Mpg video? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-24-2008, 07:00 PM - Thread Starter
corelor's Avatar
Im somewhat new to recording formats? What is the difference from mpeg-1 to mpeg-2 or 4?
I assume they all have basic similarities... why the different compressions?
corelor is offline
post #2 of 2 Old 03-24-2008, 07:37 PM
Guest
Quoted: 38 Post(s)
Liked: 198
From this Wikipedia entry:
"MPEG has standardized the following compression formats and ancillary standards:
  • MPEG-1: Initial video and audio compression standard. Later used as the standard for Video CD, and includes the popular Layer 3 (MP3) audio compression format.
  • MPEG-2: Transport, video and audio standards for broadcast-quality television. Used for over-the-air digital television ATSC, DVB and ISDB, digital satellite TV services like Dish Network, digital cable television signals, SVCD, and with slight modifications, as the .VOB (Video OBject) files that carry the images on DVDs.
  • MPEG-3: Originally designed for HDTV, but abandoned when it was realized that MPEG-2 (with extensions) was sufficient for HDTV. (not to be confused with MP3, which is MPEG-1 Audio Layer 3.)
  • MPEG-4: Expands MPEG-1 to support video/audio "objects", 3D content, low bitrate encoding and support for Digital Rights Management. Several new higher efficiency video standards (newer than MPEG-2 Video) are included (an alternative to MPEG-2 Video), notably:
  • MPEG-4 Part 2 (or Advanced Simple Profile) and
  • MPEG-4 Part 10 (or Advanced Video Coding or H.264). MPEG-4 Part 10 may be used on HD DVD and Blu-ray discs, along with VC-1 and MPEG-2."
7558037 is offline
Reply Digital Recorders (PVRs) General
