Motorola Cable Box DVR video settings keep switching. - AVS Forum | Home Theater Discussions And Reviews
Old 03-12-2008, 10:18 AM - Thread Starter
tasmanohio's Avatar
I have the Motorola DCT3416 HDTV Cable Box and HDTV DVR hooked up to sony 810 receiver. hdmi and then hdmi out to my 47" Lcd vizio. I set my cable box to stretched for the video setting. It will work great but then when shut my tv and receiver off for the night(i leave my cable box on) when i go to turn it back on the next day it is set back to 480i anyone know how i can fix this????
tasmanohio is offline
Old 04-06-2008, 05:35 PM
bdoss69's Avatar
Same box same problem. I switch this in user setting in the menu. If I shut off my projector (leaving dvr on) it is always switched back to 480i next time I switch it on. Any ideas?
bdoss69 is offline
Old 04-08-2008, 09:53 AM
ImaBiggles's Avatar
is it changing in the setup menu? I know my picture used to change due to handshake issues - but the setting in the menu was always the same.
ImaBiggles is offline
Old 04-12-2008, 06:55 PM
bdoss69's Avatar
The picture changes with the hdmi handshake stuff going on and the menu setting is also changed back to 480i.
Is there no way to fix this? Thanks
bdoss69 is offline
