SA8300, Time Warner, 1-min. offset, and truncated recordings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-02-2008, 08:28 PM - Thread Starter
levensteins's Avatar
I'm in Austin, TX, subscribed to Time Warner, using an SA8300. I have a consistent problem across all TV shows on all channels, in which the recording seems to start about 30 seconds to a minute early, and ends thirty seconds to a minute early. What this amounts to is that it starts recording during the credits of the show previous to the one I want to record, and ends recording during the credits of the recorded show -- or worse, a minute from the very end.
Is there anything I can do about this, short of taking it up with Time Warner? Is there a way to adjust recording times in advance (i.e. not when the thing is actually recording)? Any recommended workarounds would be great.
levensteins is offline
post #2 of 3 Old 03-08-2008, 11:10 AM
nofool's Avatar
if i recall, selecting record show/series *with options* gives you a few choices you can change, including 'original start time' and end - you could tell it +/- 1 min at a time..... sounds like you would want to leave the start time or add a minute and add a minute or two to the end. hope it works.
nofool ;)
broadcast junkie/hopeless surfer (cable-reluctant/dvr-hooked)
SD/ana PV-M2058 w/SA8300HDC-TW, PanDVD-F65 w/ToshSMC5560 ZenSF1315W w/ShpVC-H800U
not really high-tech (what can i say..)
nofool is offline
post #3 of 3 Old 04-06-2008, 11:20 AM
rposa's Avatar
I almost always end up putting a 1 minute lead, and a 2 minute after on my series recording. Just in case.
Time Warner in the midwest..
rposa is offline
Reply Digital Recorders (PVRs) General
