AVS Forum
Google™ Search AVS:
Go Back   AVS Forum > HDTV > Local HDTV Info and Reception
Forum Jump
Old 02-17-08, 01:13 AM   #1   |  Link
a1011000
New Member
San Francisco/Sacramento, CA OTA
I am in a difficult situation. I have been using Analog OTA for the past 5 years and after hearing about the Analog Shut off I went out and bought a digital TV with SDTV not HDTV. I live in the Diablo Valley area in the bay area and I recieve mostly Sacramento stations much better than San Francisco stations on Analog due to the amount of hills. Well I hook up my rabbit ears on the roof that I had been using for almost perfect Analog reception from Sacramento about 35 miles away and I scan for digital stations and I get NOTHING but the Spanish Stations, 14.1, 42.1, 48.1/2, 64.1. And at night I might get 36.1/2 which is English but it drops out so much that it is unwatchable. But on Analog I get with near perfect reception 3, 6, 10, 13, 14, 36, 42, 48, 64 and with resonable to bad 2 ,4 ,5 ,7 ,9 ,11 , 22, 26, 54, 58, 40, 31, 66. I am unable to put a big antenna up, and again im using rabbit ears mounted on a 2x4 on my roof, 35 miles from the Sacramento transmitters, and about 25 miles from the San Francisco transmitters. Antenna web says I should be able to get digital stations: Red: 11.1, 64.1, Violet: 14.1. Is there anything that I can do to get these stations or at least some of them? Also for Cheap?
a1011000 is offline   Reply With Quote
Old 02-17-08, 01:55 AM   #2   |  Link
MJCS
Why cant you put up a big antenna?
MJCS is offline   Reply With Quote
Old 02-17-08, 02:03 AM   #3   |  Link
a1011000
New Member
Because I am a teenager and my dad won't let me put up anything more than rabbit ears, I have a bigger antenna, Channel Master Somthing that was up for awhile but my dad made me take it down, I could set it up but the highest I could put it wouldn't be higher than the gutter. So I don't know would that help at all? Im not sure if it even works anymore, I tried hooking it up a few months ago but I didn't get any channels except the spanish stations that I would get with an Indoor Antenna. But I can try again with a different transformer.
Old 02-17-08, 02:46 PM   #4   |  Link
milt9
i live in walnut creek about 600 ft el. i have a silver sensor (uhf) indoors and receive about 8 sacto digital stations.
milt
milt9 is offline   Reply With Quote
Old 02-17-08, 08:59 PM   #5   |  Link
a1011000
New Member
I just did some reaserch and found out that most Digital stations broadcast on UHF rather than VHF (3 broadcasts on 35.1). So I was able to take off the UHF part of my bigger antenna that wasn't set up, and I was able to attach it on the 2x4 that my rabbit ears were on and now I get alot more English stations, 3.1/2, 10.1/2, 13.1, 58.1. And Compared to the rest of the Diablo valley Im in a pit with hills all around my house blocking all but Mt. Diablo. But now I'm getting somewhere with digital.
Forum Jump
Bookmarks
Load Balanced and Protected By
Hosting Services Powered By
Page generated in 0.11683798 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1995 - 2009 AVS Forum.com, Inc. - All Rights Reserved. No information may be posted elsewhere without written permission.
