#1 | Link |
Picard was a fool!
The Yamaha RX-V663 thread. HDMI 1.3 upconversion, TrueHD, DTS MA decoding.
![]() ![]() ![]() http://www.yamaha.com/yec/products/p...TE&VNM=WORKING HDMI upconversion of all analog souces. 1080p60hz, 1080p24hz support, Dolby True HD and DTS Master Audio support. Even has a surprise output for 2 subwoofers with possibly seperate level controls! RX-V663BL 7.2-Channel Digital Home Theater Receiver NOTE: The HTR 6160 is the same receiver as the V663! High-Performance Home Theater Receiver features full support for HD audio formats, HDMI video up-conversion and de-interlacing, iPod and Bluetooth audio compatibility, improved YPAO, Adaptive DRC (Dynamic Range Control), multi-zone custom installation facility, and four SCENE buttons. MAIN FEATURES High Sound Quality HD Audio format support: Dolby Digital Plus, Dolby Digital TrueHD, DTS-HD High Resolution Audio and DTS-HD Master Audio 7-channel 665W powerful surround sound (95W x 7) Digital ToP-ART and High Current Amplification Pure Direct for higher fidelity sound reproduction Burr-Brown 192kHz/24-bit DACs used in all channels Assignable amplifiers for bi-amp connection Advanced Features 4 SCENE buttons offering greater operating ease (with 18 preset SCENE templates) XM ready with XM HD Surround powered by Neural Surround SIRIUS Satellite Radio ready Improved YPAO for automatic speaker setup iPod compatibility via Yamaha Universal Dock Bluetooth (A2DP) compatibility with Yamaha Bluetooth® Wireless Audio Receiver (YBA-10) Superior multi-zone control compatibility High Picture Quality 1080p-compatible HDMI (2 in/1 out) Supports Deep Color (up to 36 bit), x.v.Color, a double speed Refresh Rates of 120Hz and 1080p/24Hz transmission, and Auto Lip-Sync compenzation Analog video to HDMI digital video upconversion and deinterlacing with TBC Surround Realism • Fine-tuned CINEMA DSP and Adaptive DSP level Improved Compressed Music Enhancer Adaptive DRC (Dynamic Range Control) Other Notable Features XM Satellite Radio ready with XM HD Surround powered by Neural Surround SIRIUS Satellite Radio ready 40-station preset tuning / Auto preset tuning HD Audio LPCM 7.1-channel reception (up to 192kHz) High dynamic power and Linear Damping Low Jitter PLL Circuitry Assignable amplifiers for bi-amp connection Initial Volume and Maximum Volume Setting iPod song titles displayed in English and Western European languages ISO 8859-1 (Latin 1) on the front panel and on-screen display SILENT CINEMA and Virtual CINEMA DSP Dialogue Lift for dialogue to screen center Preout terminals for front, center, surround and surround back, and dual mono subwoofer out 9 selectable subwoofer crossover frequencies Subwoofer phase select 8-channel or 6-channel external input Speaker A, B, A+B selection Preset remote unit
__________________
No animals were harmed in the creation of this sentence. |
#2 | Link | ||
Picard was a fool!
ADDED ON JUNE 26 08 Quote:
__________________
No animals were harmed in the creation of this sentence. Last edited by eightninesuited; 10-03-08 at 12:42 AM.. |
#4 | Link |
Some discussion of it here a few days ago:
http://www.avsforum.com/avs-vb/showthread.php?t=992866 I like the HDMI conversion (which I'm assuming implies OSD over HDMI). Edit: Found the manual here: http://www2.yamaha.co.jp/manual/pdf/.../RX-V663_U.pdf I didn't read the whole thing in detail, but I can't tell if it'll apply Dolby ProLogic IIx to LPCM or bitstreamed TrueHD/DTS-HD MA, it only states that it's for DD/DTS signals (p. 92, or p. 96 in my reader window). It does accept DSD like the 661. Last edited by Jack Gilvey; 02-18-08 at 08:04 AM.. |
#5 | Link | |
Bring both of the following links up side by side. This will show the differences between the new v663, v683, HTR-6160, and HTR-6180. It looks like the 683 and 6180 are identical. However, the HTR-6160 is actually rated at 10 watts more than the v663 and the 6160 has an HD radio tuner. Apparently, the newer HTR series are now slightly better than their v series counter part. Both series have the same msrp. V-series http://www.yamaha.com/yec/compare/De...p_items=567571 HTR series http://www.yamaha.com/yec/compare/De...p_items=567572 Last edited by mpgxsvcd; 02-18-08 at 11:52 AM.. Reason: Fixed Links |
#8 | Link |
The single coolest feature of this receiver is the new adaptive dynamic range control. If it works as advertised then this receiver will be a keeper!
It basically says that if the volume is low then the dynamic range will be narrow. If the volume is high then the dynamic range will be greater. So if you turn the volume down then it will make all of the really faint sounds a little bit louder and all of the loud explosions will be a lot quieter. However, as you turn the volume up the dynamic range affect will be reduced. Therefore, the quiet sounds will be quiet and the loud explosions will be just that, “loud”. I believe it does all of this without regard to frequency which is great. I want to hear all of the sounds I just don’t want any of them to get too loud. See page 89 of the manual for more details. This receiver also has a really cool new “initial volume” and “maximum volume” setting. Basically, the initial volume setting controls what volume the receiver is set to when it is turned on. That is perfect for my house where I listen to movies at -6 to -8 Db from reference and my wife and kids listen at about -36 Db from reference. Now I don’t have to remember to lower the volume when I have finished the movie. I can just set the initial volume back to -36 Db and then turn the receiver off. When my wife turns it back on then it will automatically return to -36 Db. The maximum volume setting just limits the receiver setting from going over the set value. It does limit the output level from going over a certain level like I had originally thought it would. The dynamic range control is actually what is used for volume leveling. At an MSRP of $549 this receiver is a steal! |
#11 | Link | |
Picard was a fool!
__________________
#16 | Link | |
Personally, I would rather have a nice new shiny Emotiva 7 Channel amp than one lousy extra HDMI input. Heck my TV only has one HDMI input anyway. That extra input on the receiver does me no good(video wise) because I still can only calibrate the single HDMI input on my TV. Heck for $1500(3X the price of the receiver but still less than the Yamaha 3800) I could pick up a nice 60” Sony 1080p SXRD! Now that would be a good buy! |
#17 | Link |
The Shrubber
Subscribed!
This is great news for me. I was going to blow my budget and and get a RX-V1800. Glad I waited.
I'm a little confused with the specs listed on the website though. Both the RX-V663 and HTR-6160 are listed at the same price, but the HTR has more wattage and has the HD radio tuner. Do you guys think the HTR is listed wrong? http://www.yamaha.com/yec/compare/De...p_items=567572 (hope the link works) So, these can be pre-ordered? I'm hot to dump my Sony HTIB receiver. ![]()
__________________
If it sounds good, it is good. ~ Duke Ellington Visit my site for gear and photos |
#18 | Link | |
If you check the HTR-6160 features it says it is 95 Watts per channel. I bet it is a type-O. |
#19 | Link |
Figured it out! Here is the HTR-6160, HTR-6180, and V663 comparison!
http://www.yamaha.com/yec/compare/De...p_items=567572 Just click the comparison link in stead of going into either the V-series page or the htr page first. |
#21 | Link | ||
The Shrubber
Man, I got a $50.00 best buy gift card burning a hole in my pocket. ![]() Do you guys think Best Buy will give the usual $100.00 of MSRP with a pre-oreder? Maybe I should wait??? I feel so week. ![]() Quick, somebody hide my wallet!
__________________
If it sounds good, it is good. ~ Duke Ellington Visit my site for gear and photos Last edited by Matt1966; 02-18-08 at 03:44 PM.. |
#22 | Link |
I just read through the entire V663 manual. Here are a couple of things I have surmised from it.
1. The OSD should work on any output type even HDMI. It does not have any disclaimers that it doesn’t work over HDMI. Either it works over HDMI or Yamaha is just asking for a lot of returns with this one! 2. There is an error code for “Too many HDMI devices connected”. That one scares me. I can only guess that there is a limit to the number of devices that can be connected to a switch that is connected to this unit. I don’t know how the receiver would know that information though? However, if there is a limit this could seriously hurt the adoption of this receiver. 3. It doesn’t look like there are separate controls for each sub woofer. It just looks like it splits the signal to two subs. Bummer, but not that big a deal. 4. It appears that you can not turn the OSD off. This might be a problem for me. I use HDMI currently but my receiver does not display the OSD over HDMI. Therefore, when I adjust the volume(Always louder) my wife does not see me do it. I can keep creeping the volume up in .5 Db increments and she won’t realize it until I have it about 4-5 Db louder. If the receiver always shows the volume on the screen then I am going to be in trouble. Can anyone post a picture of what the OSD looks like when you change the volume? Does it display the volume on screen every time you change it? |
#24 | Link | |
The Shrubber
I could be wrong and probably are, but I noticed on the Best Buy website the rx-v1800 is selling for $1199.95. The list price is $1299.95. I've noticed this with other similarly priced Yamaha receivers. The $999.95 receivers usually sell for $899.95. It probably doesn't work across the board though.
Ps Just noticed my typo. Quote:
__________________
#26 | Link | |
AVS CLUB MEMBER
#28 | Link |
I wonder if the 663 avoids two well-known LFE/bass management problems.
(1) LFE hole: Does the crossover apply to the LFE channel as well as to the non-LFE channels? If so, then setting a crossover chucks away the upper part (> crossover point) of the LFE channel. As of yet, I can't get an answer from Yamaha support on this with respect to my HTR-5990. To read up on the LFE-hole issue, look at http://www.avsforum.com/avs-vb/showthread.php?t=991439 (2) LFE boost: Does the 663 boost the LFE channel on PCM sent over HDMI? If not, then it is pretty much useless for PCM lossless tracks on HDM (unless your player can boost). According to Yamaha support, my HTR-5990 does not boost. To read up on the LFE-boost issue, look at http://www.avsforum.com/avs-vb/showthread.php?t=748147 Moreover, I also would like to know if the 663 can apply PLIIx to 5.1 True-HD/DTS-MA decoded in the receiver. |
| Bookmarks |
| Thread Tools | |
