflix via xbox and mail is more that sufficient. |
#670 | Link | |
Grumpy Member
It sent me 3.0 for my A35!!
Now we see what it helps! ![]() Or hurts! ![]() ![]() Update: Well I still see Jaggies and imperfections if I use 1080p 0r 1080p/24 vs. setting the player to 1080i. This is on the HQV test disk. My TV is a Mitsubishi 65833. Maybe it's just that TV is better at deinterlacing than the player??
__________________
Joe in West Los Angeles, CA Last edited by joe221; 06-18-08 at 03:19 PM.. |
#673 | Link | |
![]() Joe221, Did you have jaggies before (@1080/24p w/ v1.3)?
__________________
#676 | Link | |
Grumpy Member
I find it amazing that the image is almost perfect forcing 1080i but breaks up at 1080p or /24. Oh well.
__________________
Joe in West Los Angeles, CA |
#677 | Link |
After trying four different brands of ISO burning software, I finally found one called BurnQuick that would make a CD with my Lite-on burner. However, shortly after I began the update process, my A3 returned the error message "2007 c00f." Does anyone know what in the world that means? I sure would appreciate a translation, if so. Thanks.
#678 | Link | |
#679 | Link | |
#680 | Link |
The problem introduced in the 2.0 firmware is related to 24p playback of AVC encoded content. Paramount released several titles using AVC, including Transformers and Next. The problem shows up very obviously on the Paramount Pictures logo at the beginning of these films. Look at the stars as they "fly" in around the mountain. The new firmware does NOT fix this problem.
#681 | Link | |
bob |
#682 | Link | |
Grumpy Member
Also my TV is 1080p (DLP) and capable of 24Hz and 120Hz. I've tried turning advanced picture settings on and off to no avail.
__________________
#683 | Link | |
That One
Not that I consider myself a "guru" by any means, but in a nutshell, the player has a problem deinterlacing AVC-encoded HD DVDs at 24Hz (and, for some, at 60Hz) with v2.0 (some say with v3.0 as well); hence, all the "jaggies." With 1080i, there is no deinterlacing being done by the player, in which case the deinterlacing is being done by the display, which may or may not improve things depending on how well the display deinterlaces. ![]()
__________________
#684 | Link | |
Grumpy Member
Does anyone else here have the HQV Benchmark HD-DVD?? If so what are your results? http://www.hqv.com/benchmark.cfm
__________________
#685 | Link | |
Cranky Member
Whatever is at fault here must be happening at the decoder. The player no longer decodes AVC discs correctly when set for 1080p24 output (which should read the data directly from the decoder without going through the deinterlacing or scaling).
__________________
Josh Z Critic, High-Def Digest Contributor, Home Theater Magazine Curator, Laserdisc Forever My opinions are my own, and do not necessarily reflect those of my employers. |
#686 | Link | |
That One
(By the way, I'm a big fan of your contributions over at HighDefDigest.com )
__________________
Sony KDS-60A3000 Onkyo 805 (v1.08 w/DSP, HDMI) Toshiba A35 (v4.0) Sony PS3 40GB (v3.15) Carver Cinema Series (Digital 7.1) Polk R50 (Zone-2/Analog 2.0) Boston 595x subs My DVD Collection Last edited by BasicBlak; 06-19-08 at 05:38 PM.. |
#687 | Link | |
IT"S NOT JUST 1080/24P !!!!!!!!!!!!! bob |
#688 | Link | ||
Cranky Member
1) The scaling chip is somehow correcting this jaggie problem after decoding. I find this unlikely, because the A35 and XA2 use very different processing chips. 2) Changing the resolution output in the player's setup menu affects more than just the resolution output in the scaling chip, but also has some side-interaction with the decoder. Considering how screwy the audio settings are in the player (e.g. changing the SPDIF output format from Bitstream to PCM also turns on and off speaker and bass management in the multi-channel analog connections), option 2 seems the most likely. Quote:
__________________
#689 | Link | ||
That One
__________________
#690 | Link | |
I've been running 1.3 fw since I've had my players (A35's for 8 months), and have had issues with only two discs...up until three weeks ago.
Becasue of the sales I've purchased dozens of discs, and over the past three weeks, I've had one disc that could not be read, and five others that started, but then froze and I could not bypass via ff/skip/pause...anything. I've also had two discs that froze, but that I was able to ff past (the freeze). Can anyone ascertain that 2.0 fw will resolve some of these problem discs (btw: they are all new), and if so, can I still have Toshiba forward me a copy? Thanks. |
| Bookmarks |
| Thread Tools | |
